Old July 3rd, 2010, 05:27 PM   #1
headshrink
headshrink's Avatar
Tire Changing Station
I'm wondering if this would be worth while in the future...
http://www.motorcycle-superstore.com...e-Changer.aspx
I currently have a nice bead-breaker, and break my back changing tires on the ground. It would be nice to change tires while upright. Has anyone ever used this? My primary concern is scratching and denting the rims. If there isn't some sort of protective material on those bars, I was thinking zip-tyeing old bicycle inner-tubes to the bars might do the trick...
Old July 3rd, 2010, 07:13 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
Guess it would be cool with spoons. Using the no-mar bar, would have to bolt that thing to the ground.....
Old July 7th, 2010, 12:42 PM   #3
Broc
Broc's Avatar
Motorcycle(s): 2009 Ninja 250R Black - Sold / 2011 Honda CB1000R
Get the harbour freight for the same price then just add a no-mar bar. What I use.
2009 Black 250R - Stock and staying that way. No matter what you do it's still a 250 at the end of the day! Save your money for gear, riding lessons, & a 600cc
Broc is offline   Reply With Quote
Old July 7th, 2010, 01:52 PM   #4
headshrink
headshrink's Avatar
Which one?
The Portable Tire Changer:
http://www.harborfreight.com/portabl...ger-34542.html
or the Motorcycle Tire Changer Attachment
Does the changer mar your wheel at all? Did you have to make any mods to protect it? How about mounting the tool itself?
Old July 7th, 2010, 02:32 PM   #5
Broc
Broc's Avatar
You need both. The tire changer stand is separate and you NEED the motorcycle attachment. I got both with coupons for $80.00 + tax. The clamps and the mounting/demount bar will scratch your rim and need attending to. I have been just cutting up wheel protecting strips to make the clamps and bar a no-mar setup. The changer is designed to bolt to the floor but I have mine bolted to a pallet with studs for portability( I do alot of other peoples tires.)
However, I will be ordering Mojoblocks(made to upgrade the harbour freight) for the wheel clamps, and a MojoBar for the no-mar mount/demount bar.
Both are here.
http://home.comcast.net/~prestondrake/mojoblocks.htm
-You could actually make these yourself if you can get ahold of Nylon stock.
http://home.comcast.net/~prestondrake/mojoweb.htm
Cheapest setup I've found! Plus this setup will cost me just over $200(I built a balancer myself with 2x4's and roller blade bearings.) Thats just 2 sets of tires installed, plus you can do other peoples tires. My setup has already paid for itself!
HERE
are all my tire changer/balancer links...including upgrades and use of the harbour freight setup:
http://www.advrider.com/forums/showthread.php?t=500556
http://www.clarity.net/~adam/tire-changing-doc.html
http://zx-10r.net/forum/showthread.p...733#post990733
http://www.fz6-forum.com/forum/tire-...e-changer.html
http://www.pbase.com/fredharmon/tirechange
http://www.advrider.com/Wisdom/TireChangerMods1.0.pdf
Old July 7th, 2010, 03:18 PM   #6
headshrink
headshrink's Avatar
That is fantastic information - thank you!
Old July 7th, 2010, 03:48 PM   #7
Broc
Broc's Avatar
I just went to go order my Mojolever and he raised the price from $89 to $99 shipped now. I am now looking back at the actual No-Mar Bar. I have heard the Mojolever is stronger and the No-Mar Bar has a tendency to bend.
However, the No-mar bar comes with a lifetime warranty, (3) extra tips, Tire lube w/ spray bottle, Instructions, comes from an actual company, & a DVD I believe. All this for $110 shipped.
The Mojolever comes with well the Mojolever, no warranty, just a guy who makes em, and no lube . All this for $99 shipped
Just an update! I still don't know who to go with. I'm gonna try to google more on the Mojolever.
Old July 7th, 2010, 06:37 PM   #8
headshrink
headshrink's Avatar
Looks like a really helpful tool , but man, talk about sticker shock - $100 for a stick!
Old July 7th, 2010, 07:22 PM   #9
Ramen
Frak It
Ramen's Avatar
There's gotta be a way to affix a piece of plastic on the Harbor Freight tire changer bar so the rims don't get scratched.
Ramen is offline   Reply With Quote
Old July 8th, 2010, 03:54 AM   #10
g21-30
g21-30's Avatar
Before everyone jumps on the HarborFreight Band wagon, you may want to checkout this link:
Old July 8th, 2010, 05:26 AM   #11
HKr1
IC2(SW)
HKr1's Avatar
No way the no-mar bar is gonna bend! The thing is beefy as all hell.... lube works great too
Old July 8th, 2010, 06:20 AM   #12
Broc
Broc's Avatar
There is a way(zip ties) to attach a rim/wheel saver to the end of the harbour freight mount/demount bar to prevent scratches....which I have been doing but it sucks. (Look in the links I posted above, several people show how to do it)
I had built a homemade tire changer before and used the crap out of it(Old 14" wheel and all thread.) I use to do it on the ground like Kkims DIY...no thanks kudos to that guy! It's much easier to use the HF not to mention on my back. If you are too cheap to spend a tad over $200 to do pretty much any tire for the rest of your life, thats your deal I know what I'm using! The damn thing pays for itself and can even make you money off it! Plus $200 is only (2) full sets of motorcycle tires installed...screw that!
Now, I just need to decide on a bar. There are still mixed reviews everywhere on the internet on the two.
Oh, harbour freight also sells a tire balancer for $50.00 if anyone doesn't wanna make one. It looks pretty good too.
Last futzed with by Broc; July 8th, 2010 at 07:54 AM.
Old July 8th, 2010, 10:10 AM   #13
HKr1
IC2(SW)
HKr1's Avatar
If you are too cheap to spend a tad over $200 to do pretty much any tire for the rest of your life, thats your deal I know what I'm using! The damn thing pays for itself and can even make you money off it!.
http://www.eagleequip.com/page/EE/PR...rce=GoogleBase
Old July 8th, 2010, 06:48 PM   #14
Broc
Broc's Avatar
haha! I am definitely too cheap for that! Might take a while to pay for itself
Old July 8th, 2010, 07:27 PM   #15
headshrink
headshrink's Avatar
I have the HF bead breaker and tire balancer. They both work. Not the highest quality of course, but they both work.
Old July 9th, 2010, 03:54 AM   #16
Banzai
Psychic war veteran
Banzai's Avatar
May have to look at this again!
Old July 9th, 2010, 03:41 PM   #17
headshrink
headshrink's Avatar
They aren't junk.... I hope that is not how it sounded, they do the job acceptably, without any problems. They are great bargins, and I wouldn't really worry about getting nicer (more $$$) stuff unless I did a LOT of tires.
Old September 22nd, 2010, 10:10 AM   #18
headshrink
headshrink's Avatar
I probably could have added it here, but I started a related post on purchasing the HF changer here: http://www.ninjette.org/forums/showt...719#post216719
Old August 6th, 2012, 10:10 AM   #19
I think I see a problem with all the DIY tire changer guides: The threaded rod sizes they suggest are too thick for our front axles! The No-Scuff Tire Tool guy suggests 3/4" and others I see suggest 5/8 which are both too large for our 15mm front axles:
http://scandalon.com/2009/06/motorcy...iameter-chart/
Am I missing something? Are we supposed to be removing bearings and stuff? 1/2" should fit but I assume that it could mar the bearings. There is too little clearance for a spacer or pipe and anything smaller would probably require the threaded rod to be additionally supported overhead before you start levering against it.
[roadracingworld.com] - Motorsport Products Tire Changing Stand Ninjette Newsbot Motorcycling News 0 April 2nd, 2013 11:40 PM
Tire changing video mrlmd General Motorcycling Discussion 6 January 10th, 2012 03:03 AM
Build this Complete Tire Changing Station g21-30 2008 - 2012 Ninja 250R Tech Talk 17 October 12th, 2011 07:37 AM
Tire Changing video cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 10 October 8th, 2011 10:36 AM
Will changing a tire damage wheel stripes? headshrink 2008 - 2012 Ninja 250R Tech Talk 4 November 27th, 2009 07:21 AM
