Old May 12th, 2014, 05:22 AM   #1
scorch
scorch's Avatar
Motorcycle(s): 250
winterizing 250's
Is there a good way to winterize bikes for the summer.. yup, i said summer.
ill be going to europe for a month of two, and the last time i came back the batt was dead and i had a hell of a hard time starting up the bikes.
i left my 08 ninja for a week, and it was a beast to restart. So hopefully i can get some tips here.
scorch is offline   Reply With Quote
Old May 12th, 2014, 05:29 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Fuel stabilizer battery tender and run the carbs dry. A month it will be fine
Worlds fastest 250 ninja
Old May 12th, 2014, 05:36 AM   #3
scorch
scorch's Avatar
Motorcycle(s): 250
i have 1 battery tender, but i have 2 ninjas. Should i just disconnect the battery, is there a way to use 1 battery tender on 2 batteries?
What is a fuel stabilizer? in portugal i tried to find such a thing i and could not. I did run the carbs dry on most bikes.
If you leave a bike for a year, how do you winterize it. I have bike in Europe which i use in the summer.
Old May 12th, 2014, 05:49 AM   #4
Racer x
Racer x's Avatar
Get the stuff called stability marine formula from auto zone and follow the directions. Disconnect the newest battery and charge the oldest.
Old May 12th, 2014, 06:04 AM   #5
jschorr
jschorr's Avatar
Motorcycle(s): 1995 ninja 250r
I don't see why you couldn't charge them in a series...or is it parallel....
I think leaving it for a year would be the same as for the winter. But of course when you take it out you change th fluids after that long.
jschorr is offline   Reply With Quote
Old May 12th, 2014, 06:23 AM   #6
allanoue
allanoue's Avatar
MOTM - Sep '14
here is a good thread
https://www.ninjette.org/forums/showthread.php?t=29183
\merge
@Alex did it work?
Old May 12th, 2014, 07:32 AM   #7
DaBlue1
DaBlue1's Avatar
If you are going away for a couple of months, get some Star Tron Fuel Treatment for your bike here in the U.S. (sold at Walmart, Auto Zone, Advance Auto and most auto part stores and small engine shops.) Make sure it gets into the carbs.
For your bike in Portugal you may also be able to find Star Tron or Motorex Fuel Stabilizer. Since those bikes are stored longer, it's best to drain the carbs and tank dry.
As for your batteries, make sure they are in good condition before leaving them on a battery tender for such a long period. Also make sure you have a battery tender that's up to the task of long term charging, meaning that it has automatic shut off for voltage, temp, and power surge. I'd also take them out of the bike. Try to get a good charge on the weakest battery first before storage. It should last a month or more before it is critically discharged (providing it's in good condition). I wouldn't bother if it's a battery that's already got issues like being more than 4-5 years old or does not get regular charged during routine maintenance.
Even though you're only going away for a couple of months, it would also be a good time to go over some Winter Storage Tips for the summer as well.
Old May 12th, 2014, 06:21 PM   #8
\merge
@Alex did it work?
Evidently not!
Old May 13th, 2014, 05:38 AM   #9
scorch
scorch's Avatar
Motorcycle(s): 250
in portugal i could not find any stabilizer at all for the fuel. I did top off the gas tank. Removed the battery, drained the carbs, put it up off the ground. Greased up parts. Changed the oil and filter.
But its always a pain to get it started after so long of not riding.
Old May 13th, 2014, 07:41 AM   #10
DaBlue1
DaBlue1's Avatar
Originally Posted by scorch View Post
....in portugal i could not find any stabilizer at all for the fuel.
When you get there, you may need to order some. They do have it, just maybe not in the area you are in. Many may use fuel stabilizer in their boats.
If plain gas sits too long it loses it's energy, which may be one of the reasons for the hard starts. Fresh gas is always the best thing to use.
Old May 13th, 2014, 11:34 AM   #11
allanoue
allanoue's Avatar
MOTM - Sep '14
http://www.motorinbox.com/es/consumi...a-brp-xps.html
Winterizing for one day Ninja Rob General Motorcycling Discussion 50 January 10th, 2015 08:01 AM
Winterizing Question Apex123 2008 - 2012 Ninja 250R Tech Talk 2 November 12th, 2014 09:53 PM
Winterizing... emilyLOVESlime 1986 - 2007 Ninja 250R Tech Talk 18 November 2nd, 2009 10:57 PM
Anyone Have Problems De-Winterizing? TrueFaith 2008 - 2012 Ninja 250R Tech Talk 17 April 13th, 2009 09:29 PM
Winterizing your Ninjette Sailariel 2008 - 2012 Ninja 250R Tech Talk 37 December 20th, 2008 08:05 PM
