July 23rd, 2008, 11:01 AM | #1 |
[motorcycledaily.com] - A Quartet of CVOs: New models from Harley-Davidson's Custom V
A while back we talked about the BackOff brake Modulator/Flasher but it does require a few wires to be cut for installation. Some crafty 2Fiddy’r has come out with a much less expensive option, that is also ‘No Cut’ installation.. (Can we say WIn-Win) Meaning it’s “Plug and Play”… So You can put away your soldering irons, butt plugs, and electrical tape and run right out and flash your neighbors.. (Whoa.. That can be taken a few different ways…) This no cut model is based off the Rear-Alert module, and installation should take no more than “2 minutes”..
So for those of you asking, ‘What exactly is a Brake Modulator, and why do I want one?” — Well it’s simple: When your front or back brakes are applied, the modulator pulses your brake lamp for about 4 seconds. The lamp then stays on solid until you release the brakes. Re-applying the brakes causes the unit to pules the brake light an additional 4~5 seconds. Generally you get 7 or 8 pulses before the lamp stays on solid. Also, cutting the green wire doubles the flash time should you want your brake light to flash longer.Remember, Visibility is key when it comes to safety when on a bike. Price: $19.95 URL: EBay Motors Click here for full story...
[motorcycledaily.com] - Harley-Davidson 2015 Models Announced: New Freewheeler Trike | Ninjette Newsbot | Motorcycling News | 0 | August 26th, 2014 09:10 AM |
[motorcycledaily.com] - 2010 Harley-Davidson CVO Models - MD First Ride | Ninjette Newsbot | Motorcycling News | 0 | October 15th, 2009 02:31 AM |
[motorcycledaily.com] - 2009 Harley-Davidson Touring Models and V-Rod Muscle - MD Fir | Ninjette Newsbot | Motorcycling News | 0 | August 5th, 2008 02:00 AM |
[2wf.com] - 2009 Harley Davidson Models | Ninjette Newsbot | Motorcycling News | 0 | July 23rd, 2008 11:01 AM |
[usridernews.com] - NEW ENGINE, FOUR NEW MODELS FROM HARLEY-DAVIDSON | Ninjette Newsbot | Motorcycling News | 0 | June 19th, 2008 04:30 AM |
