June 10th, 2012, 02:44 AM | #1 |
Join Date: May 2012 Motorcycle(s): 2010 Kawasaki Ninja 250R Posts: 27
Wheel Balance Product - Dyna beads
Has anyone ever used these to keep their tires balanced? What do riders here think? http://www.rockymountainatvmc.com/p/...le-Starter-Kit
June 10th, 2012, 03:58 PM | #2 |
No, I haven't use it,..........and I wouldn't.
Some sticky weights are more than enough. http://www3.towerhobbies.com/cgi-bin...?&I=LXK204&P=7
June 10th, 2012, 04:01 PM | #3 |
i've heard people talk wonders about these.
i think its crap. balance the wheel properly, don't take a lazy route. you dont need any fancy equipment to balance a wheel. just put the wheel with the axle through it on some jackstands. spin the wheel and see where it settles, spin it the other way- it should settle in the same spot. if it doesnt your bearings are going. the spot that it settles at is the heavy spot. you will be placing weights on the exact opposite side of the wheel to counter-balance the wheel. typically the heavy spot is near the valve stem. tape one weight on at a time and spin the wheel until it doesnt settle in the same spot (as in; no heavy spot. you can set the wheel at any rotation and it will balance there fine.) if you have a cyclegear around, you can pick up a strip of ounce stick-on weights for free. they hand them out. i think if you take your wheel down there they will even balance it for you for free.
June 10th, 2012, 04:04 PM | #4 |
Join Date: Jan 2012 Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really) Posts: 355
Not seen that before would be interesting to see if it really does work
I.e take a bike with know balance problem and see if it works as stated.
Be safe ride smart .....a dumb rider is a dead rider |
June 10th, 2012, 04:14 PM | #5 |
Ms. Personality
June 10th, 2012, 09:31 PM | #6 |
Thanks for replies! At first I wasnt sure how to balance the tire.... Ill try my research on how soon. Thanks again!
June 11th, 2012, 08:59 AM | #7 |
Edit: Oops.
Dyna Beads | kevheads | General Motorcycling Discussion | 15 | August 7th, 2014 08:10 PM |
how much weight do you use to balance your wheel/tire? | cuong-nutz | General Motorcycling Discussion | 6 | September 13th, 2012 07:40 AM |
Dyna beads AND wheel weights? uhh what..?! | KawiKid860 | General Motorcycling Discussion | 59 | December 24th, 2011 04:04 PM |
Dyna beads | eddiekay | General Motorcycling Discussion | 2 | July 1st, 2011 05:12 PM |
dyna beads - anyone use them? | shift_6 | 2008 - 2012 Ninja 250R Tech Talk | 8 | June 15th, 2010 10:46 AM |
