Go Back   ninjette.org > General > !%@*#$%!)@#&!%@ I crashed!
Old May 4th, 2009, 02:45 PM   #1
ARF07
ARF07's Avatar
Motorcycle(s): Yamaha R6
Dropped my bike today
Pretty upset as I'm sure you can call imagine. I'm just not sure what I did wrong. I was coming to a stop, shifting down then when I was almost at a complete stop over it went and I couldn't stop it. The only thing I can think of is that I used the front break instead of the rear...I'm still a total newbie, so any suggestions as to what I can do to avoid this next time, or what I might have done wrong?? Oh, and one last question..when it went over, I saw some liquid come out of the bottom. What was that and do I need to check any levels? Thanks in advance
On the plus side, that even though it hit the street, there wasn't a single scratch on the fairings...A small one on the shifter peg, but thats it...
ARF07 is offline   Reply With Quote
Old May 4th, 2009, 02:48 PM   #2
zail
zail's Avatar
Motorcycle(s): 08 Ninja 250r
Know how you feel - dropped mine yesterday doing a u-turn in a car park... only mark is on my gear shift and on the crash protector... not sure about the liquid - mine didn't leak anything... main thing is you and the bike are both ok
zail is offline   Reply With Quote
Old May 4th, 2009, 02:52 PM   #3
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Sorry to hear about the drop Nathan. Are you ok aside from the injury to your pride?
Old May 4th, 2009, 02:56 PM   #4
ARF07
ARF07's Avatar
Thanks Kim, yea I'm ok. I didn't fall off the bike, I kinda came off it/tried to hold it up as it was going down..Zail: glad you ride is ok too!..At first I was really mad, then I saw the liquid spill and was like uuuhh wtf?? so hopefully that was nothing
Old May 4th, 2009, 03:35 PM   #5
Snake
Snake's Avatar
Sorry to hear that Nathan. If you had the handle bar turned as you applied the front brake that could have made you go down. Yes be sure and check the fluids to be sure all is well.
Old May 4th, 2009, 03:38 PM   #6
liquid was most likely coolant. check the level in the coolant reservoir on the right side of the bike.
Old May 4th, 2009, 03:50 PM   #7
ARF07
ARF07's Avatar
Cool, thanks Kelly. I'll go check now...Rick that may have been it because I was about to turn. This might be OT but what speed should I stop using front break and start using rear brake? Idk if that would have made a difference here or not.
Old May 4th, 2009, 03:53 PM   #8
when traveling in a straight line, I always use both. The front a bit harder than the rear to avoid the rear tire from sliding. apply smoothly and progressively.
Old May 4th, 2009, 04:03 PM   #9
ARF07
ARF07's Avatar
ok thanks. So I just checked what I hope is the correct fluids lol. I've been around bikes for a grand total of about 3 months of my life, so I'm about to sound totally retarded. Pls fill me in on the correct terminology. On the right side of the bike middle/bottom, there is a clear circle for checking some kind of fluid levels. That looks pretty empty. Brake fluid levels are in between high and low. Suggestions?
Old May 4th, 2009, 04:24 PM   #10
Apex
Livin' the Minimoto Life
Apex's Avatar
I use both brakes all the time, unless I'm in the middle of a turn. I trail brake a lot, even on the street. Whatever you do, do not try to trailbrake into a turn. You still need to hone your feel of the bike. Trail braking is a bit more advanced.
You just have to get the feel for the lever. After a while you don't even think about it anymore, and you just know (for the most part) how much brake to give it. I normally use both brakes unless, like I said, I'm trail braking.
Old May 4th, 2009, 04:31 PM   #11
Nickds7
Nickds7's Avatar
As someone else suggested, if you had a lean or you were turning at the point of stopping, the bikes weight will all go in that direction. Take the motorcycle safety foundation course, they will teach you a ton about that, and hopefully prevent a future drop.
Nickds7 is offline   Reply With Quote
Old May 4th, 2009, 04:33 PM   #12
ARF07
ARF07's Avatar
I did take the MSF course. They must have skipped the "Don't drop your bike at stop signs" part
Old May 4th, 2009, 04:56 PM   #13
noche_caliente
Nathan, you're referring to the oil sight glass, and it will look empty on the side stand - you need the get the bike upright to check the oil level - good luck
Old May 4th, 2009, 05:04 PM   #14
how to check the fluid levels is in your owner's manual. I suggest you read it thoroughly as I think you are looking at the oil level sight glass. coolant tank is under your right fairing.
Old May 4th, 2009, 05:05 PM   #15
Strider
Back on the Black!
Strider's Avatar
Motorcycle(s): 2006 Kawasaki Ninja EX250 (Black)
Ouch, any drop is a bad drop, but at least you weren't hurt!
Strider is offline   Reply With Quote
Old May 4th, 2009, 05:08 PM   #16
ARF07
ARF07's Avatar
Thanks Kim! I just did a search for coolant levels and found Old Guys thread about it, I'll go try to find it soon..Thanks for all the help
Old May 4th, 2009, 05:36 PM   #17
jonb08
jonb08's Avatar
Motorcycle(s): 2007 EX250
Did you check to see if there was gravel or oil in the road where you were stopping? Maybe that liquid you saw was already there? Glad your good. Doesn't just happen to newbies. If your not paying attention, it could happen to anyone.
jonb08 is offline   Reply With Quote
Old May 4th, 2009, 05:54 PM   #18
BlueRaven
BlueRaven's Avatar
Motorcycle(s): '09 Ninja 250 Black
I remember the trainer yelling don't ever try to stop while you are turning. If you are turning, straighten the bike first then brake. If you are stopping, stop straight then when you start off again then you can turn. It's engraved in my brain from practicing during the course. They would not let you go to the next challenge unless you could do the task correctly.
BlueRaven is offline   Reply With Quote
Old May 4th, 2009, 06:02 PM   #19
ARF07
ARF07's Avatar
Jon, there was gravel+it had just rained. idk if that contributed or not.. I wasn't turning when it happened, but there is always the possibility that I anticipated the turn after the stop sign and began to turn my handlebars, I don't really remember though. The fluid looked like the coolant in the bike, so I'll take the fairing off tomorrow and refill it
Old May 4th, 2009, 06:03 PM   #20
BlueRaven
BlueRaven's Avatar
don't feel bad about the drop, i dropped mine 5 min after it was delivered just trying to move it in the garage and i wasn't even sitting on it.
Old May 4th, 2009, 06:11 PM   #21
sm0kediver
one disaster at a time
sm0kediver's Avatar
Motorcycle(s): EX250J9
Sorry to hear that Nathan. I think more riders have problems with slow speed maneuvers than anything else. You looked pretty competent on that thing Sunday.
I had some business near Rockmart this evening, and found some really good twisty roads out there. I'll text you next time I head that way.
sm0kediver is offline   Reply With Quote
Old May 4th, 2009, 06:16 PM   #22
ARF07
ARF07's Avatar
Thanks BlueRaven, this is actually my second drop. I dropped it getting it off the pickup truck but it was in our back yard so the grass kept it from getting hurt..Looking forward to riding again Jody, just lemme know when.
Old May 4th, 2009, 07:27 PM   #23
TrueFaith
TrueFaith's Avatar
Motorcycle(s): 2011 Honda CBR250R
Don't let it scare you away from using the front brake. It's still your best friend in most situations and the possibility of "flipping" your bike using it is pretty remote. In fact you're much more likely to lowside if you start favoring the rear. I doubt the drop really had much to do with which brake you were using and had more to do with the angle of the bike.
TrueFaith is offline   Reply With Quote
Old May 4th, 2009, 10:30 PM   #24
thsadmin
1986 GPZ Ninjette
thsadmin's Avatar
Motorcycle(s): 1986 GPZ Ninja
DoH !! It happens easily, I dropped mine the other day whilst pushing it up a small step - it got up and then back down - I am skinny and not that strong - as soon as the bike rolled back I lost my footing and nearly tripped ... and bike dropped.
Then this morning I was testing my oil leak fix ... ran low/out of oil (as the fix didn't work) - so I had to walk up a steep hill to get home ... my legs were starting to ache and I didn't want to stop (knowing that if I did I wouldn't get going again) ... by the time I got to the top of the hill I was exhausted and the bike felt so damn heavy - I felt it starting to lean and I used the rest of my energy to hold it str8 and correct the lean ... so close to dropping again.
So yeah it happens ...
thsadmin is offline   Reply With Quote
Old May 5th, 2009, 05:07 AM   #25
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Good thing you're OK. Did you remember to put your feet down after you stopped? That could make you fall over (don't ask how I know).
Old May 5th, 2009, 07:25 AM   #26
Cali619
Giggity Giggity
Cali619's Avatar
Motorcycle(s): 08 ninja 250R aka Hiryu
Nathan if you want a copy of twist of the wrist(I have 1 and 2) shoot me a PM. It is easy reading and can give you things to try as you get more experience.
Facebook DY Fender chop, Danmoto CB slip-on w/baffle, Airbox removed, Kleen-air removed, shimmed needles, Mikuni #117.5 Main jets, K&N RU-1822 air filter pods
Cali619 is offline   Reply With Quote
Old May 5th, 2009, 07:27 AM   #27
OldGuy
Live Life
OldGuy's Avatar
Motorcycle(s): 2009 Green SE Ninja 250
Careful Nathan my thread was for the pregens and there are differences on the coolant reservoir between the two generations. Concept is the same but . . .
Glad you are OK. It really sucks when you drop it but a) you are OK and b) no major damage. Now just figure out what happened for sure so you don't do it again.
One thought for you - on my road bicycle my couple of fails at stops (I use clip in shoes) were caused because I had a weight shift away from the foot that I had put down. All most impossible to recover from that. I've gotten very comfortable with low speed riding and don't put a foot down until the very end BUT, I put both feet down and keep them down until I move. That way I don't have to worry about a weight shift.
- ATGATT -
Scorpion EX700 Hi-Vis Helmet, First Gear MeshTek 3.0 Jacket, TourMaster Transition 2 Jacket and Flex Pants, Sidi Doha boots
OldGuy is offline   Reply With Quote
Old May 5th, 2009, 09:16 PM   #28
CodE-E
Ninja Newbie
CodE-E's Avatar
Motorcycle(s): EX250K9
I dropped mine a bit over a week ago when I tried to lift the rear wheel with a mount to clean the bike's chain. I've never lifted the rear with a mount before, and the mount I bought is a cheap generic PoS mount which doesn't make the job particularly easy or safe. Well, I somehow lost balance and made my bike tip over. It fell on its right side on a sidewalk, and the plastic body got quite a big crack.
That's why it's still in the workshop. I hope it'll be fixed in the next few days.
Regarding stopping, turning, and breaking: some very light, controlled breaking while cornering can be okay, but when coming to a stop, go off the brakes, straighten the bike, and then brake to a stop. Also, when I come to a stop before a tight corner, I always keep the wheel straight, even if I want to make a turn, just to slowly roll forward to check for traffic. Only when it's clear, do I start turning the handlebar and take off. I nearly dropped my Ninja twice in the first week by trying to go through corners where I might need to yield in a smooth motion like with a car.
CodE-E is offline   Reply With Quote
Old May 6th, 2009, 10:32 AM   #29
Apex
Apex's Avatar
My retarded drop was coming to a stop just after it stopped raining. I was on a back road and slowed for a stop sign. I stopped, and proceeded to put my right foot in oil slick that was in the center of the lane. I tried to hold my footing, but the sick removed all traction and the bike fell on its side. I laughed and looked around. Lucky nobody was there to witness this. lol
I learned to watch for the slick after that, never did it again!
Glad all is well though. First things always first: a bike can be repaired or replaced, you can't. Just glad you're ok.
Old May 6th, 2009, 01:11 PM   #30
CC Cowboy
CC Cowboy's Avatar
I've done that at toll booths. Be careful, the amount of oil and grease adds up and when you pull in on a bike you put your feet right in it.
If you do fall over at a toll booth, look for change.
Last futzed with by CC Cowboy; May 6th, 2009 at 05:13 PM.
Old May 6th, 2009, 02:42 PM   #31
sm0kediver
sm0kediver's Avatar
Originally Posted by CC Cowboy View Post
I you do fall over at a toll booth, look for change.
Old May 6th, 2009, 02:53 PM   #32
Apex
Apex's Avatar
Might as well try to get something to help cushion the misfortune.
Old May 6th, 2009, 03:33 PM   #33
tjkamper
tjkamper's Avatar
In MSF They told me to always keep my bars straight. If you have you bars turned it just pull the bike down when you use the front brake.
dealership dropped a $900 bomb on me today newtobikes 2008 - 2012 Ninja 250R Tech Talk 39 August 26th, 2014 08:40 AM
Dropped it today :P KawiKid860 !%@*#$%!)@#&!%@ I crashed! 20 August 1st, 2011 05:48 PM
I did it.. dropped my Ninja at 0 MPH today.. grrrr Rosie !%@*#$%!)@#&!%@ I crashed! 33 August 25th, 2010 06:24 AM
Dropped my bike today! :( Majik !%@*#$%!)@#&!%@ I crashed! 64 December 23rd, 2009 04:12 PM
Dropped Bike Need Help! NewNinja !%@*#$%!)@#&!%@ I crashed! 7 March 16th, 2009 07:50 AM
