Old August 24th, 2021, 11:05 PM   #1
Austin0707
Austin0707
Motorcycle(s): 2011 ninja 250
Can't get my ninja to start after carb clean
Hello, I am having some trouble getting my ninja 250 to start after fully cleaning the carbs and was wondering if someone can guide me thru troubleshoot steps? I'm not even sure if I have the hoses on right for start. I have the breather from tank haning out not sure if it connects to anything, I have no hose connected to under the handlebars that goes to the airbox
Austin0707 is offline   Reply With Quote
Old August 24th, 2021, 11:50 PM   #2
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
I got the manual for the 2012 kawasaki Ninja 250R on line and down loaded it
and it has hose connection details in it....
if you have just one hose wrong that could be causing the bike not to start.
the vacuum lines from the carb are the ones I would suspect first... those are the ones that go directly into the intake manifold , where you check for carburetor synchronization at... if their unplugged, the bike won't run.
or of their plugged into the wrong place....
the hoses have to be right.... you can't fake it and luck out !
get a manual and double check every line on that thing....
once your satisfied all is correct then you can start trouble shooting as to why it won't start.
Sorry I can't be more helpful than that but certain things MUST be right on these things, and the hoses that go everywhere are one of them.
Bob......
Old August 25th, 2021, 05:05 AM   #3
ducatiman
ducatiman's Avatar
1st......Ca or 49 state model?
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old August 25th, 2021, 06:03 AM   #4
Look over this section for carb info, photos, and troubleshooting tips -
https://faq.ninja250.org/wiki/Intake
Old August 25th, 2021, 08:32 AM   #5
What procedure did you use to clean carbs?
Did you turn petcock on?
Did you hook up vacuum hose to petcock?
Choke cable connected and adjusted?
Use small squirt-bottle to spray 1cc petrol down carb-throats (or into airbox snorkel). If engine starts, you know it's fuel-delivery issue.
Old August 25th, 2021, 12:04 PM   #6
Austin0707
Austin0707
Yeah I hooked up the vacuum and fuel line from the tank, I will have to try that spray next! Are the other lines crucial to get hooked up? Online it shows it as a emission line not exactly sure where that goes
Old August 25th, 2021, 12:05 PM   #7
Austin0707
Austin0707
49 state model
Old August 25th, 2021, 12:30 PM   #8
ducatiman
ducatiman's Avatar
3 vac hoses present/connected to top of decel valve?
did you split the carbs when cleaning?
remove EPA caps over pilot screws? how many turns out are they set at?
Custom Carb Service
Old August 25th, 2021, 01:20 PM   #9
Austin0707
Austin0707
That's probably what I am missing, there is a valve by the manifolds thay gors to the air box and nothing is connected. I screwed it in all the way and turned it 4 times.
Old August 25th, 2021, 05:48 PM   #10
ducatiman
ducatiman's Avatar
valve, goes to airbox, nothing connected? could you clarify?
Custom Carb Service
Old August 25th, 2021, 05:54 PM   #11
Austin0707
Austin0707
Wish I could send a pic i took but its udber the handlebars and it connects to a big hose that goes over the carbs and into the airbox on the side
Old August 25th, 2021, 06:31 PM   #12
Only big hose that goes into airbox's side is PAIR valve:
If so, you've got CA model.
Old August 25th, 2021, 09:19 PM   #13
Austin0707
Austin0707
Ah dang that's exactly what I have, I have the 3 spliter I'm assuming 1 goes to there then. So does it just connect 2 ways out of the 3?
Old August 25th, 2021, 11:28 PM   #14
All three legs of splitter needs to be plugged in. You can use this arrangement with 3rd port going to drive PAIR valve.
Old August 25th, 2021, 11:56 PM   #15
Bob KellyIII
Good work Danno !
you nailed it !
good man !
Bob.....
Old August 26th, 2021, 12:19 AM   #16
Austin0707
Austin0707
Thats it! The picture didn't show a hose for the 3rd slot thats why I was confused but now I see it hooked up to that valve! Thank you so much now I can hopfully get it running! Does it matter what hose is connected to which on that 3 line?
Old August 26th, 2021, 09:40 AM   #17
Doesn't matter how you have 3 legs of splitter hooked up. As long as all ends are connected to proper ports:
- carb vacuum port (source)
- coast enricher
- PAIR valve (CA emissions fitting)
Make sure vacuum hoses fit snuggly and clamps actually apply pressure. Otherwise, you can use small zip-ties.
Old August 26th, 2021, 10:40 AM   #18
Austin0707
Austin0707
- coast enricher
Ok perfect thank you! Will I have to take the carbs out and re clean them? I tried starting it with the vacuum from the petcock in the spot where the emmision spot goes
Old August 26th, 2021, 11:08 AM   #19
That didn't do anything to the carbs that would require another cleaning.
Old August 26th, 2021, 11:41 AM   #20
Austin0707
Austin0707
- coast enricher
Old August 27th, 2021, 11:04 AM   #21
That should be OK. But where does 2nd-carb's vacuum port go? If it's just left open, that'll cause you problems.
Old September 6th, 2021, 06:30 AM   #22
Bob KellyIII
HAHAHAH haven't heard from Austin in a month...he must have got it going again ! HAHAHAHA !
thanks for helping guys that was way over my head !
Bob.......
Old September 6th, 2021, 06:31 AM   #23
11 days does not a month make.
Old September 6th, 2021, 02:15 PM   #24
Bob KellyIII
LOL your absolutely right ! and some people have to work for a living too !
, it just seemed like a long time to me ! .
Bob......
Old September 6th, 2021, 04:19 PM   #25
Time flies when you're ADD!!!
clean carb t-cab12 Items Wanted 2 May 4th, 2018 08:21 AM
Another Carb clean quesiton. blink. 2008 - 2012 Ninja 250R Tech Talk 1 June 23rd, 2015 07:16 PM
Strange Fueling after Carb Clean ncarota 1986 - 2007 Ninja 250R Tech Talk 21 January 30th, 2015 01:50 PM
carb clean and shimming 86 ninja 250 james250ninja 1986 - 2007 Ninja 250R Tech Talk 2 August 28th, 2014 07:33 AM
Valve adjustment, carb clean, carb sync? amad1972 1986 - 2007 Ninja 250R Tech Talk 2 July 29th, 2014 09:42 PM
