April 21st, 2016, 09:10 AM | #1 |
Fork seal driver: what size?
Anyone know what size we need for the 08-12?
I'm buying one for my other bike (CBR500r = 41mm), & want to know if it will work for both, or if I should get a universal seal driver.
May 5th, 2016, 05:30 PM | #2 |
Fogwalker
Join Date: Mar 2015 Motorcycle(s): '09 Ninja 250 "Matilda" Posts: 124
Have you considered using a piece of PVC pipe to drive the seals with? It's what I use. An 18" length of 37mm (1.5") ID pipe works fine for both gens of the Ninja 250. Picture attached as I just did the seals on mine...
You'll need something a little bigger for the Honda seals. 1.614" inner diameter. Luck, J~
Take care of new riders, for we were them, and they will be us. Y. Hong 2004 |
May 5th, 2016, 10:54 PM | #3 | |
Thanks for the tip.
May 5th, 2016, 11:44 PM | #4 |
Schönen Tag noch
Join Date: Sep 2013 Motorcycle(s): 08 ninja 250 race bike, 02 gixxer 600 telefonica Posts: 184
+2 pvc pipe is the way to go.
May 6th, 2016, 06:45 AM | #5 |
Vintage Screwball
MOTM - Mar '16
For one of my other bikes, I actually found that the plastic extension tube for my shop vac was the perfect size.
Have a look around your garage/shop, you probably already have something that will work.
Goin' fast on slow bikes! |
May 19th, 2016, 08:15 AM | #6 |
Hello Moto
Join Date: Mar 2013 Motorcycle(s): 1975 RD350; 2001 KX125; 2003 Z1000; 2003 KDX50; 2009 ZX6R; 2011 Ninja 250R; 2014 KX250F Posts: 352
I have a few pieces of PVC around the shop for different fork sizes. I thought about buying a universal fork seal driver but why spend the money when I already have a functioning method.
May 23rd, 2016, 10:00 PM | #7 |
Name: Red Snapper XXX
Join Date: Nov 2013 Motorcycle(s): Ninja 250R 2009 Posts: 39
Tip
There is a big washer that needs to go down fist. Make sure it's down correct, BEFORE using the fork driver.
You don't need a l lot of force for the driver. My friend didn't seat the washer right, and starting using tons of force with fork driver, still he could not put on the metal clip. He took the fork seal out, and saw the washer was not on right. |
May 25th, 2016, 04:20 PM | #8 | |
Leak on right fork seal | AmyF | 1986 - 2007 Ninja 250R Tech Talk | 17 | July 11th, 2014 09:29 AM |
Fork seal size? Pyramid parts | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 3 | March 6th, 2014 05:41 PM |
Fork Seal Size Clarification | cokatominnesota | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 6th, 2013 06:01 PM |
OEM Brand New Fork Oil Seal, Dust Seal (08-12) | capriccio | Motorcycle-related | 3 | June 9th, 2013 05:11 AM |
Fork Seal Leaking | broken neck | 2008 - 2012 Ninja 250R Tech Talk | 16 | June 2nd, 2013 11:40 AM |
