December 16th, 2020, 10:24 AM | #1 |
New rider
Join Date: Nov 2020 Motorcycle(s): 2021 Ninja 400 (abs), 2004 NinjaEx (2007 motor) Posts: 40
Exhaust Dual or Single?
Hi good morning everybody, I have a question regarding the exhaust on my bike. I have a dual pipe and was curious if it was better to eliminate one of them for an aftermarket exhaust or just go with two, will power be taken away or maybe forced through that one pipe and create more power? Thank you ahead of time. My humble mind wants to say two is better than one, I dunno.
December 16th, 2020, 11:14 AM | #2 |
Hi Anthony! There's roughly TWO types of exhausts for these bikes with different results:
2-2 exhaust - stock pre-gen, tends to favour high-end flow and power, gutless down low 2-1 exhaust- stock new-gen, favours low-end/mid-range flow and torque, not as much high-end HP In order to buid either one of these, pipe-diameters, lengths and other physical properties must be optimized from beginning. You simply cannot convert from one to other. It must be built with one or other design in mind when tubing is selected. If you compare new-gen 2-1 exhaust, you'll notice that pipe-size after 2-1 merge is significantly larger than 2-2 exhaust. And muffler needs to be twice as big as well to flow twice as much exhaust. For pre-gen, which has reputation for being high-RPM screamer with not much down low, it's best to get 2-1 exhaust for low-end/mid-range improvement. Much, much more useful for daily-driving. I've got some photos and measurements comparing them here: an Exhausting Tale!!! Area-P's 2-1 pre-gen exhaust and development process: Official Area-P Pre-08 Ninja 250 Exhaust Thread |
Does Ninja 250 have dual or single throttle cable? | caineroad | 2008 - 2012 Ninja 250R Tech Talk | 2 | September 21st, 2013 11:02 AM |
Single Exhaust Header | Shintoxica | 1986 - 2007 Ninja 250R Farkles | 5 | September 12th, 2013 05:56 AM |
Dual exhaust for ninjette | psych0hans | 2008 - 2012 Ninja 250R Tech Talk | 21 | February 23rd, 2012 01:20 AM |
2 into 2 exhaust... traditional dual, or both on same side? | JMcDonald | 2008 - 2012 Ninja 250R Farkles | 32 | August 17th, 2011 02:41 PM |
Whose bike is this? Single-sided swingarm, dual discs, Ducati-tail, etc. | CZroe | General Motorcycling Discussion | 21 | June 26th, 2011 01:11 AM |
