Old May 30th, 2014, 03:40 PM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
replacing front wheel bearing question
hey guys which side should I knock on the bearings out,
the side that this circlip was on?
right now I'm Tappin it and its not budging I heated it up a little it seems like the piece that the actual slide thru in between the bearings,
it seems as if it is Preseed to both sides,
I just don't want to go hammering on it part until I figure out,
if it matters which side you're not the bearings out on,
thanks Mike h
mikedabike64 is offline   Reply With Quote
Old May 31st, 2014, 06:53 AM   #2
Originally Posted by mikedabike64 View Post
hey guys which side should I knock on the bearings out..........
Please, read this:
http://www.dansmc.com/wheelbearing.htm
Old May 31st, 2014, 04:35 PM   #3
mikedabike64
excellent thank you
that was a greasy dirty job I have almost 15,000 miles on it,
I took the time to take as much grime off of everywhere that I could not normally get into.
Old May 31st, 2014, 05:20 PM   #4
You are welcome, Mike
Fix for front wheel squeak noise/Front wheel removal cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 13 April 23rd, 2014 12:25 PM
Replaced a NewGen front wheel? I need your bearing spacer! InvisiBill Items Wanted 10 February 20th, 2014 01:04 PM
Wheel bearing quality broken neck 2008 - 2012 Ninja 250R Tech Talk 15 January 18th, 2014 07:34 PM
Wheel Bearing?! RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 3 May 20th, 2012 07:12 PM
09 Ninjette wheel bearing removal Swaggeringpagan 2008 - 2012 Ninja 250R Tech Talk 6 September 3rd, 2010 04:29 PM
