Old September 6th, 2012, 02:52 AM   #1
arnoldc6
arnoldc6's Avatar
Motorcycle(s): 09 ninja 250r
My bike sorta has 12 gears.
Dropped her 2 weeks ago since then she had been working pretty weird.
Once in a while i can't even start the engine, and sometime when i tired to downshift from Neutral to first gear i still ended up with neutral...often have to step on it multiple times to down shift to first gear. Sometime when i am at 2 gear it would drop down to neutral too, although this had been happening for quite a while and i reckon that might simply be because i am not kicking it hard enough (doesn't had any problem with other gears tho, odd enough).
What should i start checking for? I am by all means no mechanic but to me it seems like it has something to do with either engine or gear box.
Or both?
"trust me, I am not a lawyer."
arnoldc6 is offline   Reply With Quote
Old September 6th, 2012, 05:23 AM   #2
oblivion007
"scandal!"
Motorcycle(s): 2011 250R(Crashed 2/26/2014), 09 ER6n
Is the shift lever properly attached? Maybe it loosened up with use and dropping it loosened it some more?
oblivion007 is offline   Reply With Quote
Old September 6th, 2012, 09:43 AM   #3
for one, be gentle on the shifter. When you get stuck in neutral and it won't go down to first, let the clutch out just to the beginning of the friction zone, and tap it down like normal into first. It will drop into first nicely. Bashing on the shift lever is a great way to bend shift forks and need tranny work.
Old September 6th, 2012, 03:36 PM   #4
adjust the positioning of the shift lever to make it easier.
Old September 9th, 2012, 02:11 PM   #5
arnoldc6
arnoldc6's Avatar
Just replace battery and it still isn't starting smoothly.
Like it would make a Pop sound (exhaust?) and dies..without choke, best is that it starts, rumble a little and dies.
Thought it might be a dirty carb but none of those too rich/lean systoms exist besides hard to start...might be a motor thing i guess.
Man there's a lot to learn about bike maintaince..
Old September 9th, 2012, 02:14 PM   #6
it would probably start great after a valve adjust, oil change, carb cleaning and sync
Old September 9th, 2012, 04:11 PM   #7
arnoldc6
arnoldc6's Avatar
Did my oil change a week ago...so carb it is then.
Hope my baby is good.
Old October 10th, 2013, 03:42 AM   #8
Insan3guy
Insan3guy's Avatar
Motorcycle(s): 2015 zx6r
Or both?
my bike really likes being in neutral, so it's become somewhat of a habit for me. at a stop, hold the clutch in and press down on the shifter and keep pressing down while simultaneously letting the clutch out until it just barely clicks into gear. you don't need to hammer on the shifter, just need to coax it a bit... give it a little lovin'
edit: extreme facepalm. timestamp is 2012, not 2013
Insan3guy is offline   Reply With Quote
[motorcycle-usa.com] - Gettysburg Bike Week Gears Up For 14th Year Ninjette Newsbot Motorcycling News 0 March 2nd, 2015 11:23 PM
How the gears of your bike were made Motofool Videos 13 July 17th, 2014 07:08 AM
My bike has too many gears:/ JohnnyBravo 2013 - 2017 Ninja 300 Tech Talk 34 January 23rd, 2014 09:14 AM
What's up with my bike? Dropping gears Trailerboy531 2008 - 2012 Ninja 250R Tech Talk 15 June 25th, 2011 12:06 PM
[topix.net] - Charity Bike Ride Gears Up For Good Cause Ninjette Newsbot Motorcycling News 0 August 7th, 2010 08:30 PM
