Old July 28th, 2013, 07:49 PM   #1
anacron
anacron's Avatar
Motorcycle(s): Triumph Street Triple R
Please tell me this isn't a brake fluid leak
I have no idea where that stuff came from. I checked the pipe running to the caliper and its completely clean.
Everything else looks clean except what you see.
Here's my Youtube Channel.
Here's my Flickr Photostream.
anacron is offline   Reply With Quote
Old July 28th, 2013, 07:59 PM   #2
MNDruggist
MNDruggist's Avatar
Motorcycle(s): 2013 Ninja 300 Ebony
It looks like brake fluid to me. It might be coming out of the master brake cylinder and running down your brake lines to the low spot pictured. Crush washers can fail if the banjo bolt above the brake cylinder is over-tightened. The bad news is that brake fluid spills should be wiped up right away, it can eat through your paint very easily. If your under warrantee, have it dealer inspected so your bake will be fixed and also future paint or swingarm replacement should be covered due to the defect.
Unregistered's village called.......Their idiot is missing.
MNDruggist is offline   Reply With Quote
Old July 28th, 2013, 08:13 PM   #3
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
can we get a close up of caliper? doesn't look like brake fluid, but hard to tell. looks kinda greasy...
Old July 28th, 2013, 08:15 PM   #4
anacron
anacron's Avatar
Yup absolutely. It felt greasy when I touched it and wasn't a clear-yellowish color as the brake fluid looks in the reservoir.
I'll post one in a couple of minutes.
Old July 28th, 2013, 08:18 PM   #5
Bentley813
Bentley813's Avatar
Motorcycle(s): 2013 White 300
Looks like grease to me.
Bentley813 is offline   Reply With Quote
Old July 28th, 2013, 08:46 PM   #6
anacron
anacron's Avatar
Its dark and my camera flash is terrible.
Smells like grease to me. I did a thorough pat down of the brake reservoir pipe - didn't feel wet spots.
The exterior of the pipe just above the suspected leak was spotless. I'll keep a close eye over the next few rides to see if its a serious problem.
Edit: Time to give it a bath...
Old July 28th, 2013, 08:50 PM   #7
it looks like ****
Old July 28th, 2013, 09:23 PM   #8
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
This is not the fluid of the brakes
Old July 28th, 2013, 09:24 PM   #9
Smile
it looks like ****
May it be that a bird visited your bike today?
Old July 28th, 2013, 09:42 PM   #10
anacron
anacron's Avatar
Awesome!! Would have felt pretty down if it was a brake leak.
Especially with all of my recent "ZOMG I'm getting good at riding and treating the bike well" posts.
Thanks for the input people.
Old July 28th, 2013, 09:43 PM   #11
anacron
anacron's Avatar
Quite possible. I did park outside today while doing some shopping. Must have been one greasy **** that the bird took...
Old July 28th, 2013, 09:46 PM   #12
JohnnyBravo
Lots of funky things land different places on your bike, make sure ya ain't got a visible leak, clean it off, ride it some more... If it keeps doing the same thing it's a problem. if its a random bird turd, or road grime your good!
Old July 28th, 2013, 09:48 PM   #13
If the bike was on the side stand, how could the staff flow up on the top face of the swingarm without some help "from above"?
Old July 28th, 2013, 09:51 PM   #14
anacron
anacron's Avatar
Absolutely agree! I got worried in the first place because it was such a strange location and the closest thing was the brake pipe.
BTW is brake pipe the technical term?
Old July 28th, 2013, 10:16 PM   #15
deeno415
deeno415's Avatar
Motorcycle(s): 2006 Kawasaki EX250(Bright Yellow)
^^I believe you are referring to the 'rear brake line'...^^
deeno415 is offline   Reply With Quote
Old July 29th, 2013, 07:26 AM   #16
It is a hydraulic hose.
"Hydraulic hose is graded by pressure, temperature, and fluid compatibility. Hoses are used when pipes or tubes can not be used, usually to provide flexibility for machine operation or maintenance. The hose is built up with rubber and steel layers. A rubber interior is surrounded by multiple layers of woven wire and rubber. The exterior is designed for abrasion resistance...............Hydraulic hoses generally have steel fittings swaged on the ends. The weakest part of the high pressure hose is the connection of the hose to the fitting. Another disadvantage of hoses is the shorter life of rubber which requires periodic replacement, usually at five to seven year intervals."
http://en.wikipedia.org/wiki/Hydraul...ipes_and_hoses
http://en.wikipedia.org/wiki/Brake_bleeding
http://en.wikipedia.org/wiki/Brake_fluid
It is commonly called brake line or brake hose.
Yours is extra protected by a rubber hose (the surface that you see).
The real brake hose can be seen at the end, where it connects to the metal fitting.
Old July 29th, 2013, 08:51 AM   #17
anacron
anacron's Avatar
Thanks! very informative.
Old July 29th, 2013, 09:53 AM   #18
If it was brake fluid it would most likely take the paint off when you removed it.
If you thought it was brake fluid, the first thing you would check is the fluid level in the rear mastercylinder. If it was leaking it would let air into the system and the petal would feel soft, but might change when you pumped it repeatedly.
If it didn't take the paint off, the lever feels right, and the level in the mastercylinder isn't low - it's not brake fluid.
Old July 29th, 2013, 11:08 AM   #19
JohnnyBravo
now ya know, and knowing is half the battle.
Where in the world is Carmen sandiego when ya have a mystery???
Old July 29th, 2013, 11:42 AM   #20
anacron
anacron's Avatar
yup, now I know. Thanks all.
Old July 29th, 2013, 12:28 PM   #21
Asspire
Asspire's Avatar
did it taste like grease????
Old July 29th, 2013, 02:34 PM   #22
JohnnyBravo
Asspire ate what?
Old July 29th, 2013, 02:50 PM   #23
anacron
anacron's Avatar
Did I eat what I suspected to be brake fluid?
Nope.
Fluid Leak After Drop tony7kp 2008 - 2012 Ninja 250R Tech Talk 7 December 31st, 2013 01:00 PM
2010 Ninja 250r Brake fluid bleed/Replacement and brake caliper cleaning RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 1 May 30th, 2013 08:13 PM
Replacing brake pads and brake fluid Bones85 2008 - 2012 Ninja 250R Tech Talk 4 April 28th, 2013 06:25 PM
Rear brake fluid leak (container leak?), any advice appreciated. deaddemon 2008 - 2012 Ninja 250R Tech Talk 5 November 6th, 2011 01:52 PM
Brake Fluid? ASecretNinja 1986 - 2007 Ninja 250R Tech Talk 4 January 20th, 2010 03:02 PM
