August 8th, 2017, 12:23 AM | #1 |
Join Date: Sep 2015 Motorcycle(s): Kawasaki Ninja 250R '08 Posts: 1
Ninja 250R '08 FI - Oxidized contact somewhere
Hey folks,
I'm sure the issue I have is due to an oxidized contact somewhere and my hope is that someone here can help me figure out where to look. Backstory: My bike's been sitting out in the rain unfortunately, since my bike's cover got stolen - twice. I will buy a 3rd one and lock it up this time, in the meantime though I gotta fix the bike. I had an issue starting the bike ~2 weeks ago where I bought a new battery, tested the solenoid which was working correctly and found out, in the end, that it was in issue with the engine start button on the handlebar. There was an oxidized layer on the contacts of the button so I ended up scratching it off with a knife and it solved the problem. Now, I have a different problem... Issue description: This morning, the bike wouldn't start again. The electronics wouldn't come up at all, no light, all LEDs off, no solenoid click. So I tried a few things and found that when I push the bike forward and grab the front brake, the electronics come up during the forward "swing", for lack of a better word. If I try pressing the engine start button though, once the bike has settled, the solenoid clicks once and everything turns off. So obviously, the next thing I did was to push it and brake, electronics come up, push it and brake again while pressing the engine start button, thus starting the bike. So for now I have a workaround to start the bike, but that's obviously temporary and far from ideal. I'd like to find the oxidized contact and clean it, but I'm not sure where to look. I assume it's a contact that is parallel with the bike somewhat or laying under something heavy so it is compressed during the "swing"? Not sure. Also, the bike runs fine once started so I assume the engine vibration is enough to create enough tension on the contacts to keep the current flowing? I'm talking out of my *** here so... anyway. Looking for help. Thanks Last futzed with by crazydarcz; August 8th, 2017 at 04:14 AM. |
August 8th, 2017, 06:23 AM | #2 |
I would start at the battery. Confirm the voltage is correct at 12.7V or more. Check the battery terminal connections and the connections to the solenoid and chassis ground.
It sounds like something is loose and the movement temporary improves the connection. A battery that is shorting internally may do the same thing. Get some Dielectric Grease, clean the terminals well, and apply the grease to any contact points. |
[motogp.com] - Petrucci: “I am very sorry for the contact with Aleix” | Ninjette Newsbot | Motorcycling News | 0 | June 1st, 2015 04:50 AM |
[motogp.com] - Pedrosa taken out after contact with Marquez | Ninjette Newsbot | Motorcycling News | 0 | September 29th, 2013 06:40 AM |
To anyone else who wears contact lenses.... | Honko | General Motorcycling Discussion | 18 | August 17th, 2011 08:31 PM |
[roadracingworld.com] - Video: Yates Says There Was No Contact, Young Says There Was | Ninjette Newsbot | Motorcycling News | 0 | June 10th, 2009 11:40 AM |
[roadracingworld.com] - New Contact Information For CMRA | Ninjette Newsbot | Motorcycling News | 0 | March 24th, 2009 04:50 PM |
