Old December 9th, 2012, 09:43 PM   #1
cuong-nutz
cuong-nutz's Avatar
Bike won't start
My bike started to not want to start towards the end of the the trackday sunday. I thought it was my battery, so I left it on the trickle charger. Tried starting it and it'll turn over not fire up and run.
I'm thinking I might need to readjust my valves again but I just recently did them about 3-4 months ago. The transmission has popped out of geara few times at the track so it's hit the rev limiter a bit.
Is there anything else I should look at before I tear down the bike again? Perhaps I need to get the battery tested.
HalfFast Racing Team
Old December 10th, 2012, 05:40 AM   #2
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
Spark Plugs?
My replies are intended for street riding only, plz do not provide track only replies.
Visit my new MotoVlog Channel !!
Old December 10th, 2012, 11:14 AM   #3
DaBlue1
Long Time Rider
DaBlue1's Avatar
Originally Posted by cuong-nutz View Post
....Is there anything else I should look at before I tear down the bike again?
Try swapping out the IC Igniter.
Old December 10th, 2012, 11:28 AM   #4
just doesn't want to start? has ok power when it runs though? or wont run at all?
need 4 things to go boom, fuel, air, compression and spark... check intake for something plugging it... make sure you are getting gas in there, and check spark... if you have a gauge, check compression too... this should give you a good idea of what is wrong before you try to tear anything open
if your battery is truly ****ed, it could be draining so much power even on the trickle charger that the igniter wont get proper power and will throw everything off... but if it will turn the motor over off the trickle i'd say its not completely ****ed.
Old December 10th, 2012, 11:28 AM   #5
Lychee
sail away
Lychee's Avatar
spark?, air?, fuel?, compression? I doubt its the valves unless you had idle problems prior to the no start issue.
edit: ha like alex said.
Old December 10th, 2012, 04:47 PM   #6
cuong-nutz
cuong-nutz's Avatar
Power seemed normal before it decided not to fire up. The plugs are fouled but there is spark and from all the gas fumes coming out of the pipes. Airbox and filter are clean too. Going to run to the auto parts and pick up some new plugs and see if they sell the adapter I need.
My compression tester doesn't have the right size adapter for these small plugs.
Old December 10th, 2012, 05:45 PM   #7
does changing throttle effect it?
post a video of what it sounds like when its cranking
Old December 10th, 2012, 11:23 PM   #8
cuong-nutz
cuong-nutz's Avatar
Got it to fire up for a little. It after numerous tries and jumping the battery. I have the choke on and was opening the throttle. When it fired up I opened the throttle some more.
Old December 11th, 2012, 10:08 AM   #9
ok well i dont think it would rev like that if the head was messed up or it was seriously down on comp... sounds like it might be some kind of electrical draw keeping it from sparking well... i would do a couple quick fuel tests... turn off the fuel tank, disconnect the carbs from the fuel line then drain each carb and make sure they measure about right, connect it up again and put the tank on prime for a minute, then off and disconnect it again and measure the carbs again... if its getting good fuel to the carbs i would try starting it with spraying some extra flamible stuff in the intake and see if it fires up right away... if it does i would investigate fuel supply more (jets clogged? intake leak?). if it responds similarly i would test all the major electrical components. (check for short on the main line, check main coils, pickup coil and stator resistance, make sure the cdi is receiving a good voltage power when cranking)
have you dumped and examined the oil yet? any time i have engine problems that's usually my first step. you'll know right away if its a small problem or something catastrophic. you can even send a sample to be tested and the different contents of metal will give you good hints on what problems the engine is facing
Old December 11th, 2012, 09:25 PM   #10
cuong-nutz
cuong-nutz's Avatar
I can't really tell much about the oil other than that it's really dark.
Seems like I'm getting adequate fuel through the bowls. One things is for sure though, I flooded the crap out of my cylinders. I had the spark plugs out and turned over the motor (didn't undo the gas lines) and fuel was spewing out of the spark plug holes and leaking out the exhaust header flange.
Old December 12th, 2012, 08:00 AM   #11
bruce71198
bruce71198's Avatar
The way it sounds on start up leads me to believe its a fueling issue. The fact that you have fuel spewing everywere leads me to believe its an over fueling issue. Check the floats, needles and seats. First though pull the vacuum line off for the fuel petcock and see if raw fuel comes out, you may have a ruptured diaphram in the petcock. When you get it figured out make sure to change the engine oil as it is surely contaminated with gasoline as well as the spark plugs.
Old December 12th, 2012, 08:09 AM   #12
bruce71198
bruce71198's Avatar
Old December 12th, 2012, 10:01 AM   #13
cuong-nutz
cuong-nutz's Avatar
I really am not looking forward to tearing out the carbs again. The airbox gave me hell last time.
Old December 12th, 2012, 10:11 AM   #14
it's easier if you take out the engine first
i would fill up the carbs with gas then turn off the petcock and and try starting it... if its overfueling it should start then stop after cranking for a few seconds. if you have a multimeter it only takes like 5 minutes to test all the electrics
Old December 12th, 2012, 11:48 AM   #15
Lychee
sail away
Lychee's Avatar
Cutting the battery box off the airbox saves me loads of time when removing the carbs on my pregen.
Old December 12th, 2012, 12:19 PM   #16
bruce71198
bruce71198's Avatar
Practice makes perfect, after a few times it become old hat ( whatever that means). I dont know what level your meachanical skills are but I work on a lot of stuff, at this point its all just nuts and bolts !! Try to look forward to instead it makes it more enjoyable.
Old December 30th, 2012, 10:30 PM   #17
cuong-nutz
cuong-nutz's Avatar
Got the 10mm adapter.
Last futzed with by cuong-nutz; December 31st, 2012 at 07:42 AM.
Old December 31st, 2012, 12:09 AM   #18
beninja
beninja's Avatar
Just for learning purposes, does this mean you have to replace the rings that go around the piston to regain compression?
beninja is offline   Reply With Quote
Old December 31st, 2012, 07:40 AM   #19
cuong-nutz
cuong-nutz's Avatar
Not necessarily.
If your rings are shot, you can try putting some oil through the spark plug hole to see if compression increases. If it doesn't increase than your valves aren't seating or are bent. You'll have to check your valves and see if they're in spec. and you can do a leak down test. which pressurizes the cylinder and checks to see if your valves are seated properly. If your rings are bad, you'll probably have to get the cylinder bored over and go with the next up oversized rings.
Old January 3rd, 2013, 07:46 PM   #20
cuong-nutz
cuong-nutz's Avatar
Unhappy
Wet compression test confirmed rings are shot. I had forgot to do this before checking the valve lash At least I know the valve lash is still within-spec.
Also, too much oil in the combustion chamber will kill your valve stem in your compression tester.
Options are "new" motor or bore over and bigger pistons.
Old January 3rd, 2013, 07:49 PM   #21
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
:/ get that 1 engine from mh its almost newish
THE GOOD LIFE
Old January 3rd, 2013, 08:18 PM   #22
cuong-nutz
cuong-nutz's Avatar
Yeah, it looks like the most plausible thing to do as doing an overbore won't be beneficial to me without upgrading the cooling system.
Old January 17th, 2013, 07:57 PM   #23
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Yeah sorry man I know even less about this stuff your dealing with then the members who have already posted. I was told on my 2 stroke to test its compression when its at operating temperature so that way everything is warm and in spec. This means riding it around for a few minutes then pulling the plug and testing. Is the test method different for a 2 vs 4 stroke?
My NSR50 has 2 full race seasons a 4hr and a 24hr endurance race on its original piston and rings and its still the fastest bike on track. Although the motor sound a bit sloppy it still makes 113psi.
Old January 17th, 2013, 10:56 PM   #24
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
According to my manual (08-12) usable compression range is 139-213 psi.
Possible causes for low compression is:
leakage from cylinder head
valve seating
valve clearance
piston/cylinder clearance
piston seizure
piston rings/ring groves
Valve clearance would be the first thing I would check. If that checks out might as well pull the engine and tear it down.
LoD575 is offline   Reply With Quote
Help!!!!!!!! - bike won't start auntymunga 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2014 06:54 AM
Bought first bike and 1 day later it won't start: do I have a junk bike? brendandubs 1986 - 2007 Ninja 250R Tech Talk 43 May 11th, 2014 07:59 AM
Bike won't start FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 127 November 17th, 2013 03:18 PM
bike won't start... nebraskan 2008 - 2012 Ninja 250R Tech Talk 4 May 11th, 2011 01:48 AM
