Old May 22nd, 2018, 08:10 PM   #1
sarcaz
Motorcycle(s): Ducati Monster, Ninja 250
Extra bolt with nyloc nut
Gang - Where does this go? Look familiar to anyone? I'm rebuilding this 1986 Ninja EX250E and I'm about 99% of the way done. It runs and it mostly works, but I've got this extra part (among others) and it's concerning. Thoughts?
Mirror mounting bolts added for scale on the right.
https://imgur.com/DaIgTba
sarcaz is offline   Reply With Quote
Old May 22nd, 2018, 09:46 PM   #2
sarcaz
Update: I'm convinced this was an extra bolt from the clutch handle assembly, which I partially replaced... unless there are alternate theories.
Old May 23rd, 2018, 06:22 AM   #3
You're probably right, given its small size, and the fact that it's a shoulder bolt.
Old May 23rd, 2018, 06:24 AM   #4
I would say that is a lever pivot bolt.
Old May 23rd, 2018, 09:15 AM   #5
MR2Aaron
Motorcycle(s): 2003 Kawasaki Ninja 250
It's clearly a pivot bolt of some sort.
The kickstand has a similar one with a lock nut on the back, although I think it's shorter, and a bigger diameter than the one pictured.
MR2Aaron is offline   Reply With Quote
Old May 23rd, 2018, 01:04 PM   #6
Definitely lever-pivot bolt. What's holding on your brake or clutch lever now?
Old May 23rd, 2018, 08:24 PM   #7
sarcaz
I have a full replacement clutch lever assembly I bought ages ago... full swap at the same time as my rebuild, so I didn't realize this part would have been attached then. Thanks, all!
Can't remove Clutch pivot bolt lock nut! ninja98r 2008 - 2012 Ninja 250R Tech Talk 7 May 22nd, 2013 04:52 AM
clutch lever pivot bolt/nut torque specs Confuzshuz 2008 - 2012 Ninja 250R Tech Talk 3 September 25th, 2012 05:11 AM
Clutch pivot bolt and nut setasai Items Wanted 4 October 8th, 2011 08:14 AM
Bolt/Nut Discoloration delsin General Motorcycling Discussion 14 March 8th, 2011 07:30 AM
Never use fuel tank linear, and there is a nut on the clutch lever bolt... saber63 1986 - 2007 Ninja 250R Tech Talk 0 April 23rd, 2010 08:58 AM
