Old May 28th, 2012, 02:18 PM   #1
Countersteer
Countersteer's Avatar
Motorcycle(s): <2008 250R> Past Bikes:06 GSXR600 89 CBR1000 78 Hawk 400 86 Ninja 600R 86 & 87 FZ600 81 GPZ550 71 CB360T
Carb Question
Does anyone know what the functionality of the four highlighted holes are? I just finished installing a SixSigma jet kit and noticed these, but have no idea what they do. Thanks!
Have you ever read the King James Bible?
To say speed kills is akin to saying guns kill, neither of which is true.
Countersteer is offline   Reply With Quote
Old May 28th, 2012, 02:39 PM   #2
Those are idle holes.
When the throttle valve or butterfly plate is close to or completely closed, some air by-passes it via these little passages cast into the carb's body to feed the idle system.
Old May 28th, 2012, 03:22 PM   #3
Countersteer
Do you know where the holes lead to? There is a brass plug on the opposite side of the holes.
Old May 28th, 2012, 04:49 PM   #4
The brass plug is to close the passage after a long drill opens it.
Using that trick, the manufacturer can achieve bends or U-shapes just using drills.
The holes lead to the mixture screw, where air (induced by strong vacuum) from them plus fuel from the pilot jet mix to feed the engine at idle rpm's and some rpm's above those.
Old May 28th, 2012, 06:13 PM   #5
Countersteer
Thanks, Hernan! I appreciate the info!
Old May 28th, 2012, 06:41 PM   #6
You are welcome, Eric.
I was working on your area three weeks ago, staying in Spanish Fort.
Here you can learn more about carburetors, if you are interested:
http://www.dansmc.com/carbs2.htm
Old May 28th, 2012, 07:10 PM   #7
Countersteer
Really; what kind of work do you do?
Cool link!
Old May 29th, 2012, 05:36 AM   #8
PM sent
carb question Bob2010 2008 - 2012 Ninja 250R Tech Talk 9 April 15th, 2014 10:00 PM
Carb Question Scotty878 1986 - 2007 Ninja 250R Tech Talk 4 July 12th, 2013 09:56 PM
Carb question drstimpy 1986 - 2007 Ninja 250R Tech Talk 9 March 25th, 2010 02:55 PM
Carb question sombo 1986 - 2007 Ninja 250R Tech Talk 6 March 22nd, 2010 09:27 PM
Another carb question diablo250 2008 - 2012 Ninja 250R Tech Talk 3 June 22nd, 2009 11:13 AM
