July 31st, 2014, 02:13 PM | #1 |
Join Date: Mar 2014 Motorcycle(s): 04 ninja 250, 2010 klx 250sf, 86 gsxr 750 Posts: 21
Just installed new gen rear wheel, brake problem?
I shaved the rear caliper hanger the oft-cited 13mm and for the most part all slots in like one would hope, BUT when spinning the wheel on the stand I can just see the caliper move a little back and forth, the axle adjusters are even enough and everything SEEMS unwarped, so would brake pads and their seating be the sensible culprit?
Side note, I didn't have to change the torque arm at all, just left it unattached and loose, tightened the axle etc then the slop afforded by the loose nuts let me get it in place, the rotor rubbing happens regardless of the torque arm being connected or not. |
July 31st, 2014, 04:53 PM | #2 |
MOTM - Sep '18, Feb '16
Pictures would help. But it sounds like the rotor is amped if the caliper is moving.
July 31st, 2014, 06:03 PM | #3 |
The variance is too small for me to find and take a photo at the same time so I'm not entirely sure what to photo. |
August 2nd, 2014, 04:56 PM | #4 |
Laterally?
August 2nd, 2014, 06:36 PM | #5 |
August 2nd, 2014, 08:21 PM | #6 |
Then, your brake disc may be warped.
You can check it against a lateral fix point of reference. Please, read this: http://www.atlprorepair.com/services...disk-breaks-3/
August 2nd, 2014, 09:26 PM | #7 |
For the record a warped disc was my first thought when noticing a braking component move unusually, after googling whichever words seemed to sum up my issues pads often came up as the culprit, as the rotor didn't scream I'm warped (beyond the more obvious caliper lateral movement) I thought it best to ask, esp as the pads have been used on a 16 wheel all their life and not a 17 ( seems to leave a few mm of pad surface unused against the rotor)
Another issue is it seams a new newgen rotor costs nearly as much as a 500 wheel, and supposedly the 500 wheel slots in with not too much (2mm?) work. What would you do figuring you have a spare caliper hanger? ( I do) Order a new china rotor, new OEM ($$$) rotor, used (rotor) or a 500 wheel with a 500 rotor? Bonus round, could a slightly unsquare spacer cause a wobble? as far as my mind can figure it would just make things crooked as long as the spacer isn't rotating, at which point it would be a bearing right? <- trying to eliminate the modified caliper hanger from the problem equation. |
Rear Brake Problem | RandomPhantom | 2008 - 2012 Ninja 250R Tech Talk | 11 | July 11th, 2014 05:10 AM |
weight of new gen 250 rear wheel? | genosr1 | Ninjettes At Speed | 3 | December 8th, 2013 05:53 PM |
08+ rear wheel, right rear set, rear brake system, seat | cuong-nutz | Items Wanted | 2 | October 6th, 2013 05:37 PM |
Stock rear wheel, gauge cluster, windscreen, new gen parts FS | jman511115 | Motorcycle-related | 15 | November 13th, 2012 03:50 PM |
new gen rear wheel | eddiekay | Free stuff! | 6 | April 10th, 2012 11:21 PM |
