Old October 10th, 2021, 07:50 AM   #1
adio21131
Motorcycle(s): 2011 ninja 250
Help Flooded engine/crankcase
hello everyone i dissassembled my carb cleaned the jets hooked up hoses wrong and my gas mixed with the oil. I drained the oil/gas mix and when i look in the sightglass i see like 2 metal plates still intact and showing that it is still full. did i hydrolock my engine with gas? its a 2011 ninja 250
i hooked the carb overflow hose up to the gas tank...
Last futzed with by adio21131; October 10th, 2021 at 07:57 AM. Reason: adding info
adio21131 is offline   Reply With Quote
Old October 10th, 2021, 08:06 AM   #2
Hi Matthew welcome to Ninjette!
As long as you didn't try to start it in hydrolocked condition, you should be fine. Drain all oil/gas mixture from crankcase, refill with fresh oil and engine should be OK. Sight glass is for looking at oil-level on glass surface itself, ignore everything you see behind it (clutch).
Last futzed with by DannoXYZ; October 12th, 2021 at 12:07 PM.
Old October 10th, 2021, 08:17 AM   #3
adio21131
I drained the crankcase i think bottom 17mm bolt where oil filter comes out correct? there is still that mixture inside after draining or am i missing another bolt to drain it? Sorry for noob questions i just dont want to pay for a tow if my new bike is toast i just bought it.
Old October 10th, 2021, 08:37 AM   #4
ducatiman
ducatiman's Avatar
https://faq.ninja250.org/wiki/J_model_oil_change
further suggest pulling spark plugs, cranking engine over for a few seconds to rid chambers of fuel leftovers
Use an old towel (or shop rags) over each spark plug hole as fuel will spray out/up quite a bit.
I perform 2 oil changes in such bikes to fully rid them of fuel, during the 2nd changing filter as well.
PS the carb "overflow" hose doubles as a vent hose....must be left fully clear and unkinked to breathe. Do not plug the end.
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old October 10th, 2021, 08:45 AM   #5
adio21131
Thank you both for the replies! it was just SLOW to drain i went back in the garage and my pan was overflowing. Will be taking it to a professional from now on LOL.
Old October 10th, 2021, 09:12 AM   #6
Or stick around and learn, and you won't have to pay to have others to do the simple maintenance jobs. You might be surprised at how many problems I read about that were caused by a "mechanic".
Old October 10th, 2021, 08:22 PM   #7
Yeah, there are many shops that rush and mess up simple procedures. Such as installing CBR250R (MC41) oil-filter backwards and destroying engine! You can do search here and find how-to guides for everything from adjusting mirrors to complete engine removal and rebuilds.
I'm just down street from you if you want to come over and help me with oil-change to see how it's done. Gonna change oil in my 2002 250, 2009 250R and 1986 VFR750F this coming week.
Old October 11th, 2021, 07:18 AM   #8
As suggested by others - learn to do it yourself.
You need to know how to work on your cycle, and what to look for before it becomes a safety issue.
It's not hard, and if Danno will help you - you are golden!
Old October 11th, 2021, 08:41 AM   #9
shspvr
Motorcycle(s): 07 Kawasaki Ninja 250
1: First Pull main oil drain plug and also pull the oil filter drain both side.
2: Pull both spark plugs and check clean out air box to.
3: Let sit for 24 hour open.
4: Refill with 10/40w oil
5: Spin the motor with out the spark plugs install for at 5sec
6: If all good fire her up
First of all the the carb don't overflow hose didn't you mean you hook up the vacuum hose to wrong side of fuel petcock it can happen.
shspvr is offline   Reply With Quote
Old October 11th, 2021, 08:43 AM   #10
shspvr
It usually just won't turn over
Old October 11th, 2021, 04:00 PM   #11
Yeah, in my case with strong battery, it did this :
Last futzed with by DannoXYZ; October 11th, 2021 at 08:54 PM.
Old October 11th, 2021, 05:05 PM   #12
shspvr
