Old June 12th, 2009, 01:08 AM   #1
diablo250
Crafty Salesman....
diablo250's Avatar
Motorcycle(s): 09 250r, 06 sv650sf
Smile Idle mixture screw question after jet install...
So I got finished putting in my dynojet jet kit, installed the clips to the recommended position and installed a 098 main. After I prepared myself for a tough time tuning the idle, the bike started right up and idled fine. I took it out, rode slowly, no jerkiness, no hesitation. Pulled hard to redline. At idle when I blip the throttle it revs quickly and then returns. Is it normal to not have to tune the idle adjustment screws after jetting? After all i've read, it seems that this bike could be an exception....
diablo250 is offline   Reply With Quote
Old June 12th, 2009, 01:22 AM   #2
do you know where the mixture screws are set now? if not, find out, then start tuning them. you can always put them back where they are now if you can't find any improvement.
you may have lucked out and they might be set to optimum right now, but w/o playing with them a bit, you'll never know... and isn't that part of the reason you installed the jet kit... to maximize what you have to work with?
on the other hand, if you're happy with the way the bike performs now, leave it alone and go ride.
Old June 12th, 2009, 04:56 AM   #3
HKr1
IC2(SW)
HKr1's Avatar
If you followed the DJ instructions, the mix screws are at 3 now?
Old June 12th, 2009, 07:14 AM   #4
Justanothermp5
Justanothermp5's Avatar
i didnt mess with my mixture screws and im running rich right now
i blip the throttle and it comes back down but i little slower then normal, better rich then lean though
i put the 100 jets in from the dynojet stage 2 kit, i knew i should have put the 98s but i didnt want to have to take them apart again if its too lean
my idle is like 2grand, normal or kinda high?
Justanothermp5 is offline   Reply With Quote
Old June 12th, 2009, 07:21 AM   #5
g21-30
g21-30's Avatar
Try adjusting the idle via the Black Knob on the left side, under the gas tank. Did you install the DJ needles?
Old June 12th, 2009, 07:30 AM   #6
Justanothermp5
yea i did everything in the kit, i adjusted the idle knob ur talking about but under 2k it idles really rough so i just bumped it up a little so i wouldnt shake my nuts off at a light lol
Woodcraft~Area P~Zero Gravity~Dynojet~DDM
Custom Paint by- ME
Old June 12th, 2009, 09:00 AM   #7
HKr1
IC2(SW)
HKr1's Avatar
Doesnt that mean lean
Old June 12th, 2009, 09:46 AM   #8
yes.
Old June 12th, 2009, 12:17 PM   #9
diablo250
Crafty Salesman....
diablo250's Avatar
The bike should idle properly ~1300 rpms. Check your idle mixture screws, check the throttle cable and also check the end of the choke wire at the engine. Sometimes after working on the bike the ferrule doesn't seat right into the holder and the choke can stay on a bit...
Old June 12th, 2009, 12:18 PM   #10
diablo250
Crafty Salesman....
diablo250's Avatar
I didn't touch the screws. The bike runs fine though.
Old September 25th, 2010, 11:43 AM   #11
Justanothermp5
i know this is an incredibly late, super late response lol but i just saw this when i was searching for my posts (havent been on in a while)
how could the bike be lean? i have the 100's from the dynojet kit, the areap full exhaust, and the snorkel removed
in my head there is no way it could be running lean, idle smells really strong like gas too so i figured it was rich
either way bike is still kicking
bike is an 09 an only has 1500 miles on it i think lol so i dont ride it much,
Custom Paint by- ME
Old September 25th, 2010, 11:49 AM   #12
have you even bothered reading the installation instructions which tell you how to tune the carb circuits after installing the jet kit?
carb circuits are not tuned using the "smell" test.
if you're happy with the way it runs, leave it alone.
Old September 26th, 2010, 09:10 AM   #13
Justanothermp5
no....lol I installed them a while back, im kind of a newb to working on carb'ed engines
ill take a look at the instructions, still have them in the garage, sorry if im being a bit of a nuisance, just trying to expand my knowledge
i may have to take the carbs off the bike anyways, so i can adjust the screws at the same time...its been sitting for 3 weeks, went to start the bike today and it didnt want to idle without the choke all the way on
Custom Paint by- ME
what is the best idle screw mixture vmax 2008 - 2012 Ninja 250R Tech Talk 9 July 1st, 2017 10:45 AM
Idle Mixture Screw Problem gogoKawi 2008 - 2012 Ninja 250R Tech Talk 6 April 23rd, 2013 07:07 PM
Adjusting the Idle Mixture Screw conrya5 2008 - 2012 Ninja 250R Tech Talk 22 March 18th, 2013 05:03 AM
very quick question on idle mixture screw RockyCapone 1986 - 2007 Ninja 250R Tech Talk 5 October 15th, 2012 05:52 PM
Idle Mixture adjustment screw Q indr 2008 - 2012 Ninja 250R Tech Talk 1 December 2nd, 2010 09:36 PM
