#241 | |
Join Date: Dec 2013 Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD) Posts: A lot.
This is similar to what I have been working on to remedy the problem. Its not that I am just staring at the huge rock wall with jersey barriers in front and a tire wall between my soft tissue and their hard surface, its just always in the back of my mind. Since this was the first season where I was actually able to run the track properly with me and the bike working as a team, I just began to experience this issue. Since most of my life has been street riding, have not had tons of experience running a liter bike at full throttle in top gear. Once things get into triple digits I am used to backing off on the street. I know what I have to do to correct this problem-just keep the bike pinned longer. Thank you for the write up, your suggestion and description are extremely helpful and I hope it will help others who may have the same issue ![]() |
#242 | |
I had a long discussion last night with a trusted riding coach and he sort of said the same thing as you did in your post. I am not fixated on the walls or any other points on the track but I know what and where the potential hazards are and I know what a safe pace for me feels like in relation to the perceived hazards. I am out of my comfort zone once speeds start hitting above 120. My last 30 years of street riding have had only a few runs up to high speed and on the street, more speed ='s increased danger or risk. I have just realized that I have this issue of slowly rolling off the throttle on longer straights, and I was working on it this last few track trips. Part of my lower lap times have come from getting on the gas earlier in the turn and holding it on longer. I am mostly trying to understand why I do this more than what needs to be done,( but please dont hesitate to add any suggestions) I hope to have this much more sorted next season. I have a few small issues to work on that should make this problem solve itself. Thank you for the write up and suggestions, I will keep all posted as to my progress with this issue |
#243 | |
@Misti, Thank you for taking the time to read my journey. You have given me great direction in the past and I really appreciate your help. Your question about how I relax when riding is great and I had to take a little time to think about that. I am always relaxed when riding ---except when Im not relaxed! I will attempt to explain: When I ride, I try to "flow" with the bike. Muscle memory, as you know well, along with experience, good lines and throttle control all make the bike move from DOT to Dot on the track with little actual effort, this is what I mean by "Flow". When I am riding like this my mental budget is not overwhelmed and I work with the bike, the bike stays smooth and happy and so do I. Once the decision is made to "Up the Pace" more than just a little over last lap, things start to happen. Lets take an example turn entry: Normally I would roll off just before my brake marker, begin braking-release brake and turn in at my reference point. Add 10% or more speed and I now need to roll off earlier or brake harder. Both quantities unknown at my present level and no extra budget for calculations. I either over brake or miss my turn in marker running deeper into the turn than usual. These little errors begin to add up causing slower laps over all. Once I catch myself trying to push harder and making errors, I simply remind myself that I know how to follow all the riding rules and just have to slow a bit and start hitting my mark's correctly again. Once things get back under control and back within my mental budget, I can begin to add speed slowly and there is time and mental power to make more precise inputs and adjust my markers as needed. My feeling is that the bike is smooth and stable(Happy) when I am running my 85% pace but once I start running 90-95% I start making small mistakes that upset the pace and/or the bike and that makes me unhappy. All I need to do is refocus on my markers and lines and I get back up to speed/ smooth and can add a small amount of speed next turn. Anytime I try to take a bigger step, the bike protests (due to my inputs) and lap times fall. I really cant remember any other technique I would use to relax and stay relaxed besides remembering I know how to ride a bike so I just relax and ride and the speed comes-step by step- even if its baby steps at this point. On another subject, I hope to be able to ride with you on COTA in the next couple of years! 2020 is done and 2021 is still an unknown but I hope to have a chance to get to Texas and ride with you and the CALI Superbike school. Great school, great track and BMW S1000RR? Where do I sign up for that deal??? Could not think of a better reason to go to Texas. |
#244 | |
Join Date: Oct 2010 Motorcycle(s): currently: Yamaha YZF 250 dirt/motard Posts: 778
What happens to your visuals when you try and enter a corner faster? Does your vision change? Does it narrow down or do you lose track of your wide vision? Can you still see all your Reference points? For me, when I try and go fast, my vision gets behind a little and my perception of speed feels faster because of it. I get scared and then I over slow. Whatever gains I made in entering the corner faster, are therefore lost. So, it starts with having great Reference Points, but then also has a ton to do with how and when I LOOK at those reference points. The key in almost all the situations is to NOT try and go fast but to work on improving your skills, one step at a time. Quick story for you, you may have heard it before but here it is again. The first time I raced AMA 600 at Daytona I had never ridden the track before. I showed up a week before with the intent of spending the weekend club racing and learning the track before the AMA race but unfortunately on my second session around, I blew my motor on the banking. We scrambled to get a replacement motor sent from Oregon where my B Bike was (I couldn't afford to have both my bikes there) and that meant that I had just ONE Day to learn the track during the Team Hammer track day, before AMA qualifying the next day. I went out for each practice session with a specific exercise to work on. First was Reference Points, in finding them and in drawing the track. I called Keith Code himself between sessions to talk through areas that I was struggling. Each session out I drew the track and added more RP's and before the final practice session of the day we compared may split times with everyone else's times (I was way off the pace) and chose the two corners where I was losing the most time. Those two corners also happened to be the corners I had the fewest reference points in. For the last session I worked on finding more and better RP's and in putting my vision together so I flowed from one point to the other. The next day was qualifying and I didn't have much practice time to step up and find several seconds of improvement. I did the same thing, systematically working on putting my visuals together until the qualifying session came and Keith Code said "ok, you've done your work, now just RIDE, relax and have fun." I let go of everything and focussed on being smooth, relaxed and in having fun. I kept shouting in my helmet, "I'm riding DAYTONA!!!!" and sure enough when I came in, I had managed to find the time needed to qualify for the race! So many times I caught myself trying to go FASTER instead of trying to improve and I had it all backwards. If you work on trying to improve your skills, how you roll on the gas, when you roll on, adding more RP's, remaining relaxed, not allowing your vision to narrow etc.....THAT is when you will find the speed. ![]() You're on the right track. Keep up the hard work and you will find improvement in your times!!
"Leap and the net will appear!" superbikeschool.com www.motomom.ca |
#245 |
MOTM - Mar '13, Jun '14
A good friend of mine, who happens to be a motorcycle legend, told me when I first started racing (back in 1982) to find someone fast and follow them. This might help you find the points of reference and the speed you are looking for.
He now mentors young riders and still tells them to do that. Just remember to pass them before the finish line.
#246 |
Join Date: Dec 2011 Motorcycle(s): CB125T EX250F-street Ninja250R-race CBR250R-MC19 CBR250RR-MC22 NSR350R-MC21 VF500F CBR600RR VFR750F Posts: A lot.
I actually think you're doing fine and making great progress! Might be stressing yourself by trying to chop off too much time too quickly. Work on consistency for a while, get all your laps within 1-sec of each other. You'll find it'll give you great comfort and stability. Then it'll be easier to pick up 0.1s at a time.
#247 | |
Remember, this is supposed to be fun!
#248 |
If I ride at a comfortable speed I'll be 5 seconds off my race time. I need a rabbit to chase. If I get a tow just above my comfort level. Soon that speed will be comfortable. And so on so forth.
#249 | |
At this time my confidence at my current pace is good and that is why I was able to improve my lap times last trip. With all the improvements I made to the geometry of the bike, tires and my mental work things are going well. I did not experience even the slightest scary moment with things the way they are setup now. Different day, different track might change all of this but at least I had a weekend on the bike where it was setup perfect for the way I was riding on that track that day. Heres to hoping the bike has a good baseline setup as I continue to look for the edge of traction. |
#250 | |
![]() 2 out of 2 members found this post helpful. |
#251 | |
You are correct, when following a faster rider, I always use all my reference markers as they still work at the faster pace. I am still far from 99% braking or carrying max speed thru turn. Since I just finally made a break thru this season a lot of these things are still unchanged since I just started to get comfortable running at the faster pace. When following a faster rider, I use my reference but I might brake just slightly late. The only thing I see as different is that I dont have to think as much to set entry speed, I just match the faster rider. I will look at their markers this season and see if I can use them to my advantage. Thanks for the plan! Ant PS I live in Worcester Mass area and have 2 Ducatis--Should you be in the neighborhood and want to go for a ride |
#252 | ||
#253 | |
Sorry for the delay in answering your post, I had to really think to work out what the difference really came from. I guess if im honest, its me being lazy. Since we are not racing, I can safely assume they bike I am following (in the slower groups) will not be braking anywhere near 100% and will not be carrying max corner speed. This allows me to simply match their speed down the straight until I reach my brake marker, then just brake + or - a little bit to again keep the gap between us approx the same. I only use my line thru the turn so they may be on the same line but usually they are on a different enough line that I can run up along side to show a wheel or slow a bit more to maintain the gap. I believe this means I use my own reference points but that the other rider I am following becomes a moving reference point. Most of the time when this is happening now, I am setting them up for a pass driving out of the turn so matching their speed on entry then looking to get on the gas earlier than them to get the good drive out. I dont think I have an issue with not looking far enough down the track(see my posts about looking beyond the next turn focusing on the jersey barriers or the huge rock wall beyond) but I will take a mental note of how far ahead I really am looking at speed. I have a real test ahead of me now. My next track trip is just over a week away and I will be riding an unfamiliar bike at a track I have never been to. Going to Road Atlanta for 2 days and borrowing a bike. I have no doubt that I am in good hands down there just the normal worries of a borrowed bike on a new to me track. I will report back once the event has concluded |
#254 | |
![]() As for following faster riders, I usually find that when I'm following a faster rider, it is actually forcing me to look further ahead or further down the track, SOONER, which helps me feel like I'm not actually going as fast. There are other things you can learn as well, like the angle they approach the turn-in area, where they turn the bike, how much of the track they use etc. I'll never forget my second session riding at Aragon as part of Troy Corser's Racing School Europe and having Troy himself blast by me and tap the back of his bike- follow me! I barely knew if the corner went left or right but I was doing everything I could to tag along with him. He was giving me all sorts of hand signals, move this way, 2nd gear, look up the track, etc....it was too much at once, but the biggest take away were some of his lines, how much more of the track he was using than I was, and just getting my eyes up higher because I was watching him!
#255 |
I am a fan of full disclosure....
Ducati999 was with me @ Road Atlanta for 2 days. I could not ride with him on track as we were "sharing" a bike. However, I was all over that track infield on my scooter trying to see him in the most important and challenging corners except turn 7. I can share this... He did everything very well. The evidence shown on the bike and tires proved this. I chatted with the coach that was towing him around, all good feedback. He had amazing composure, patience and restraint when riding an unfamiliar track, on someone else's bike but DID push hard enough to leave with a smile and learned a thing or 2 about inline 4's and their characteristics vs twins. His comments to me in the paddock showed an understanding of what he needed to do and a plan to do it. Road Atlanta is a big track where you spend quite a bit of time per lap near or over 100mph. Its kink in the back straight will challenge your ability to hold full throttle @ 140mph+, the elevation change onto the front straight will test your faith in the ability to brake in time to make the corner at the bottom of the hill. And the chicane after the exit of turn one will ensure that you have planned ahead of time. ps... The tach (and many other things, lol) on my bike doesn't work. He found himself having to ride in a way that forced an understanding what the bike wanted from him vs looking at a dash. Only 3 things work on my dash; fuel light, the clock and the near rev limit shift light. Aside of that, it's just the rider, the bike and the track. Watching him come to terms with this over 2 days was an amazing sight. For full disclosure, the speedo works but we all already know about that while on track. imho.... he left having more experience in one of the most important skills that a rider can have. Listening and understanding to the bikes subtle feedback and hints will serve you well. pss.... He should have come to NOLA with me, cause the track, people and food were amazing. psss.... He snores ![]()
#256 | |
Time for a report from Road Atlanta. I signed up for the intremediate group as RA just runs 3 groups and I dont feel ready to play with the biggest dogs in the park just yet. I have to side step a little and explain the entire situation before before I get into what went down on track. Turns out that my gracious host had an issue with his regular track bike and his backups, backup was not running either. So here is my situation: New track I have never seen before, Borrowed bike, I ride a big V-twin and the borrowed bike is an R6 with totally different power delivery and just happened to have a NON FUNCTIONING tachometer! Lets add to that the fact that my host is a coach and also had another event 3 days after this one where he was traveling to coach at NOLA and we would have to share the bike for the 2 day event. Could I even ever be more worried about even the smallest crash? I dont think so!!!! Also, Road Atlanta is the fastest track I have ever been to, with 100mph into turn 1 as the norm. I dont mean you are running at 120 then brake, you are accelerating down the straight from turn 12 to turn 1 at 120 touch the brake to get the bike to turn and dive right in to the turn at 100ish. Never done that before. There was one guy that over shot turn 1, bike went thru the gravel, hit the air fence and flew into the air coming to rest between the air fence and jersey barrier. They needed to get a crane to lift his bike out, he was unhurt. Since Moto America was running the track 2 days later, we were instructed to slow enough for turn 12(last turn) to "put your kickstand down before proceeding". We were told that no one was to crash in turn 12 no matter what!! Ok enough excuses for not being fast. Overall I did well and my coach/host rated my performance as a solid A but I gave myself a B+. I spent the entire event riding at 75-80% of my ability which was good enough to keep the shiny side up and not annoy the other riders. The tires dont lie and they looked great after each session with plenty of rolled rubber and good wear. I did not have any scary moments (except once when I forgot which turn I was in and missed my mark but was able to correct and make the turn. Most of the issues I did experience were because I would down shift 2 gears on corner entry and should have done 3. I am not used to 16,000 RPM redline and with no tach to reference, it took a little bit of learning to keep up momentum. At least there was a shift light 1000 rpm before red line. I knew when to up shift but had many roll ons that fell flat on lower than optimal RPM. I did learn that most track day riders that event were rolling off way early and braking much softer than I. They would blow by on the back straight-While I was at redline with the rev limiter/gearing holding me to 148mph--but I would catch or even pass them before I even rolled off for turn 10! I was rolling off just before the 200ft marker and dropping 3 gears while braking into the turn. I was advised by my coach to move this back to the 300 ft marker and do things a little slower. I would still catch and pass some riders but things were smoother and I felt a little less rushed. After turn 10(left turn) there is a 3rd gear right turn then up the hill. You cannot see what is past the top of the hill, you have to wait till you crest the hill at 80-90 mph-totally blind and as you crest that hill you see the track drops down 40-50 ft or more in the next 150 yards. Total nose dive down to the manditory parking lot turn 12 at 110 mph! No worries, whats the worst that could happen? I did much better at holding the throttle wide open for the entire straights, which was an issue I had been experiencing earlier. I did well learning the track fairly quickly--learning the lines was much quicker than learning the bike for me. Turn 6 is a fast left uphill and most bigger cc bikes wheelie at the top, the R6 was no exception, I was riding out a 6-7" wheelie when I heard a bike overtaking me. I look right and there is a ZX10 in a full stand up wheelie but the electronics put the front down just for it to raise skyward again and drop and rise as he passed me and accelerated away-I miss my Ducati!!!!! Could not have been a better trip, No crashing and I learned a whole lot. I cannot thank my host enough for this experience! ![]() |
#257 |
Time for an update on my pathetic life.
I will be returning to the Palmer Mass track in approx 2 weeks for Memorial day weekend. I have booked Sunday and Monday. My update here is just to establish my personal goals, in writing. Back in 2019, I solved my big handling/body position issues and have steadily improved since. Enough about boring old me, lets talk riding! My best lap time around Palmer is currently 1:55.? and my goal is to improve this time to 1:50 on Sunday. I know this sounds like a lofty goal for a guy who was running 2:16 laps this time last year but many things have changed. Let me explain before you make a decision if I am "pushing too much". After solving my BP issue, I added a set of offset tripples and changed to Pirelli tires vs the Dunlop Q3+ tires I had been running. Since I messed with the geometry of the bike and switched tire MFG's at the same time, I decided to put the stock gearing(which is very high) back on the bike. With the much smaller rear sprocket (6 teeth smaller) I could pull the rear wheel back to its maximum making the wheel base much longer and the bike a little slower to turn in but more stable and less likely to slide/spin the rear. Stock Ducati gearing is crazy high giving the bike a theoretical 178MPH top speed which the motor is incapable of reaching. With my lower gearing I can top 155 and at Palmer, you do not need much more. OK so we have lower gearing now, new tire brand, better geometry and I had the track Guru set my suspension up, so feeling bike turns much better, has better stability, better acceleration and handles the rough stuff much smoother. All this adds up to potentially better lap times(rider dependent). Should you have been following my issues in the above thread, you will be aware of my issue of not holding the throttle wide open-especially on the long straights. My trip to Road Atlanta has cured this for me. The back straight at Road Atlanta is fast and long and if you dont hold it pinned, its much longer!! The throttle on the R6, I was lucky enough to have borrowed, is much heavier(return spring) than my Duc and I still have not regrown the skin on my hands from the blisters I got holding said throttle at the stop for a lllllooooonnnnnggg time! Burrr Burrr Burr goes the rev limiter at 148MPH. Now we have a bike with better geometry, better suspension and lower gearing along with my new ability to hold open the throttle longer and you can see that 4-5 seconds is not that big a jump. I am not planning on running any harder (at approx 80% my possible pace now) than I have been but all these changes should make this goal obtainable. I mentioned in the above thread that I have not had any negative feed back from the bike just compliance for anything I have asked of the bike and loads of positive feedback from tires and suspension, telling me its ok to add a little more speed/throttle each session/lap. Ducatis are expensive to fix so I dont want to crash at least as much as you, but the bike is telling me its OK to keep slowly increasing pace and I am happy to do so!! I feel like my current level should be at the 1:50 level but I have been approaching it cautiously. I will, of coarse, be careful not to risk my health and bike nor my fellow riders but I feel that this goal will fall with no danger to bike nor body. Should anyone disagree, Please speak up. I appreciate any concerns that may be expressed as I only know what I know and nothing more! Ride safe and thank you for listening/reading my babbling on about this stuff ![]() ![]() |
#258 | |
I have just been rereading many of the posts from all the helpful people and I believe you found my issue in your reply quoted in this post. Your story of riding Daytona and learning a new track. At Road Atlanta, I had to learn the track and bike while riding at mid group pace. I had to find multiple reference points just to prevent being a rolling road block for many faster, more experienced riders. With the blind entry to the chicane in the Esses and over the mountain, you better be going slow or on the right line at pace or things can go very wrong very fast--following a young lady that went straight thru chicane and onto the grass!!!!! I made the turn but she did not. I reread the quote from you below and realized what really was causing my issue. QUOTE that made me think: I went out for each practice session with a specific exercise to work on. First was Reference Points, in finding them and in drawing the track. I called Keith Code himself between sessions to talk through areas that I was struggling. Each session out I drew the track and added more RP's and before the final practice session of the day we compared may split times with everyone else's times (I was way off the pace) and chose the two corners where I was losing the most time. Those two corners also happened to be the corners I had the fewest reference points in. For the last session I worked on finding more and better RP's and in putting my vision together so I flowed from one point to the other. The next day was qualifying and I didn't have much practice time to step up and find several seconds of improvement. I did the same thing, systematically working on putting my visuals together until the qualifying session came and Keith Code said "ok, you've done your work, now just RIDE, relax and have fun." I let go of everything and focussed on being smooth, relaxed and in having fun. I kept shouting in my helmet, "I'm riding DAYTONA!!!!" and sure enough when I came in, I had managed to find the time needed to qualify for the race! My mind lit up reading this again as I realized that I dont/did not have any reference points between my corner exit and my brake marker for the turn at the end of the straight. I exit the corner at or near full throttle then point the bike down track and there is nothing until I get close to my brake marker!! With the longest straight having a kink(taken at full throttle over 100mph) I need to have a few more markers to keep me in the proper line to make the kink and then be in the proper track position to hit my brake marker. Just running this exercise in my mind brain, I can see that it will(and has at Road Atlanta) help me with this issue. I also realized that I have the same issue with rolling off over the hill at turn 6 at Palmer for the same reason. I do not have a good reference for cresting the hill and diving down to turn 7! Cant wait to get back to Palmer in 2 weeks to put this to the test. I have listed my current goals in the last 2 posts and this will make reaching my goal even easier! Thank you again Anthony |
#259 |
Final update before the Palmer Memorial day trip.
I have just returned from 3 days in the Hospital. Since I am apparently insane, I still intend to ride both days if my strength holds up. Unfortunately, the weather is forecasted to be cold and rain for the entire weekend. I am doubtful I can obtain my goals under these conditions but track time is experience and will just help me next opportunity. I may finally get a chance to try out the rain tires I purchased several years ago, they have been in shrink wrap in my "race Shop" since the Big Brown Truck dropped them on my door. Never ridden on rains so let the learning begin again!
I guess someone may want to know what happened that put me in the hospital for a few days. I could not sleep Tuesday night-not uncommon for me but this was a little different. Wednesday morning I was freezing and shivering but had no fever and my energy was super low. I tried to nap while covered with a blanket and wearing a hoodie in a 75 degree room. After a couple hours of this, i felt a little better- or so I thought- so I did a few light chores and I started to sweat. I kept feeling hotter and hotter (like the guy in Napolien Dynamite) until I was dripping sweat with all my clothes were soaked and this was with the aircon on max and a fan blowing directly on my for 2 hours. Wife drove me to emergency room and after hours of tests they could not find anything. They finally did a CT scan and I was rushed to a larger hospital to see a Urologist. The informed me that my Kidneys were/are infected and there is and abscess on one of them!!!!!!! ![]() Needless to say, many antibiotics and $10's of thousands of dollars later, I feel better and may have introduced my ER DR. to try out non sportbike days on the track!--Whoops- off topic again--The infection responded to the drugs and should totally clear up in a week or 2 after further- NON IV antibiotics. So thats my excuse if I cant reach my set goals this weekend and I can prove my case in a court of law!! Be safe and I will update for those who care, on Tuesday ![]() |
#260 | |
Misti
#261 | |
#262 |
Had to cancel both days at Palmer due to sickness. I may have been fine riding for at least one day but after unloading 10 bundles of roofing shingles from the truck so I could load the bike, I was too exhausted. I believe I would have been fine riding but after a day on the track I would still have to load up and then unload everything at home. I doubt I would have done my recovery any favors. I should have another chance at my goals and instituting the grate advice given her in September at the Labor Day event.
Last futzed with by Ducati999; June 3rd, 2021 at 07:05 PM. Reason: Spelling |
#263 |
Join Date: Jan 2016 Motorcycle(s): Ninja250 Posts: A lot.
That would be disappointing to have to cancel your track days, though it's probably better to conserve your energy for recovery and healing. I hope you're feeling better!
#264 |
#265 |
#266 |
Need more tire edge | Timr | Ninjettes At Speed | 16 | October 8th, 2014 02:45 PM |
grom over the edge at the gap | alex.s | Videos | 15 | June 24th, 2014 09:30 PM |
On the edge... | 2011Ninja250R | The Ex-Ninjetters Lair | 1 | October 8th, 2011 07:12 AM |
Living on the Edge | csmith12 | Ride Reports | 1 | June 12th, 2011 06:21 AM |
[twistingasphalt.com] - On the Edge of the World | Ninjette Newsbot | Motorcycling News | 0 | January 18th, 2011 09:50 AM |
