Old July 10th, 2022, 06:55 PM   #1
lordhelemt
Motorcycle(s): A few
Noob Carb Question
I recently picked up a non-running 2008 Ninja 250. I'm waiting on the FSM and may have gotten ahead of myself. I'm pretty good at bringing carbs back to life since I'm fortunate enough to have a professional ultrasonic cleaner. That said, this is my first time playing with this carb. I cleaned the carb, thought everything was good, but the bike won't start.
After reading some posts here I learned that the needle jets are sided. Not sure if mine were in the right spot (N9VW and N9VU) and I didn't realize the needle seals 16017 come out (I just recovered mine out of the bottom of the ultrasonic cleaner).
Pulled the carb again and will insert the seals, double check the needles, float is good at 17mm (if that is the correct setting) and go over it once again and hopefully it will start this time.
My question is are any of the other jets/components sided like the needles? Also there is a long hose that attaches between the carbs, is that just a vent hose or does it need to be hooked to anything (pic attached)?
Any help or suggestions would be greatly appreciated. I'd like to get this bike running.
lordhelemt is offline   Reply With Quote
Old July 11th, 2022, 07:10 AM   #2
Swapping needles will just results in slightly different fueling per side. Won't cause any issues with starting bike at all.
Hose between carbs goes to coast enricher. Prevents popping when letting off throttle. Won't affect starting bike.
Did you rebuild petcock?
Done flow test to verify it actually flows sufficient volume?
Old July 11th, 2022, 08:42 AM   #3
lordhelemt
Petcock flows.
I need to look at the hose diagram again but the enricher is already hooked to another port on the carb.
Old July 11th, 2022, 11:36 AM   #4
There should be three hoses connected to coast-enricher.
How much petcock flows is important. Just having power at battery is different with 8v vs. 12v.
How much does petcock flow in 30-sec with barely any vacuum applied?
Bikes aren't binary, they're analogue with shades-of-grey variations. Depending upon which end of grey you're at, they may or may not work at all.
Also have you check internal fuel-hose filter? Is it inserted in correct direction or has it been crumpled and wadded up into ball?
Last futzed with by DannoXYZ; July 16th, 2022 at 08:46 PM.
Old July 11th, 2022, 12:47 PM   #5
As final test to confirm or rule-out difficulty starting is or is not fuel-delivery issue, get squirt bottle. Put some petrol in it and squirt 2-3cc into airbox. Wait 30-second and push START button. Does it run now?
Old July 11th, 2022, 01:35 PM   #6
lordhelemt
It's all good. Installed the needle seals that fell out during the ultrasonic cleaning process and the bike started right up.
I did discover a problem with the petcock. It leaks when on when the bike is not running. Can that be rebuilt or does it need to be replaced?
Old July 11th, 2022, 02:43 PM   #7
ducatiman
ducatiman's Avatar
actually known as needle jets often forgot about/lost during cleaning process
yes, petcocks are possible to be reliably rebuilt using great care and new internals
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Wiring Noob Question 06CandyThunder 1986 - 2007 Ninja 250R Farkles 6 January 21st, 2020 05:17 PM
Hi guys. A noob question knivee14 2008 - 2012 Ninja 250R Tech Talk 6 October 19th, 2016 10:52 AM
Stupid noob question from a non-noob LNasty 2008 - 2012 Ninja 250R Tech Talk 13 March 21st, 2015 10:47 PM
Noob Stalling Question ajcadoo Riding Skills 37 March 1st, 2012 03:42 PM
noob ? (sprockets question) Raiders fan General Motorcycling Discussion 3 April 5th, 2011 11:42 AM
