May 19th, 2014, 09:04 PM | #1 |
OEM turn signal not staying in place
EDIT: Problem solved!
I think it was ever since I low sided a couple months ago and replaced the whole side fairing the turn signal fits really loose inside its "socket". I had trouble with installing the turn signal rubber "socket" because the new fairing didn't come with it (or any of the freaking needed hardware) and I had to pry it off the damaged fairing. It can be pushed in to place but after a ride it will be loose and look like this: Here's some pics of it: When I push it in:
The most dangerous risk of all is the risk of spending your life not doing what you want... Last futzed with by Brian; May 20th, 2014 at 09:25 PM. |
May 19th, 2014, 09:08 PM | #2 |
Fresh Deli Meat
Join Date: Feb 2014 Motorcycle(s): 2009 250R Ninja -Neener- Posts: 678
Really easy fix for that.
Take the stock ones off, plug these ones in http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
We shall call thee "Seahorse." -Antiant on Couvade Syndrome |
May 19th, 2014, 09:11 PM | #3 | |
The most dangerous risk of all is the risk of spending your life not doing what you want... |
May 19th, 2014, 09:12 PM | #4 |
Metal plate that the screw goes into needs to be on the backside of the fairing.
May 19th, 2014, 09:14 PM | #5 | |
I'll try to reach my hand around the fairing.
May 19th, 2014, 09:18 PM | #6 |
You can do it from up top through the fairing/ upper cowling surround. Just turn the front wheel right to give you room. You'll have to take apart the turn signal and rerun the wires back though.
May 19th, 2014, 09:21 PM | #7 |
Fresh Deli Meat
They are plug and play, fit exactly where the stock ones do. I recommend these because they are easy to hook up and didn't cause any damage to the bike or the lights when I crashed. The stock turn signals maul the **** out of your fairings when you go down.
May 19th, 2014, 09:34 PM | #8 | |
That is definitely on my list of stuff to buy, there's no need to remove the fairings, right? Also would it be okay to go with the flush mount versions instead of the ones that stick out like stock?
May 19th, 2014, 09:57 PM | #9 | |
Fresh Deli Meat
Keep in mind, while I have no experience with LED set ups, there is a lot of information on the forum about issues with blinking and needed certain relays or something. LEDS seem like a headache to me so it might be something to keep in mind.
May 19th, 2014, 10:02 PM | #10 | |
Thanks
May 19th, 2014, 10:06 PM | #11 |
Fresh Deli Meat
always happy to help man. It's what the forum is for. When you do get new lights mounted, make sure you take a picture and post it. Everyone likes to show off the new bits lol
May 20th, 2014, 07:31 AM | #12 | |
Certified looney toon
MOTM Jul '13, Jul '14
Don't be scared of LEDs. Very very simplistic reasoning. Your stock lights with their normal incandescent bulbs draw X amount of power, that the stock thermal relay uses to turn on/off/on/off/etc. LEDs draw much less power, which leaves the stock relay doing nothing because there isn't enough power to get it working. Instead of relying on the heat, using an electric relay works as it will turn on/off/on/off/etc regardless of how much power is being drawn. That's for if you have only two LEDs (like the front signals). Adding more, such as the rear tail light or rear blinkers) is when you get into needing a diode to prevent that electricity from wandering all over the place and lighting everything up. I went with the no-cut diode kit and the install was very easy when following the provided video. Are LEDs worth it? Just this weekend, I had a rider following me who later asked if my lights were stock. He explained that my turn signals from behind were VERY bright and noticeable. That right there made them entirely worth it for me. Don't write them off so fast, they are a good upgrade if you want.
May 20th, 2014, 10:09 AM | #13 | |
EX500 full of EX250 parts
There's a pretty simple way to do this at the bulb by replacing it with two small LEDs and an additional ground wire, but I'm not sure how reasonable it would be to make a kit for it. I think Tri's no-cut kit is about the easiest way to do it in kit form. |
May 20th, 2014, 10:20 AM | #14 |
Track Clown
MOTM - Sep '15
looks like you put it together wrong.
May 20th, 2014, 10:32 AM | #15 |
Intrepid Adventurer
Join Date: Jan 2012 Motorcycle(s): 2004 GSXR 750 , 71 cb350streettracker, 07 Polaris Predator 500 Posts: A lot.
Metal plate on the inside
rubber in the fairing stalk on the outside. that way the rubber is squished between the stalk and the plate causing it to expand outward and holding it tightly in place.
LIFE IS NOT FOR REGRETS OR EXCUSES. Breath deep, seek peace. Embrace the Madness. Life is good, let it be |
May 20th, 2014, 10:27 PM | #16 |
Thanks for the help guys. Here's some pics from the work in case anyone in the future needs this thread! :
pull on the sides of the plastic case to pull out base indicating long green wire and short black/yellow wire positions the two wires, out of the bulb housing and feeding it around tada!
May 21st, 2014, 08:01 AM | #17 |
Good job.
Looking for 09 oem rear turn signal and front turn signals and tail fairings | mbbernas | Items Wanted | 1 | September 11th, 2013 10:48 AM |
WTB: OEM Front Left Turn Signal | ladyinbread | Items Wanted | 2 | September 12th, 2012 07:30 AM |
2008-2012 Ninja 250 OEM Front right turn signal | dkstariob | Motorcycle-related | 2 | June 4th, 2012 11:46 AM |
wtb 2008+ oem right, front turn signal | sunshine | Items Wanted | 1 | November 10th, 2010 09:13 AM |
OEM Turn Signal Reflector ( inside ) | jorgecornet | Items Wanted | 0 | May 25th, 2010 06:51 PM |
