Old October 8th, 2018, 03:43 PM   #1
saber63
Motorcycle(s): '90 250 project, '03 250r, '14 STR,12 STR, '01 R6
Motor, front, and rear end swap project is getting serious.
First thing, With the Ninja400 This project is now a bit of a waste of time/money. But when it started... it was a good idea. At this point it's a matter of wanting to see it through.
I finally pulled the trigger on a TIG welder so I can finish up my ninja project. Hopefully shows up this week. This is like 10 years in the making...
No pics right now, will grab some this evening!
So my ninja250 blew the motor long long ago. I purchased a 03 CRF450R motor to stick in. I put in a 12v stator, made sure it ran etc.... But life got in the way of finishing it up...
I also have all the parts on hand to mount a 2006 GSXR600 front forks, and '08 wheel/rotors. waiting on tires to install. 120/70zr17 of course
I picked up a ninja 300 complete rear end for an alright price, that will let me run a 150/60zr17 tire, which I feel a little better with on that motor.
Tires are Q3+ and will be showing up this week.
It's already got the GSXR rear shock. So i need to space the 300's dogbones per the lovely post in the 300 section.
The 300 shock went onto the 250 I bought last month, along with the nice parts that had been on the bike getting replaced. GP suspension worked over front end, ss brake lines HH pads, woodcraft low risers, and the wheels with MT75's
Pics this evening!
saber63 is offline   Reply With Quote
Old October 8th, 2018, 10:33 PM   #2
saber63
PICS!
Little late with pics. Decided to get the front end on even though the wheel isn't ready. went with a set of All Balls headset bearings. Man getting the lower race off is always a pain, i should buy the correct tool....
Likely going to drop forks enough to mount the clip one above the clamps.
Also pics of the motor and rear end. not yer mounted...
Old October 11th, 2018, 06:23 AM   #3
motorjunkiematty420
Ninja 250 and beta 300
motorjunkiematty420's Avatar
Motorcycle(s): 2004 Kawasaki Ninja 250
what all is needed to swap a cr450 motor into a ninja frame??? Do they make a kit or is this all custom welded? i hope you check out my restoration ninja 250 project i also just swapped a crate engine into my honda
https://www.youtube.com/watch?v=CO4vg6W69cs&t=81s
motorjunkiematty420 is offline   Reply With Quote
Motor swap Prep Crown_clown 2008 - 2012 Ninja 250R Tech Talk 7 September 2nd, 2017 07:31 AM
Front End Swap eulark 1986 - 2007 Ninja 250R Tech Talk 12 November 20th, 2016 08:49 PM
Gixxer front end swap nguyener 2008 - 2012 Ninja 250R Tech Talk 4 June 20th, 2013 01:53 PM
'86 Front End Swap? Roblas 1986 - 2007 Ninja 250R Tech Talk 2 June 21st, 2011 02:36 AM
[roadracingworld.com] - Video: OTT Removes The Bent Front End From Their Project Yama Ninjette Newsbot Motorcycling News 0 October 26th, 2010 08:10 AM
