Old August 13th, 2016, 12:47 PM   #81
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Looking good maaaaan
Old August 13th, 2016, 01:23 PM   #82
UFOmoplata
UFOmoplata's Avatar
Motorcycle(s): 2007 Hoodrat 250
Read that in The Dudes voice.
"Brah, you can't be looking like that on a 250, brah. You gotta mod a 250, brah. It's like the hachi-roku of bikes."
UFOmoplata is offline   Reply With Quote
Old August 13th, 2016, 01:38 PM   #83
JohnnyBravo
Naturally
Old August 14th, 2016, 09:34 AM   #84
UFOmoplata
UFOmoplata's Avatar
First start attempt after @ducatiman service.
Still not quite right. Dead on throttle, Erratic idle, High idle, etc.
Probably need to mess with the insides again.
Old August 15th, 2016, 02:05 PM   #85
JohnnyBravo
Something ain't right
Old August 18th, 2016, 07:00 PM   #86
UFOmoplata
UFOmoplata's Avatar
Flush mounts on.
Free tank pad. Looks pretty tacky. On the fence about keeping it on.
Having some sort of starting issue now. Probably just the battery is low.
Old August 18th, 2016, 07:11 PM   #87
JohnnyBravo
Charge the thing maaaan... Had to do mine the other day
Old September 25th, 2016, 04:55 PM   #88
UFOmoplata
UFOmoplata's Avatar
God I'm so lazy. Haven't done crap with this thing. Cleaned the carbs again. Tuning this is getting annoying. At least the turn signals/all lights work now. Only thing left is getting it to run correctly, and mounting up the mirrors.
I have the bar-end mirrors that mount inside the bars instead of clamping on. The inner diameter of the bars are too narrow, so I will need to bore them out some.
Old October 23rd, 2016, 06:03 PM   #89
I saw your sale post leading to this thread. A few questions for you. I tried reading the whole thread but missed a few things:
You have a J engine in the F bike. Are you using Pregen mounts and radiator or newgen mounts and radiator? I saw you used the pregen water pipe into the head of the newgen engine.
Do you still have the 2007 engine? You said it ran before it was taken out? Do all the connectors from the newgen engine work with the pregen wiring harness or is there obvious modification/repinning? I'm weighing my options...
Old October 24th, 2016, 07:41 AM   #90
UFOmoplata
UFOmoplata's Avatar
Using Pregen mounts/radiator on Newgen engine.
I still have the F engine. I'm assuming the connectors do swap over, though I've not done the swap myself.
Old March 3rd, 2017, 07:37 AM   #91
UFOmoplata
UFOmoplata's Avatar
Update:
Might be picking up a maintained and clean 2005 from Arizona for 1500~1700, and swapping over some stuff from the frankenbike. At least then, I'll have a running platform to begin with.
Old March 22nd, 2017, 05:35 AM   #92
UFOmoplata
UFOmoplata's Avatar
Attached the Danmoto slip-on. Man, this thing is LIGHT! Fitment is snug. So far, so good.
Leaned the bike on the kickstand and found an oil leak coming from the....side of the crankcase? Whatever that plastic side cover is:
Old March 22nd, 2017, 05:59 AM   #93
JohnnyBravo
I like starting with something that runs; I've started plenty of projects with broken stuff, they are more rewarding if they don't frustrate you too bad.
stock ex250 wiring harness ghetto rigged? cream 1986 - 2007 Ninja 250R Tech Talk 7 March 24th, 2015 11:25 PM
CERTIFIED!! 7oxSin Riding Skills 11 November 12th, 2013 11:30 AM
Ghetto girl joins the gang! goobsmiracle New Members 25 February 10th, 2013 05:22 PM
Ideas on my cheapo ghetto tank bag? papawhellie Motorcycle Gear 4 November 4th, 2012 09:24 AM
Ghetto Digital Dashboard / GPS Project patw General Motorcycling Discussion 23 June 14th, 2010 02:26 PM
