Old August 26th, 2021, 09:50 PM   #1
msagcaoili_1991
Motorcycle(s): 2009 Ninja 250
Turn signals won’t work when I turn my front wheel to the left
I’m having trouble with my turn signals.
When I have the front wheels pointed straight forward or to the right, the turn signals work perfectly.
Once I turn the wheel to the left, passing the centerline the indicator lamp and turn signals won’t work. But when I point the tires straight and towards the right. It all works fine again.
Feels like something is possibly loose and that steering to the left is breaking the connection.
msagcaoili_1991 is offline   Reply With Quote
Old August 27th, 2021, 04:04 AM   #2
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
It sounds like the wires are not routed properly from the handle bars down to under the tank and when you tirn left it pulls the wires hard enough to break the connection... DEFINATELY NOT GOOD ! you'll probably have to pull the fairings off and the gas tank and maybe even the head light/front fairing to get at it to fix the problem... the manual shows the proper routing.
but even with the wires routed properly their quite tight on my bike...
I added 1" bar risers to my bike and I had to cut one of the steel loops for the wire routing to free up the wires that go to the turn signal switch just to give it a bit more room.....
electrical wires do not like to be stretched at all they have to have some slack
... more than likely one of the blades in the 6 by plug in is loose and will come out when you turn.... I would look there first !
Bob...
New Front Turn Signals Won't Work tmlewis3 2008 - 2012 Ninja 250R Tech Talk 10 February 9th, 2014 11:53 AM
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
Rear turn signals don't blink, front turn signals don't turn on andyuc88 2008 - 2012 Ninja 250R Tech Talk 3 March 23rd, 2012 02:47 PM
Went down, now turn signal won't work subiegy2010 General Motorcycling Discussion 14 March 18th, 2010 12:12 PM
