June 19th, 2013, 07:34 AM | #1 |
Join Date: Jan 2013 Motorcycle(s): 1987 Ninja 250 custom gold Posts: 218
Clutch snapped
Hi all,
About half way through my regular 50km ride to work today i pulled in the clutch for the last time for this ride. Clutch wouldn't release, i couldn't get into neutral, let the bike stall after i pulled into the nearest plaza. Took a look at the bike and the clutch cable is intact, its something behind the crankcase cover, a spring? Any ideas what it could be? |
June 19th, 2013, 07:45 AM | #2 |
MOTM - Sep '18, Feb '16
The thing inside the clutch cover should rotate and pull out of the cover once the cable is removed. Pull that out and look at it. Or post up some photos. This is not a big deal what what ever it is.
June 19th, 2013, 07:55 AM | #3 | |
http://faq.ninja250.org/wiki/Can_I_r...able_breaks%3F
June 19th, 2013, 09:36 AM | #4 |
I already got a tow on the bike, lucky for us to have a van
When i set out today, the clutch lever never seemed to retract fully and be fully extended whenever i let the clutch off, then it finally broke, whatever the problem is. |
June 19th, 2013, 10:06 AM | #5 |
sail away
Join Date: Jul 2012 Motorcycle(s): gixxer (sold), ninjette (upgrade!) Posts: 964
It had probably stretched enough that it was too loose to pull the clutch arm. Not an expensive fix, good thing you didn't crash!
Unregistered found this post helpful. Track Day Preparation Checklist 1. Financial 2. Mental 3. Physical 4. Gear / Bike |
June 19th, 2013, 12:17 PM | #6 |
June 19th, 2013, 01:15 PM | #7 |
sail away
Cable. Have you tried tightening the adjuster near the lever?
June 19th, 2013, 01:19 PM | #8 | |
Bottom of part 13102 has a notch that grabs part 46102 and pulls it out together with parts 92045 and 13187 as you press the clutch lever at the handle bar. That way, the friction discs are liberated from the pressure of the six springs 92081.
June 19th, 2013, 08:57 PM | #9 | |
I really appreciate the help and pictures guys |
June 20th, 2013, 04:30 PM | #10 |
Here is an update:
I like to over think things, and after i pulled apart the crankcase cover and got as far as the clutch plates i saw nothing wrong... I tugged at the clutch cable and... In the process i broke the sight glass for the oil level... suits me right for over thinking the problem. What is the torque spec on the clutch spring bolts? |
June 20th, 2013, 05:42 PM | #11 | |
http://faq.ninja250.org/wiki/How_do_...sight_glass%3F For the torque: 6.5 ft-lbs (77.9 in-lbs) ......... according to: http://faq.ninja250.org/torque/ex250f/
June 20th, 2013, 05:56 PM | #12 | |
Quick and to the point. In any case, no store within 100km of me had the clutch cable and couldn't even get anything until end of this month. So i ordered one from ebay ($17 + $5 shipping) Site glass cost me $10, New gasket is $14 and kickstand spring is ~$8. Cheers, Thanks for all your help. |
June 20th, 2013, 07:37 PM | #13 |
Not so much
You are welcome
June 20th, 2013, 07:43 PM | #14 |
Make sure to lube the cable often, check the adjustment at every oil change.
The cable off my new bike only lasted 6 months being outdoors with no lube. it gradually frayed apart, until it let go at a stop light. Forcing me to ride home clutchless.
June 21st, 2013, 07:57 AM | #15 |
Lucky for me, this thing fits in a Grand Caravan.
Last time i didn't support it enough and i damaged some of the fairings though... Will have pictures soon. |
June 21st, 2013, 02:31 PM | #16 |
sail away
Voila! You can also source a used one from craigslist as I did awhile back. $10 seemed fair at the time, but if a new one is only $23, maybe I should have went new...
June 21st, 2013, 03:39 PM | #17 |
Hey, so i installed my clutch cable. I had to tighten it all the way so there is no free-play in the clutch lever, but now its stiff the entire time i pull the clutch lever.
Thinking about it, i think i overtightened the clutch spring bolts, what do you guys think? |
June 21st, 2013, 03:40 PM | #18 |
I found a place that sells parts to dealers, sold the cable to me for $20, i installed it right away
June 21st, 2013, 04:09 PM | #19 | |
did you rotate the cable tensioner all the way down into the handle bar.
June 21st, 2013, 05:03 PM | #20 | |
The new clutch cable has a smaller angle on the metallic piece near the clutch lever connection, meaning when i sit on the bike, it literally sticks out in front of the RPM gauge. Although, it isn't OEM as Kawasaki discontinued it for the E series. |
F***! Bolt snapped! | Hero Danny | General Motorcycling Discussion | 94 | October 2nd, 2014 08:53 PM |
Clutch Cable Snapped | Kokosun | Riding Skills | 12 | February 22nd, 2014 06:29 PM |
Clutch cable snapped. | Monkeytofu | 1986 - 2007 Ninja 250R Tech Talk | 6 | November 17th, 2012 02:46 PM |
Clutch cable snapped today... | jdoucet93 | 2008 - 2012 Ninja 250R Tech Talk | 24 | December 18th, 2011 03:39 PM |
2008 model clutch cable snapped @ 17,800 miles. Replacement? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 9 | December 14th, 2010 05:40 PM |
