Old May 23rd, 2014, 10:08 PM   #1
psych0hans
psych0hans's Avatar
Different take on a quick action throttle.
Hi guys, as most of y'all know, the easiest way to get a quick action throttle is to go in for a throttle tube with a larger cam. There is also the lesser known and used way of modifying your throttle junction and installing a stroke multiplier there. I've placed an order for a junction stroke multiplier, from http://www.allensperformance.co.uk/p...throttles.html, which has a ratio of 1:1.33. This means that for every one mm of throttle pull, this will amplify that to 1.33mm. I've already done an R6 throttle mod, using an 06 R6 throttle, housing and custom cables. So I didn't want to futz about with the throttle tube anymore. Also, my experience with the zip-tie mod was less than satisfying on my original throttle(I'm an expert at screwing things up).
Does anyone have any experience or knowledge about this mod? I would love your input on the same.
P.s. This is a track only bike, so street ridability isn't of any importance.
Old May 23rd, 2014, 10:36 PM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
I think one of the motion pro style throttle sets has one of these built into it but if I remember right it was a single cable 2-stroke setup. Would you need one of these for each cable?
The idea is simple enough but I'd take some serious measurements because I'm thinking the 1.77 would be more the ticket for this slow ass bike.
The largest cam in my motion pro setup is like the bare minimum of what I wanted and it dwarfs the Cam on the R6 tube. It's more a issue with street riding because you are on the bike much longer then on the track but if you shorten the rotation by half your throttle gets twice as hard to physically turn. It just like cutting your breaker bar in half and trying to turn the same nut.
Old May 25th, 2014, 09:38 AM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I'm not sure how reasonable it is to swap/mod, but another item to look at is the wheel on the carb. The wheel on the throttle tube is like the front sprocket, the wheel on the carb is like the rear sprocket, and the throttle opening is equivalent to the wheel turning. You can make the final output faster by making the first one bigger or the second one smaller.
My '09 500 uses the exact same throttle tube part number as the later PreGens, so the carb wheel must be quite different to get the massive difference in action between the two bikes (my 500 is 1/4 turn).
Old May 25th, 2014, 10:33 AM   #4
what i did was to go get a dirt bike throttle with a microscopic throw (massive cam) then i took my stock throttle housing and cut a slot on the top so that the massive cam could fit (it sticks out the top of the box) and then the cut goes back about an inch so it can pull on the cable. now i have full throw at about 75 degrees rotation
Old May 29th, 2014, 04:49 AM   #5
mgentz
Board Member
The MP 50mm cam still has a little too much total rotation for me, but it is light years ahead of the stock throttle.
To Rojo's point though, I have this cam with the CR carbs and the throttle is hella hard to turn because of the ratio and the massive spring on the CR carbs.
Old May 29th, 2014, 05:13 AM   #6
psych0hans
psych0hans's Avatar
Weren't you going to print your own throttle?
Also, I'm not entirely sure how I'm gonna use it... The guy who sold it to me doesn't reply to emails and speaks in a very heavy English accent so I can barely make out what he says... *sigh*
Paging @akima, any chance you could call and talk to him for us please? Pretty please?
Old May 29th, 2014, 05:20 AM   #7
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
Bad idea to do this to my zx6r?
Old May 29th, 2014, 05:21 AM   #8
psych0hans
psych0hans's Avatar
I suggest you wait and let me be the Guinea pig first
Old May 29th, 2014, 05:24 AM   #9
nickjpass
#squid
nickjpass's Avatar
MOTM - Jul '16
I hate regripping the throttle. Hurts my wrist to turn that far if don't regrip.
Old May 29th, 2014, 05:36 AM   #10
psych0hans
psych0hans's Avatar
Try it if you like, it only cost me 12£ shipped to india...
Old May 29th, 2014, 07:06 AM   #11
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Sure, I can give him a call if you like. I'm a mechanical noob, so you'd have to give me very specific questions to relay!
It's 3pm over here and he probably closes shop between 5 and 6pm.
Old May 29th, 2014, 07:07 AM   #12
crazymadbastard
I'm crazy,your excuse is?
crazymadbastard's Avatar
Motorcycle(s): 250 2007 ninja
I would consider cutting the carb cam and shortening the radius before complicating the whole cable system.
My Cafe Racer Build
My intro post
Old May 29th, 2014, 07:10 AM   #13
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Just noticed this Suzuki on his website:
Interesting tail! Haven't seen anything like that before. Makes me think of thunderbirds for some reason.
Apparently it has "magnesium bodied VM's". I know you can get really light, magnesium wheels. What's a VM?
Old May 29th, 2014, 07:41 AM   #14
mgentz
Board Member
I think he's talking about the carbs. Mag is brownish in color and if you look at the picture, the carbs are brown.
Old May 29th, 2014, 09:49 AM   #15
Vintage Smoke
The 2 Stroke Ninja!!
Vintage Smoke's Avatar
Motorcycle(s): 2010 250R, 1977 RD400, 72&73 RD350 75 RD200
The VM is a series of carb made by Mikuni since the 70's. It is probably the most mass produced carb in history used on everything from dirtbikes to street bikes to snomobiles. Available in both 4 stroke and 2 stroke versions.
Vintage Smoke is offline   Reply With Quote
Old May 29th, 2014, 09:52 AM   #16
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Ahhh, thanks you too.
Old May 29th, 2014, 10:10 AM   #17
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
got a pic of that? that might be my next modification.
TEAM ALFALFA
www.apexassassins.com
Old May 29th, 2014, 10:38 AM   #18
psych0hans
psych0hans's Avatar
1) how does it work?
2) will it work with a push/pull throttle?
3) will it work on a ninja 250?
4) how is it installed?
5) are any modifications needed?
Thanks akima
Old May 29th, 2014, 10:56 AM   #19
in the works.
i'll post one in a bit
Old May 29th, 2014, 11:09 AM   #20
akima
Nooblet
akima's Avatar
MOTM - Oct '13
@psych0hans - noted. I'll ring on Saturday. If he's not around I probably wont be able to ask those questions until Tuesday.
Also: was it you that asked for my Power Commander map? I haven't actually got a map created yet (which is probably very bad for the engine!), but even when I do, you might not be interested anymore as I never installed the K&N pod filters. I decided to just install a K&N slot-in filter that goes in the stock airbox. I was advised the pod filters would be less resistent to rain... and we get lots of rain.
Old May 29th, 2014, 11:15 AM   #21
Old May 29th, 2014, 11:29 AM   #22
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
what bike did you get the cam off of? and other then the cam and cutting, did you have to do anything else?
TEAM ALFALFA
Old May 29th, 2014, 11:32 AM   #23
the cam i used had only one cable attachment so i don't have a forced return cable (safety hazard here) but i used some random dirt bike tube from cyclegear that i bought for $5
Old May 29th, 2014, 11:33 AM   #24
p.s. the housing was cut for the stock cam. you can see with the bigger cam it basically cuts it almost in half
Old May 29th, 2014, 05:16 PM   #25
mgentz
Board Member
hmmm. I have the MP 50mm cam on mine and I still need to overgrip it like a dirt bike.... :shrug:
Old May 29th, 2014, 07:33 PM   #26
psych0hans
psych0hans's Avatar
Hi akima, that would be fantastic thank you. I'm in no real hurry, so take your time .
Also, yes, it was me who wanted the map, but I read your post where you said you wouldn't be installing the pod filter, so I didn't ask again cheers!
Old May 30th, 2014, 04:41 AM   #27
psych0hans
psych0hans's Avatar
Hi Hansveer
dont know what the set up is on your bike if its two cables from the carbs you need to put the muliplier of if you have single throttle cable from the throttle put it in there,the only problem you may have is clearance to fit it.
Hope this helps
Dave
Allensperformance
Anyone understand this? I don't...
Old June 3rd, 2014, 10:31 AM   #28
akima
Nooblet
akima's Avatar
MOTM - Oct '13
Tried getting through to them 3 times today, but no luck. I had the questions all written out and everything!
Will try again soon.
Have you had any other response to your email yet?
Have you tried looking for a youtube video of the product? There might be an installation or review video out there with useful info in it.
Old June 4th, 2014, 12:42 AM   #29
psych0hans
psych0hans's Avatar
Thanks akima! That's the only response I got, unfortunately.
Old June 21st, 2014, 01:09 AM   #30
psych0hans
psych0hans's Avatar
New reply and pictures...
Originally Posted by dave@allensperformance.co.uk
Hi Hanaveer
you need fit to the pull side and the push shut side in the cable so you can have the same a mount of ajustment on both sides.
Hope this helps
Dave
Allensperformance
Once again, I have very little idea of what he wants me to do... Anyways, pics... Can anyone understand how this would work? @rojoracing @alex.s @mgentz
Old October 9th, 2014, 08:46 AM   #31
akima
Nooblet
akima's Avatar
MOTM - Oct '13
@psych0hans
I phoned through a bunch of times a while ago but each time I phoned they were either out or no one picked up. I remembered this thread today and gave one last call and got through to a guy called Dave.
I told him you have fitted an '06 R6 throttle and he didn't seem to think that affected the situation.
So questions and answers below...
>>> How does it work?
He replied: "You run a cable into one end of this thing from the throttle and you run a cable into the other side of this thing from the carbs." It adds leverage so smaller movements of the throttle are needed to get the same effect.
>>> Will it work with a push/pull throttle?
Replied "should do"
He said the pull cable opens the throttle and the push cable means when you close the throttle it closes the butterfly valve. He said this push/pull design and its use of springs means that if a cable breaks butterfly will still be closed.
>>> Will it work on a ninja 250?
"yeah - it should fit anything"
"it's not model specific"
"universal part"
At this point he was just trying to tell me to relay that you should be very careful. He seemed worried that you'd get it wrong and make the bike dangerous.
I think he was trying to tell me that if you wired it up wrong it can result in the butterfly valve not automatically closing if a cable breaks.
I asked him that and he again re-iterated "just be careful"
He said you have to cut the throttle cable to fit this thing.
He said that there should be 2 cables going to the throttle. I think he said that only the pull cable should go into this thing and the push cable should be left as is.
I think he gave up trying to explain it to me (probably because I'm a mechanical tard) and suggested that you might be best off putting on a simpler system like a "Hairy R's" quick action throttle.
http://www.hairy-rs.com/
He said that Hairy R's are much easier to fit. They come with instructions telling you what to do, so you don't have to be so knowledgeable.
Best I can do
Old October 9th, 2014, 07:01 PM   #32
psych0hans
psych0hans's Avatar
Thanks Akima, I really appreciate the effort This helps tremendously and I believe I might actually be able to install it after reading this. Thank you so much!!!
Old October 10th, 2014, 12:09 PM   #33
akima
Nooblet
akima's Avatar
MOTM - Oct '13
No problem
R6 Quick turn throttle tubarney 2008 - 2012 Ninja 250R Tech Talk 59 September 6th, 2014 12:55 PM
Motion Pro quick turn throttle rojoracing53 2008 - 2012 Ninja 250R Tech Talk 43 May 28th, 2013 07:18 AM
[sportrider - latest stories] - Yoyodyne Quick-Turn Adjustable Throttle Ninjette Newsbot Motorcycling News 0 December 30th, 2010 01:11 AM
09-09 250r quick throttle tube stroked59 2008 - 2012 Ninja 250R Tech Talk 18 June 25th, 2009 11:09 PM
Dan Kyle's Quick turn throttle question Gregular 2008 - 2012 Ninja 250R Tech Talk 7 February 28th, 2009 03:14 AM
