Old May 7th, 2011, 10:45 PM   #1
setasai
setasai's Avatar
Replacement fairing plastic clips?
Can someone point me to a location I can purchase those annoying little plastic clips that are used to hold the fairings together?
I accidentally stepped on one of the small ones and cracked it in half. Are there alternatives for those things? Like little metal clips that'll hold up better?
Old May 8th, 2011, 04:15 AM   #2
DaBlue1
Long Time Rider
DaBlue1's Avatar
Cycle gear carries some.
http://www.boltmotorcyclehardware.co...678c3333203355
Old May 8th, 2011, 09:55 AM   #3
setasai
setasai's Avatar
Perfect. Thanks!
Old May 9th, 2011, 12:28 PM   #4
CZroe
CZroe's Avatar
I went to Cycle Gear and bought an assortment but only two fit the smaller type and one fit the larget type.
Old May 9th, 2011, 06:01 PM   #5
setasai
setasai's Avatar
How much did it cost and how many extras did it include? It'd be lame if it had like 20 different sizes and only 1 fit. What would I do with the other 19?
Old May 9th, 2011, 07:32 PM   #6
lockie
lockie's Avatar
Motorcycle(s): 2009 blue ninja 250R
You can also try bike bolts.com. The have fairing kits with lots of the little clips and wellnuts. You might find the one you want.
lockie is offline   Reply With Quote
Old May 11th, 2011, 07:05 AM   #7
CZroe
CZroe's Avatar
It was a "Bolt" hardware kit with a bunch of other stuff too (bolts, nuts, etc) on clearance for $5. There were several plastic rivets but only two works as replacements for the four small rivets and only one works as a replacement for the three larger ones, if I recall correctly. I'll take pics when I get home.
Old May 13th, 2011, 02:14 PM   #8
Liquidtoon
Liquidtoon's Avatar
Motorcycle(s): 09 Ninja 250r
Lowes sells them in the nuts and bolts isle there is a section called automotive. cheap to under a buck, and no mail order delay.
Liquidtoon is offline   Reply With Quote
Old May 13th, 2011, 02:16 PM   #9
rockNroll
rockNroll's Avatar
Motorcycle(s): black
exactly which clip did you break?
WTB: Plastic Rivets/Clips for the Fairings Yaozer Items Wanted 7 January 10th, 2013 02:32 PM
replacement fairing ?? ninjaflav 2008 - 2012 Ninja 250R Farkles 2 August 3rd, 2011 03:42 AM
