September 15th, 2015, 02:16 PM | #1 |
Join Date: Sep 2015 Motorcycle(s): 08 ninja 250r Posts: 4
my 08 ninja 250r wont run after it was tipped over
my bike fell over on me when i was pushing it up the driveway and now it wont run. It ran for a min and stalled on me and hasnt ran since. ive cleaned the carbs and changed the spark plugs still nothing. itll try to run off of starting fluid. any tips on what i should do?
September 15th, 2015, 02:29 PM | #2 |
Could be a couple things.
Either it flooded when it tipped over, or the floatbowls drained and there's not enough fuel. Try cranking it without choke and opening the throttle - 1/4, 1/2, full - for 5 seconds each. If it doesn't start after that, try adding full choke for 5 seconds of cranking, then back it off to 1/2. If no go, open the throttle 1/16 to 1/8 and try. You may need to charge the battery after all of that if it doesn't light up. |
September 15th, 2015, 02:40 PM | #3 |
thanks ive tried it but no go i have it hook up to a car battery
September 15th, 2015, 02:48 PM | #4 |
September 15th, 2015, 03:29 PM | #5 |
idk thanks, im going to look it over again tomorrow. it looks like my oil has some coolant in it.
September 15th, 2015, 05:13 PM | #6 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Verify you have spark at the plugs.
September 15th, 2015, 06:28 PM | #7 | |
If that's the case, the coolant overflow bottle should be low. The oil would be milky-colored (maybe some green color if that's the color of the coolant) and the oil level might rise. The exhaust could show more vapor than normal and it would have the unusual smell of heated coolant. |
September 17th, 2015, 12:10 PM | #8 |
it has spark, and the oil is milky looking.
September 17th, 2015, 01:25 PM | #9 |
Participant
You don't want coolant in the oil, of course, but that shouldn't keep it from starting.
With respect to starting: have you tried a shot of starting fluid (diethyl ether)? |
September 17th, 2015, 01:57 PM | #10 |
You can get milky-looking oil from condensation forming in the engine. It can take a while (like 30 minutes) of riding to clear the window, and it may form again as it cools if the conditions are right - not much you can do about it except extend your short trips and minimize idling.
Check your coolant overflow. If there's any amount of coolant leaking into the oil the level will be dropping. You could try a shot of Starter Fluid as dcj recommended. It doesn't take much. I've had engines that refused to start normally start right up with a shot even though they ran just fine days before and after (no carb issues). |
October 5th, 2015, 07:23 AM | #11 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
You say you cleaned the carbs. This was after the issue of not starting began?
When you reassembled them is it possible one of the vacuum hoses got crossed? Have you verified that you have fuel getting in to the carb bowls? Each bowl has a drain screw. Loosen the screw and see if fuel comes out. If there is fuel in the bowls I would suggest pulling the plugs and trying to start the bike without them. Obviously it won't start, but if there is excess fuel in the cylinders it will blow it out. Put the plugs back in and try again. If there is not fuel in the bowls, take the carbs apart and clean them again and set the float heights as per the manual. Using an air compressor, blow through all the passages and jets. Ensure the vacuum hoses are routed properly and try again. |
October 13th, 2015, 09:53 PM | #12 |
Join Date: Jul 2015 Motorcycle(s): ninja 300 ninja 250 project Posts: 35
maybe its flooded
October 14th, 2015, 08:03 AM | #13 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
I assume it's turning over/cranking, but won't fire?
Which side did it fall on? Any way to post a video?
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
Need Help Diagnosing Bike That Wont Run | Yondaime | 2008 - 2012 Ninja 250R Tech Talk | 25 | October 4th, 2014 01:18 PM |
[superbikeplanet.com] - Former ISC Catering, Merchandise Exec Tipped To Run DMG | Ninjette Newsbot | Motorcycling News | 0 | January 15th, 2013 11:30 AM |
Help!! Need advice... Bike Wont Run | Trainsk8 | 2008 - 2012 Ninja 250R Tech Talk | 3 | May 30th, 2012 06:32 PM |
bike wont run without choke on? | ReDnEcK | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 15th, 2010 08:50 PM |
Ninja 250r Wont Rev or run without choke | esde | 1986 - 2007 Ninja 250R Tech Talk | 21 | November 9th, 2009 02:32 PM |
