Old September 16th, 2015, 10:18 AM   #1
pb3
Motorcycle(s): 09 n250, 14 n300, 22 n400
radiator hoses and o-rings
hi all,
well con't my catch up with periodic maintenance items, the manual says replacement of radiator hoses and o-rings every 3 years. i count 7 hoses and 5 o-rings. does K sell a kit? anyone else found this interval to be necessary?
bike in question is '09 with 12k
tia,
parker
pb3 is offline   Reply With Quote
Old September 16th, 2015, 10:42 AM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Hoses last for many years, especially if the bike spends a lot of time in a garage or shed (out of sunlight, away from ozone sources). I replaced my K75 coolant and fuel hoses when the bike was 14 years old as a precautionary measure, but I could have waited longer.
I replace o-rings when they leak. The coolant pipe o-rings tend to leak when disturbed.
Old September 16th, 2015, 10:44 AM   #3
The secret to a happy life is....
"Do not fix what is not broken."
Visually inspect your hoses and such. If they look worn or cracked or suffer any dry rotting, then replace. Otherwise, it aint broke and you are participating in a system designed to extract as much $$$ out of you as possible.
Old September 16th, 2015, 10:53 AM   #4
dcj13
Participant
dcj13's Avatar
Well stated.
And if you inspect the o-rings, you'll be replacing them.
Old September 16th, 2015, 11:09 AM   #5
pb3
understood. i've got some of the blue green stuff around the thermostate housing and cap. but i'll just check for tightness, wipe it off and move on?
Old September 16th, 2015, 11:14 AM   #6
dcj13
Participant
dcj13's Avatar
Yeah, but keep an eye on it. If it continues to weep, figure out where it's coming from: radiator cap; cracked radiator; hose/clamp; etc.
Old September 16th, 2015, 12:32 PM   #7
pb3
Old September 16th, 2015, 02:53 PM   #8
dcj13
Participant
dcj13's Avatar
I'd snug that clamp up a bit if it were my bike. Then keep an eye on it.
It appears you got lucky!
Snug up all 4 clamps.
Last futzed with by dcj13; September 16th, 2015 at 02:55 PM. Reason: added blurb about other 3 clamps.
Old August 4th, 2017, 05:49 AM   #9
pb3
Old August 4th, 2017, 08:39 AM   #10
ninjala
Motorcycle(s): 2008 Ninja 250
I got 08 with 65K. I never change the hoses and O-rings. Every time I check the coolant level, it is always full. the cooling system is great.
ninjala is offline   Reply With Quote
[roadracingworld.com] - Video: Installing New Radiator Hoses And A Coolant Overflow B Ninjette Newsbot Motorcycling News 0 January 27th, 2015 10:40 AM
