Old September 12th, 2012, 09:08 PM   #1
cuong-nutz
cuong-nutz's Avatar
how much weight do you use to balance your wheel/tire?
This the is second time having to use about one full ounce to balance my front wheel and tire. I found it kind of odd to have to use so much.
The stock IRC front tire only used a 1/4 oz and when I switched to a 110 BT-16 I needed a full oz. Then just recently when I switched to a 120 BT-16, I needed a full oz again to balance it. I wonder if it's related to the BT-16 tire or my wheel is just that off? I don't think all my low sides would have caused my wheel to go out of round.
Any other ideas?
HalfFast Racing Team
Old September 13th, 2012, 04:12 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I will use up to one oz. Then after that I would need two weights. So I try to spin the tire on the rim . Some times it helps and sometimes not . But an ounce is OK I some times use 2-3 ounces on car tires.
Worlds fastest 250 ninja
Old September 13th, 2012, 04:43 AM   #3
broken neck
Motorcycle(s): 2011 Ninja 250R Special Edition (sold), 2017 CRF250 Rally
Have you put the tire correctly on the rim?
I don't know for motorcycle, but with automobile tires, they mark the place where the tire should align with the valve on the rim.
Maybe the same thing applies to motorcycle tires. It could help reduce weight needed to balance them.
My two cents
broken neck is offline   Reply With Quote
Old September 13th, 2012, 04:58 AM   #4
Yes, Cuong, the dot on the motorcycle tire always indicates the lightest spot.
You should balance the naked wheel first and find the heaviest spot (not adding weights, just marking the heaviest spot with a marker).
Then, you align the tire spot and the mark of your wheel.
No, your tire is not out of round as to need counter weights.
In that case, you would be jumping at each turn of the wheel.
Old September 13th, 2012, 05:14 AM   #5
cuong-nutz
cuong-nutz's Avatar
Yeah, I'll have to remember to check the balance of the wheel first before mounting the tire.
Old September 13th, 2012, 07:12 AM   #6
The heaviest spot of the wheel is supposed to be by the air valve, but after checking several wheels, I have found that not being true in every case.
The disk in the front wheel and the sprocket in the rear one may introduce their own heaviest point, which combines with the heaviest spot of the wheel.
Old September 13th, 2012, 07:40 AM   #7
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
yea but on the pirelli rosso II the dot is right on the belt so im pretty sure that's the heavy spot of the tire PLS correct me if im wrong
THE GOOD LIFE
cuz is offline   Reply With Quote
weight of new gen 250 rear wheel? genosr1 Ninjettes At Speed 3 December 8th, 2013 05:53 PM
Wheel Balance Product - Dyna beads lancer3vo 2008 - 2012 Ninja 250R Tech Talk 6 June 11th, 2012 08:59 AM
[sportrider - latest stories] - No-Mar Reusable Spoke-Mounted Wheel Weight Kit Ninjette Newsbot Motorcycling News 0 April 16th, 2012 02:50 PM
Wheel weight came off.. KawiKid860 General Motorcycling Discussion 2 November 16th, 2011 12:54 AM
No Tire Balance - How Bad? gfloyd2002 2008 - 2012 Ninja 250R Tech Talk 14 October 8th, 2011 11:19 PM
