March 9th, 2014, 11:50 AM | #1 |
[motorcycle.com] - 2014 Harley-Davidson Low Rider Review
2014 Harley-Davidson Low Rider Editor Score: 84.25%Engine 18.25/20Suspension/Handling 12.5/15 Transmission/Clutch 8.5/10Brakes 8.25/10 Instruments/Controls4/5 Ergonomics/Comfort 9/10 Appearance/Quality 9/10Desirability 9/10Value 8/10Overall Score86.5/100When introducing a new motorcycle, many manufacturers lead off with all the technical marvels they’ve packed into their latest offering. Harley-Davidson often begins with talk of the style of its new motorcycle and how it ties to the company’s history. Being the single largest motorcycle manufacturer in the world certainly says something about the success of the motor company’s development model. So, when the representatives at a Harley new model press briefing mention styling first, it should come as no surprise. Reintroducing a model that was first released in 1977 (at Daytona Bike Week, no less) after it has been on a five year hiatus, Harley naturally calls upon the bike’s past heritage (by, maybe, introducing it at Bike Week) before outlining how it’s been modernized with a more powerful engine and a refined chassis. In the Heritage Department, the Low Rider wears some unmistakable styling touches that were featured in the original FXS model of the Low Rider. Take a gander at the polished headlamp visor or eyebrow (as it was referred to in the press briefing). The polished fork and the tiny front fender carry a family resemblance. How about those split five-spoke aluminum wheels, featuring both machined aluminum and wrinkled black paint? Hey, the engine gets the same wrinkle paint, machined metal look, too. The chromed 2-into-1 exhaust has the same bad attitude of the original. Yep, theme duly noted here. The design team’s attention to detail ties the Low Rider to its predecessors yet looks more modern at the same time. The Low Rider has always been about hot rod styled performance wrapped in an attention-getting chassis (most recently the Dyna chassis) that just so happens to fit shorter riders. However, when addressing the FXDL’s past style, Harley’s engineers gave themselves some technological challenges to puzzle over. The biggest task was the desire to have the Low Rider fit riders ranging in height from 5’1″-6’1″. Yes, an entire foot difference in height. Most American riders don’t know that, although the Low Rider has been shelved domestically for the past five years here, it has continued to sell – and sell well – in the Japanese market. Since Japanese are typically shorter than Americans, the size spread begins to make more sense. The Low Rider was designed to fit every body size between a Japanese female who measures in the 50th percentile of height or, in other words, the median height for a Japanese woman. The 6’1″ top end of the equation settles in at the 90th percentile height of American men. So, the FXDL is supposed to fit riders ranging from a mid-sized Japanese woman to an above average height American man. Considering the variables of arm, leg, and torso length, this is an astonishing challenge. To find out what the needs of riders in the market for a bike like the Low Rider were interested in, Harley used the same customer-focused process they developed for Project RUSHMORE. The puzzle presented by the Low Rider is really a question of ergonomics. How does a single motorcycle accommodate such differing body types? In the end, Harley did it with some good old American ingenuity, the key of which was the all-important rider triangle. The handlebar, seat and pegs constitute the primary contact points with the rider. Within these points the physical limitations of the differing body sizes needed to be accommodated. If the pegs were in a fixed location (though ultimately two inches forward from their previous location), then the points available to change by the riders themselves were the grips and the seat. Both were addressed in simple but clever ways. Sometimes a simple solution is the best one. Take a look at how the same seat can support two different sized riders. Using computer models, the design team was able to overlay the two extremes of the rider triangles onto the chassis in order to calculate the range that the two variables needed to support. Once those were determined, the trick was to make the bike easily adjustable. For example, Harley could have sold the Low Rider with a seat option for shorter and taller riders. Many manufacturers do this. Instead, a seat was created with a means of changing its size to fit smaller riders. The FXDL’s seat has a spiffy chrome Harley badge inset into the lumbar section of the seat. However, what looks like a nice styling touch is really a cover. Lifting the seat reveals two screws positioning the badge. When these are unscrewed, mounting points under the badge are exposed that secure a bolster which moves the back of the seat 1.5 inches forward. Reaffixing the badge holds everything neatly in place. This mode of adjustment is much more convenient for both the customer (who isn’t forced to make a choice at the time of sale) and the manufacturer (who only needs to build and track one seat). The handlebar position is given infinite variability within a 2.4 in. range thanks to a clever riser assembly. In an arrangement that looks somewhat like dog bone risers (only bent about 60 degrees), the adjustment comes from clamps located just above the triple clamp. Then the risers themselves pivot forward and rearward through the range of adjustment. Atop the risers a pair of clamps hold the handlebar itself. Adjusting the bar position is as easy as loosening two allen bolts and adjusting the tilt of the risers. Once they’re tightened in position, loosen two handlebar bolts and rotate the handlebar until the grips are in the desired location. Total time is just about two minutes! Why don’t more cruisers have adjustable risers like this? Probably because nobody thought of this clever solution before now. To a 5’11″ rider, having the risers in the foreword-most position feels a little like the reach to a drag bar. In the full rearward position, the grips feel a bit too rearward to the same rider. Fine tuning takes seconds. Adjusting the seat only takes a phillips head screwdriver though this only moves the rider forward. The seat height itself is a modest 25.4 in. The narrowness of the front of the seat gives the rider the feeling of an even lower seat. The upgrades to the Dyna chassis focused on the suspension bits. The stated goal was to find the right balance between riding comfort and control. Given that the FXDL is viewed as a performance model, when the conflicting goals conflicted with each other, the nod was given in the direction of control. Both the fork and the shocks have tri-rate springs. The initial rate is quite soft to address rider comfort over smaller road irregularities. The next two rates are progressively firmer, allowing better control over larger bumps. In the 49mm fork, the firmer spring rates also minimize brake dive into the 5.1 in. of travel, giving the rider more confidence during aggressive braking. <div id="attachment_7173" class="wp-caption aligncenter" style="width: 633px"><a href="http://www.motorcycle.com/manufacturer/harley-davidson/2014-harley-davidson-low-rider-review.html/attachment/030914-2014-harley-davidson-low-rider-action-6059" rel="attachment wp-att-7173">
[motorcyclistonline] - Harley-Davidson Low Rider | First Ride | Ninjette Newsbot | Motorcycling News | 0 | June 15th, 2014 06:20 AM |
[motorcycle-usa.com] - 2014 Harley-Davidson Low Rider First Ride | Ninjette Newsbot | Motorcycling News | 0 | March 9th, 2014 01:00 AM |
[cyclenews.com] - First Look: 2014 Harley-Davidson Low Rider | Ninjette Newsbot | Motorcycling News | 0 | March 7th, 2014 03:10 PM |
[motorcycle-usa.com] - 2014 Harley-Davidson Low Rider First Look | Ninjette Newsbot | Motorcycling News | 0 | March 7th, 2014 04:50 AM |
[motorcycle.com] - 2014 Harley-Davidson Low Rider Preview | Ninjette Newsbot | Motorcycling News | 0 | March 6th, 2014 11:20 PM |
