Old November 6th, 2021, 04:39 PM   #1
BlackCat04
MC Pee Pants
BlackCat04's Avatar
Motorcycle(s): '04 EX250F custom, 2008 Ninja 650R
Airbox Connection
All right. So, I've recently put my airbox back into my little Ninjette, after a while of having an air-filter mod installed. My only issue is trying to connect the hoses to the back of the carbs.
What's the easiest way to get them to wrap around the mouth of the carbs? The hoses are also pretty stiff. Is there anything I could use to soften them a bit? Would something like WD-40 work? I already have the battery box mod and it's still a pain. I appreciate any and all help I can get!
Thanks. ฅ(^・ω・^ฅ)
BlackCat04 is offline   Reply With Quote
Old November 7th, 2021, 07:38 AM   #2
BlackCat04
MC Pee Pants
BlackCat04's Avatar
Managed to get it to fit. Sprayed the connectors with WD-40, let it sit overnight, then I took my portable heater and sat it over the hoses for about 10 minutes this morning. They slid right on!
Connection cover concern o5mooch5o 2008 - 2012 Ninja 250R Tech Talk 3 September 1st, 2017 10:45 PM
Ground connection? juliusmichaelhonrada 1986 - 2007 Ninja 250R Tech Talk 3 August 5th, 2016 06:12 AM
Airbox to Carb Connection Ralgha 2008 - 2012 Ninja 250R Tech Talk 5 September 15th, 2014 06:38 PM
Can you tell me what this wire connection is for.. svsandeep 2008 - 2012 Ninja 250R Tech Talk 2 May 19th, 2012 10:43 AM
