Old August 6th, 2017, 04:22 PM   #1
ck.mecha
Motorcycle(s): 1969 Benelli Cobra 125, 1970 Honda CB160, 2009 Kawasaki 250R
Broken Camshaft Cover?!
Well, I was breaking into a POS I bought a while back to finally check the valve clearances.
Somehow either I broke one of the bosses that the head cover bolts to the cam cover or I didnt notice that the PO did. I see three solutions each with their own positives and negatives, what say the masses?
1) Do nothing, somehow plug the hole and allow 3 bolts to hold the head cover on. Would be the easiest but oil leakage is possible. I dont like this solution. 1b) JB weld or similar...
2) Replace entire cap with one from another head. I happen to have one, but im concerned since these parts are factory matched I may end up with premature cam journal wear. This may be a temp solution to get me through the race season.
3) Have the current one welded. Im concerned there will be warpage since this is a cast component and I may have the same problem as simply replacing it.
I know the proper solution is to replace the entire head, but with a race scheduled less than 2 weeks away I really dont want to break the engine down with no test scheduled in between.
ck.mecha is offline   Reply With Quote
Old August 6th, 2017, 11:22 PM   #2
I would use aluminium brazing to fix. Much lower temps so warpage won't be an issue. Yet still quite strong with 40-45kpsi strength. I've used it to fix broken alternator ears, join intercooler pipes, etc.
Broken sprocket cover bolts kvgeorge1 2008 - 2012 Ninja 250R Tech Talk 20 September 28th, 2017 01:33 PM
Broken Valve Cover Bolt -- Where Can I Buy Better Bolts? Cra1g 1986 - 2007 Ninja 250R Tech Talk 12 August 31st, 2016 01:55 PM
Camshaft Issue jpatt87 2008 - 2012 Ninja 250R Tech Talk 42 March 25th, 2014 02:49 PM
camshaft profiles micoulisninja 2008 - 2012 Ninja 250R Tech Talk 30 February 12th, 2014 04:01 AM
Intake Camshaft jpatt87 Items Wanted 14 January 19th, 2012 08:55 AM
