Old September 21st, 2014, 10:28 AM   #1
Ninja Rob
Ninja Rob's Avatar
Motorcycle(s): 2004 Ninja 250
Coolant Reservoir disconnected hose
Hi everyone,
I am a new member. I recently bought a 2004 Ninja 250 and I am fixing all the things that need fixing/replacing. The coolent reservoir is empty and the upper hose is cut. Where is it supposed to be connected to?
The hose is Part# 39062
Thank You.
Ninja Rob is offline   Reply With Quote
Old September 22nd, 2014, 02:22 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Welcome to the forum, Rob!
Upper reservoir hose is just a vent/drain to the outside world. It is routed under the air box / over the gearbox to the right hand side of the bike, then it turns downward and ends somewhere near (but not touching) the exhaust pipe. The routing is not critical.
Old September 22nd, 2014, 03:00 PM   #3
its a drain
Old September 23rd, 2014, 12:57 PM   #4
Ninja Rob
Ninja Rob's Avatar
Thank You guys. I have been lying awake at night for weeks just thinking of where it goes. No, not really. Well now, on to the next question. What kind of coolent should I use? The coolent tank is empty. What kind of brakes too? I am not a heavy footed braker. I brake softly and brake Waaaaaaay before hitting a stop.
Old September 23rd, 2014, 02:15 PM   #5
dcj13
Participant
dcj13's Avatar
I run the garden-variety green Prestone antifreeze that I mix 50/50 with water.
As far as brakes go, I'm guessing you're asking about pads. I bought whatever the local CycleGear had on the shelf: EBC brand, probably HH scintered material.
Coolant Reservoir hoses ian_d3 1986 - 2007 Ninja 250R Tech Talk 2 May 10th, 2014 06:01 AM
Topping up coolant reservoir frequently -- possible leak? mgorven 2008 - 2012 Ninja 250R Tech Talk 3 August 26th, 2013 01:29 PM
Any reason I can't swap out the coolant overflow reservoir? Jojah17 2008 - 2012 Ninja 250R Tech Talk 16 July 31st, 2011 09:45 PM
Question about checking coolant reservoir. wild-bill 2008 - 2012 Ninja 250R Tech Talk 4 January 1st, 2011 09:28 AM
Coolant Reservoir Level OldGuy 1986 - 2007 Ninja 250R Tech Talk 5 December 31st, 2008 08:52 PM
