Old March 18th, 2021, 03:45 AM   #1
Based12
Motorcycle(s): 2010 Kawasaki Ninja 250R,
Valve shim size question
Hi! Just finished measuring my valve clearances and the leftmost exhaust one was at 0,08mm and had a 2.84 (misplaced the dot, sorry) shim inside.
How screwed am I? I´ve been looking at shim kits and it seems like most of them have a 1.20 as the smallest one, so am I going to need a valve replacement?
Thanks!
Last futzed with by Based12; March 18th, 2021 at 11:37 AM. Reason: Misplaced the dot on the shim measure
Based12 is offline   Reply With Quote
Old March 18th, 2021, 05:23 AM   #2
Are you mixing up millimeters with thousandths of an inch?
Old March 18th, 2021, 11:34 AM   #3
Based12
Oops, misplaced the dot on the shim measuring, sorry.
It seems like using a 1.2 shim (the smallest I've been able to find) it'll be in spec actually, so I'm thinking of placing it and changing that valve in the next valve adjustment.
Now my doubt is: is this approach correct? Or there's a worrying symptom I don't know about? The exhaust valve next to this one is at 0,16 mm right now, so still out of spec but not as far as the first one
Last futzed with by Based12; March 18th, 2021 at 11:38 AM. Reason: Explanation about the misunderstanding
Old March 18th, 2021, 01:19 PM   #4
Based12
Okay, I'm extremely dumb, I miscalculated because of the placement on the comma, so I bought the wrong shims and they're completely useless it seems
valve adjustment shim jcsalazar 2008 - 2012 Ninja 250R Tech Talk 15 October 10th, 2014 09:30 AM
Valve shim diameter? smokinsingle Ninjettes At Speed 2 February 8th, 2013 04:31 PM
Valve Shim help kamikaze 2008 - 2012 Ninja 250R Tech Talk 26 February 18th, 2012 12:22 AM
Valve shim exchange alex.s 2008 - 2012 Ninja 250R Tech Talk 1 December 8th, 2011 06:26 PM
valve shim exchange? pb3 2008 - 2012 Ninja 250R Tech Talk 1 August 22nd, 2011 11:01 AM
