Old January 1st, 2022, 09:11 PM   #1
tomsninja2020
Guest
Posts: n/a
Question Need a Windscreen for my 1986 Ninja 250
Been searching high and low for a windscreen for my 1986 Ninja 250 but I cannot seem to find one. The only ones that I can find are for the 1988 and up models of the Ninja 250. Is it possible to use one of those or there other options for this?
Thanks
Tom
Old January 1st, 2022, 11:52 PM   #2
Yes! It's possible to use windscreen from '88-07 pre-gen on '86-87 1st-gen. Here's an '87 I rescued in boxes.
Put it all back together
Ended up using headlight, windscreen and mirrors from pre-gen.
Bolt upper holes together and you'll see lower holes don't quite line up. I marked from back side where to drill new hole in windscreen to fit. Thinking back, I should've marked from front and drilled new hole in fairing. Then final result would've been cleaner without unused original hole in windscreen visible.
Last futzed with by DannoXYZ; January 2nd, 2022 at 08:34 AM.
Old January 2nd, 2022, 03:33 PM   #3
tomsninja2020
Guest
Posts: n/a
OK, thank you for the info I that. How does it work to block the wind and cut down on the wind noise going through the helmet?
Thanks
Tom
Old January 2nd, 2022, 05:22 PM   #4
works pretty well. I bought taller "double bubble" screen that's about 2" taller.
Good article on this bike:
http://www.yeoldecycleshoppe.com/roa...250r-road-test
1986 ninja 250 james250ninja Pictures 12 August 19th, 2014 05:58 AM
