Old October 14th, 2021, 08:00 PM   #41
Dizzy
Motorcycle(s): 250r
Alright check back tomorrow and I'll put a little video up on YouTube and post it here Thanks For Everyone's help much appreciated guys
Dizzy is offline   Reply With Quote
Old October 15th, 2021, 06:48 AM   #42
Dizzy
Motorcycle(s): 250r
As promised here's a little short video of it running before I just dumped the oil a few mins ago
Old October 15th, 2021, 06:50 AM   #43
Dizzy
Motorcycle(s): 250r
Old October 15th, 2021, 06:54 AM   #44
Dizzy
Motorcycle(s): 250r
Might have to click on link idk why didn't work first time
Old October 15th, 2021, 07:40 AM   #45
Dizzy
Motorcycle(s): 250r
Ok so lucky I know how to rev and shift it rides good but its like when I pull the clutch lever its like its not letting it free spin any idea's guys ran it up to 45 and 4 gear before backing down ideas on the clutch?
Old October 15th, 2021, 09:39 AM   #46
Dizzy
Motorcycle(s): 250r
Recommendation of places to buy new clutch plates gasket etc for my bike clutch is not disengaging probably because of it sitting and that nasty mayonnaise oil
Old October 15th, 2021, 10:04 AM   #47
If you push it and slip it into gear, and carefully do clutchless shifts, you can warm it up fully while holding the clutch lever to the bar the whole time. This will help the water-in-oil problem, and may let you break the plates free with a couple full-throttle blasts.
If they're really stuck I've had to take the clutch cover off and pry the plates apart to free them up.
Old October 15th, 2021, 10:56 AM   #48
Dizzy
Motorcycle(s): 250r
I may try to do that in a little bit I'm feeling under the weather and a little sick so maybe in a few hours I will ride it more I know how to speed shift or rpm safe easy shift... I only put 1 mile on it earlier I'll mess with it later before I decide to order the gasket and take the cover off
Old October 15th, 2021, 12:05 PM   #49
Usually causes opposite problem with clutch-slipping. Might just need cable adjustment; tighten adjuster on either end about 1/4-1/2 turn. Verify disengagement/engagement point is about 1/2-way through lever pull.
Old October 15th, 2021, 08:20 PM   #50
Dizzy
Motorcycle(s): 250r
Sooo decided to just tear into it and check everything and ....
Old October 15th, 2021, 08:29 PM   #51
Dizzy
Motorcycle(s): 250r
Pulled the clutch cover off and cleaned hole bottom end because clutch got stuck engaged and that sucked so said nope pull it apart its pretty easy only 15 bolts or so......
Old October 15th, 2021, 08:37 PM   #52
Dizzy
Motorcycle(s): 250r
So pulled the plates off the metal ones cleaned up a little and sitting in gas until tomorrow and the fiber plates in oil I'm thinking I can use 600 grit wet sand paper with gas and seafoam and get the plates clean enough that new ones can wait till later I believe I can get away with it thoughts.... I thought it was going to be alot worse what's everyone watching this thoughts on the clutch and tips are always welcome thanks guys be back tomorrow with update
Old October 16th, 2021, 02:07 AM   #53
Check edges of fingers on basket. If they have indentations from clutch-plates, you should file them off.
Be careful when assembling. Outer plate has dimple that must be positioned just right.
Old October 16th, 2021, 05:34 AM   #54
Dizzy
Motorcycle(s): 250r
Will do Danno not going to mess with it until later on this afternoon got a cold NOT covid.... Because covid is fictional scare tactics I'm gonna lay down and sleep some more so my body can do it's job and fight off this cold been legit years since I've been sick smh little brother passed something to me couple days ago I'll be alright I'll do a update on the progress tonight oh not gonna get a new gasket just gonna use some permatex gasket maker to throw the case back on after I clean the plates and carefully reinstall them have a good day everyone
Old October 16th, 2021, 08:44 PM   #55
Dizzy
Motorcycle(s): 250r
So a couple things can y'all look at the clutch plate pictures zoom in and see what y'all think about them reinstalled them and put the case back on got to get oil tomorrow to check if it was just sticking up let me know what y'all think was going to just order this kit of gasket and plates ideas on if they're good for the price....
Old October 16th, 2021, 08:45 PM   #56
Dizzy
Motorcycle(s): 250r
https://www.ebay.com/itm/27125299117...hoC5jYQAvD_BwE
Old October 16th, 2021, 08:47 PM   #57
Dizzy
Motorcycle(s): 250r
Gonna throw up another thread and ask for more views the look ok to me OEM plate's and gasket are 4-5x that price
Old October 18th, 2021, 02:53 AM   #58
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
You think that bad my fav brand Barnett are so over price it ant's funny any more costing $135 from them or 117 off eBay your better off with EBC
shspvr is offline   Reply With Quote
