May 21st, 2017, 07:59 AM | #1 |
Join Date: Jan 2017 Motorcycle(s): 2008 Triumph Speed Triple (Blazing Orange); 2010 Nina 250r (Race Project) Posts: 97
Is this chain done?
Gimme your .02. In VA, under a cover, but tons of rain and humidity. Surface rust around about the chain. Pic is aftrr about 10 minutes of grunge brush and kerosene.
May 21st, 2017, 09:04 AM | #2 |
How to tell if its time to change the chain 101.
1. Does it have any frozen links? 2. Does it make a patterned grinding noise that seems to come and go as speed changes? 3. Once adjusted to spec slack, will hit hold that slack for many, many miles? 4. Is the chain visibly damaged in any way? 5. Is there any abnormal wear patterns that cause concern? 6. Will the clip/rivet stay secure on the master link? 7. Does the chain slack measure "fairly close" if take in 4 different spots on the chain? 8. Do you not like the color of your chain? 9. Is your chain too dirty even after cleaning it very well? 10. Are you jelly that your track buddy has a race chain and you still have the 520? hahahahahahah Take a stiff bristled brush and give it a good cleaning, it looks fine to me.
May 21st, 2017, 10:36 AM | #3 |
I appreciate the insight!
I broke down and bought a new one. This will be my lady's track bike, and if anything did happen on that chain, I'd hang up my helmet. Nothing wrong with starting fresh! |
May 21st, 2017, 11:13 AM | #4 |
MOTM - July '15
Good man!
May 22nd, 2017, 06:35 PM | #5 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill |
May 22nd, 2017, 06:37 PM | #6 |
Agreed! I got the Vortex kit. Kept it stock just so I can learn a bit more before I meddle!
May 22nd, 2017, 10:20 PM | #7 | |
New Chain
Bill |
August 2nd, 2017, 09:35 AM | #8 |
Guest
Posts: n/a
I didn't want to start a new thread so I thought I'd piggyback on this one.
My chain is very loose and not in great shape. I am looking to just tighten up the chain to get a little more use out of the bike, I probably won't replace the chain as I do not want to put any more money into the bike. I watched a video on chain adjustment and they said to not adjust the chain past the horizontal slash on the wheel alignment markers. Is this true, can I tighten up my chain past this point? I added some pics below. Thanks |
August 2nd, 2017, 10:10 AM | #9 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
I don't know what slash they're talking about, but you probably have enough adjustment range to tighten that (super loose) chain. That said, it looks like it's in pretty bad shape and probably not safe. Breaking a chain underway can be VERY bad.
bike * miles = smiles smiles / bike = miles smiles / miles = bike |
August 2nd, 2017, 10:22 AM | #10 | |
August 2nd, 2017, 01:41 PM | #11 |
why can you not take it past the horizontal slash? maybe a new chain, so you still have adj room, but other than that I dont see why not. school me.
August 2nd, 2017, 02:06 PM | #12 |
I guess if you want to not have to replace chain AND both sprockets, you can replace just chain at end of slash mark. After that, things are too worn and you should replace all three.
August 2nd, 2017, 02:34 PM | #13 | |
Bill |
August 2nd, 2017, 02:47 PM | #14 |
so it has nothing to do with location, for example when i drop some teeth in the rear, for gearing, on my smallest sprocket i am past the hash mark, and your saying thats no good? i dont want to drop a link just for the smaller sprocket.
August 2nd, 2017, 03:07 PM | #15 | |
Bill |
August 2nd, 2017, 03:26 PM | #16 | |
i did watch a motogp vid where they kept the axel in the same location when changing out the sprockets, to not change the geometry of the bike, was not sure if thats where they were going with there post. |
August 2nd, 2017, 05:04 PM | #17 |
Yeah, I never bother with marks on swingarm because they're really not that accurate.
I prefer to measure wear in %-stretch or pull-chain-off-sprocket test. I'm running a 18/59t 428 conversion anyway, so those marks don't apply. |
August 2nd, 2017, 05:08 PM | #18 |
Right, it's just a fool-proof test to know when the chain is worn to the point of needing replacement, but it relies on your having the stock sprockets installed. Measuring the chain is really the most straightforward and accurate way to know when it needs replacement.
August 2nd, 2017, 07:00 PM | #19 | |
You didn't hear that from me and you can't use it to go faster than me! |
Several things for sale (RK chain tool kit, sprockets, RK chain) | Bones85 | Motorcycle-related | 9 | May 11th, 2016 05:00 AM |
More chain trouble: 2-month old chain, O-Ring failure at master link. :( What now? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 56 | July 7th, 2012 05:42 PM |
[webbikeworld.com] - Chain Pickle Motorcycle Chain Cleaner and Degreaser Review | Ninjette Newsbot | Motorcycling News | 0 | April 1st, 2011 04:22 AM |
[webbikeworld.com] - DuPont Chain Saver Motorcycle Chain Lube Review | Ninjette Newsbot | Motorcycling News | 0 | May 18th, 2009 09:50 PM |
[webbikeworld.com] - Chain Drain Motorcycle Chain Cleaner System | Ninjette Newsbot | Motorcycling News | 0 | September 4th, 2008 05:42 PM |
