Old March 29th, 2019, 05:02 PM   #1
Cep
Stock Brake lever too low , can it be adjusted ?
Can the brake lever be adjusted up ?
Was about to order adjustable levers but my main issue is I feel the lever is too far below the throttle. I'd like it to be a little higher. I haven't taken a real close look but can it be adjusted at all? And as far as adjustable levers, they can only be adjusted closer / further out correct?
Cep is offline   Reply With Quote
Old March 29th, 2019, 05:50 PM   #2
Dave Wolfe
CCS Amateur #501
Dave Wolfe's Avatar
Motorcycle(s): '09 250 SE 'Booger'
Yep, loosen the two bolts on the master cyl and adjust to your liking. Make sure the lever doesnt hit anything when you twist the bars side to side.
Dave Wolfe is offline   Reply With Quote
Old March 29th, 2019, 05:50 PM   #3
Cep
Thank you
FS OEM stock clutch lever and brake lever Shaol1n Monk Motorcycle-related 0 July 17th, 2011 06:36 PM
WTB: stock exhaust, brake lever, reservoir cover Godzilla35 Items Wanted 5 March 24th, 2011 10:23 AM
stock brake master and lever sharky nrk Items Wanted 0 July 27th, 2009 05:52 PM
