#1 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
Question about adjust idle mixture screws
So I have read all of the guides and DIY. But am still kinda confused. I am trying to adjust these to their correct spot. From what I read when you turn the screws in the idle should drop or engine would start to miss. When I do that the idle adjust jumps up. So I am confused as to where I would adjust the screw in and then back out a 1/4 or 1/2 of a turn. Thanks!
#2 |
Read through this section - http://faq.ninja250.org/wiki/Intake.
There's a lot of general carb info that may help you better understand what's doing what. The page with idle mixture adjustment is here - http://faq.ninja250.org/wiki/How_do_...dle_mixture%3F Last futzed with by jkv45; February 28th, 2016 at 03:28 PM. |
#3 | |
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#4 |
so thats what is puzzling, When I turn the screws in the idle go UP not down.
#5 |
Hmmmm, stupid question time,
Is the engine at operating temperature? Are you turning it the right way? Remember it's upside down so you must turn counter clockwise direction? Are all the parts in place, O-rings, and washers? What happens when to bottom the screw out?
#6 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
Is your choke off?
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over ![]() ![]() |
#7 | |
Start at 2.5 turns out. Let the engine get fully warm. Add 1/4 turn out - does it increase or decrease the speed? I like to find the highest idle speed, then go out (richer) by 1/8 to 1/4 turn. Then set the correct idle speed (up or down) with the idle speed screw. |
#8 | |
#9 | |
#10 |
If the bike is track only use, then don't worry about it, anything past 1/4 the pilot circuit isn't doing much, by 1/2 it's not doing anything, it's the mains, and needles job.
Last stupid question, you sure the carburetors are 100% functional? Maybe @ducatiman may have an idea?
#11 |
yeah that's kinda what I was thinking. This bike has a full M4 system, K&N filter KLEEN removed. I went with a Factory Pro 3.0 kit. Using 112 mains 40 pilot and clip in 3rd slot.
#12 |
Then don't worry about getting the idle mixture screws adjusted set to 2 1/2~3 turns out, after all its a track bike, be more concerned about dialing in the mains/needles.
#13 |
#14 |
If you have access to an exhaust gas analyzer then your set, otherwise seek advice from fellow forum racing members, whom should have insight about jetting for track use.
#15 |
SIDENOTE:
I know NewGen carburetors are set-up different from Kawasaki, with two different size needles, and other such changes. Unfortunately that's all I know about NewGen, hopefully someone will clarify the differences between them.
DIY - Accessing and adjusting idle mixture screws | VeX | 2008 - 2012 Ninja 250R Tech Talk | 71 | December 15th, 2017 03:38 AM |
adjusting idle mixture screws | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 9 | September 1st, 2014 10:29 AM |
very quick question on idle mixture screw | RockyCapone | 1986 - 2007 Ninja 250R Tech Talk | 5 | October 15th, 2012 05:52 PM |
Idle Mixture ?'s | nebraskan | 2008 - 2012 Ninja 250R Tech Talk | 31 | April 13th, 2011 08:41 PM |
Idle mixture screw question after jet install... | diablo250 | 2008 - 2012 Ninja 250R Tech Talk | 12 | September 26th, 2010 09:10 AM |
