Old April 11th, 2021, 01:36 AM   #1
Ninja09R
Motorcycle(s): Kawasaki Ninja 250R
Don’t know where these hoses connect to? Please help
Hello all,
I am having trouble finding where to connect these hoses to?
I will attached some pictures. If anyone could help that would be great!!
Sorry if this is a noob question. I’ve only been riding for around 4 months and this was my first time disassembling my bike.
Bike: Kawasaki Ninja 250R (2009)
Background; I removed the gas tank, fairings etc to remove and clean my carberator as i was told there might be an issues with it. I suspected this might be the problem.
After cleaning it, im having trouble connecting some hoses back into their original place.
File Type: jpg 31060A4E-2D64-43E0-B0B9-3740746151AB.jpg (134.1 KB, 17 views)
File Type: jpg 5EF506BA-5EFB-4B68-9B7F-DAF5FCED5793.jpg (123.0 KB, 14 views)
Ninja09R is offline   Reply With Quote
Old April 11th, 2021, 10:55 AM   #2
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Looks like the carb heater hoses. Under the front of each carb bowl, there should be a T piece with a short connector hose between them. There is an in & out port on the carbs which these hoses connect to. They feed warm coolant from the coolant circuit to stop the carbs icing up in cold moist air days.
Old April 14th, 2021, 06:38 AM   #3
Ninja09R
Thank you! Much appreciated.
Replace some of these hoses primetime00 1986 - 2007 Ninja 250R Tech Talk 4 September 27th, 2019 02:30 PM
Carb hoses skip 2008 - 2012 Ninja 250R Tech Talk 2 April 3rd, 2019 05:50 PM
2 hoses and chain Joshua95 2008 - 2012 Ninja 250R Tech Talk 12 April 28th, 2014 03:39 PM
Where do these vacuum hoses go? blackss06 2008 - 2012 Ninja 250R Tech Talk 2 April 11th, 2014 03:42 AM
Need help with vacuum hoses Jordan91 2008 - 2012 Ninja 250R Tech Talk 1 December 25th, 2010 09:57 PM
