Old July 28th, 2012, 02:02 PM   #1
95XL
95XL's Avatar
Motorcycle(s): '04 Yamaha FZ-1, '05 Ninja 250
Electronic Flasher Issue
So, as some of you might know, I've already integrated the stock taillights on my GF's 250, with incandescent (normal) bulbs. I just replaced the front turn signals with some cheepy e-bay LED's, and of course after installing them it suffered from "hyper" flash. So I bought an electronic flasher made for the 250 from Dennis Kirk. I just installed it and the turn signal indicator on the dash doesn't work with either direction. Anybody ever run into this problem? I'm going to get sick of reminding my gf her blinkers are on if I can't get this fixed, thanks!
"Live Fast, Die Young"
95XL is offline   Reply With Quote
Old July 29th, 2012, 06:04 AM   #2
95XL
95XL's Avatar
Ok, I just browsed through the Wiki, and there's a lot in there about installing diodes, but it was all for the 08+ bikes. Is that relevent to the older bikes?
Also, it said that if you needed diodes, all 4 blinkers would blink no matter what direction you turned on, my gf's blinks in the correct direction, just the light on the dash doesn't turn on, is this caused by the same thing?
**Nevermind, I just went out and double checked and the two front LED's blink no matter what direction is turned on, but the rears blink the way they're supposed to, so I guess I've answered my last question.
Old July 29th, 2012, 12:37 PM   #3
95XL
95XL's Avatar
I'm back again, I just installed the diodes out by the blinkers (there was one diagram that showed this in the wiki), it seemed the easiest so i went with it. And i still have the same problem, with just the key on, they work the way they're supposed to, start it and the opposite side lights, but barely. But, the dash light still doesn't work. I installed the diodes only in front of the LED's I left the rear alone.
So, does this mean i have to tear the dash out and install them, or could i just install them in front of the rear lights also? It'd be real helpful if someone could chime in on this. Thanks.
Old July 29th, 2012, 12:52 PM   #4
folky15
folky15's Avatar
Motorcycle(s): '08 Ninja 250R
I prob wont be much help but I just felt bad that youve been conversing here w/ yourself
I dont think the diodes will help the indicator, but I think I read somewhere that certain LED turn signals can draw such low current that the indicator light malfunctions. Not 100% sure on that, but maybe some resistors in line w/ the LED's would help?
And youre sure the indicator bulb isn't blown, and the fuse is still good?
Done: Fender Eliminator Kit, Shogun frame sliders, Rim Tape, Freeway Blaster horn, Protons, Rear LEDs, Brake Modulator
Planned: Comp Werkes Slip-on, Snorkel Delete, Shimmed Needles
folky15 is offline   Reply With Quote
Old July 29th, 2012, 06:26 PM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
The problem lies with how the dash indicator is wired, and yes, it's the same on the newgens as well. Basically, what Kawasaki did was to connect a small low-wattage bulb directly across the positive wire for both sides of the turn signal circuit. Whichever side is on at any given moment, the power goes from that side through the dash bulb to the other side which is off. However, the other side's bulbs are still connected to ground, and the large filaments in the off-side's bulbs will provide enough of a ground for the dash bulb. The dash bulb itself, being so small, won't flow enough current to actually light up the large bulb filaments on the off-side.
The solution is to modify the wiring at the dash bulb using a pair of diodes. What you do is you cut the two wires at the bulb socket, connect each wire to a diode with the diodes electrically oriented the same such that current can flow through the diodes, and connect both diodes to just one of the bulb socket wires. The other bulb socket wire needs to be connected to ground. Now, no matter which turn signal side is active, current cannot backfeed to the off-side and can only flow through the bulb to ground.
At this point the turn signal sides are completely isolated, and any combination of LED bulbs and electronic flasher will work just fine.
Old July 30th, 2012, 01:28 PM   #6
95XL
95XL's Avatar
ah, thanks for the help, and thanks for not letting me sit here and talk to myself! lol. So, it looks like I've got some wrenching to do... time to tear the dash out...
Old August 1st, 2012, 04:04 PM   #7
Monkeytofu
I told you bro
Monkeytofu's Avatar
This may be a late response, but why not just let them hyper flash? I don't see why people want to get rid of the effect. All my biker friends point out that my lights are hyper flashing when we do group rides or talk about lighting on our bikes. I take that as them noticing my turn signals, which is good.
Old August 1st, 2012, 06:28 PM   #8
Hyperflash is not legal. There's a specified rate of flashing that your turn signals need to operate within.
Posted via Mobile Device
Old August 1st, 2012, 06:52 PM   #9
Monkeytofu
I told you bro
Monkeytofu's Avatar
How fast do the stock ones flash? According to the wikipedia article, which links to the DOT's laws, it needs to be 60-120 flashes per minute.
Old August 1st, 2012, 06:59 PM   #10
I haven't had the stock ones for quite some time, so idk, but they're definitely in that range or else they wouldn't be allowed on the roads. 60-120 is a huge range. Hyper flash is likely pushing 3 times a second
Old August 1st, 2012, 07:02 PM   #11
Monkeytofu
I told you bro
Monkeytofu's Avatar
I'll record them for a second or two and see how much they flash.
Old August 1st, 2012, 07:10 PM   #12
Monkeytofu
I told you bro
Monkeytofu's Avatar
It seems to be in between 2 and 3 so I gues it'd probably be best assume they were illegal.
Flasher issue Phoenix Cycle Shop 2008 - 2012 Ninja 250R Tech Talk 2 August 16th, 2014 05:52 PM
LEDs replacement - which electronic flasher to use? caineroad 2008 - 2012 Ninja 250R Tech Talk 1 September 24th, 2013 06:03 PM
[crash.net - WSBK] - Laverty positive after curing electronic issue Ninjette Newsbot Motorcycling News 0 June 27th, 2012 05:30 AM
where do you plug in flasher relays? walty87 2008 - 2012 Ninja 250R Farkles 3 April 19th, 2012 11:51 PM
led flasher help greatwhiteninja 2008 - 2012 Ninja 250R Tech Talk 1 June 26th, 2011 04:33 PM
