Old July 3rd, 2019, 10:10 PM   #1
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
Oil in front wheel bars
Hi guys i got a time i don't visit the forum, but now im visiting the forum with a problem
The monday i was riding the ninja and when i pass a bump or a bad place i hear like a screech, before that i saw the left bar that conect the wheel, where is the speed cable got oil, i was thinking that oil was from the seal of the bars, but i change the seals like 6 months ago, i put some pictures to you can see the oil.
the balls inside the bar that connect the wheel use oil or not? idk
i hope and it is not a serious problem
Darksik is offline   Reply With Quote
Old July 4th, 2019, 05:59 AM   #2
Snake
Snake's Avatar
Even though your fork seals are only 6 months old they can still leak. Leaked can be caused by dirt and debris that collect on the forks, build up and then cause a leak by getting trapped underneath the seals. For this reason you should always wipe off your forks before and after a ride. The seals can be cleaned out with a seal cleaning tool made of thin plastic or you can make one by cutting a plastic milk jug. I will try and find a link for you.
Old July 4th, 2019, 06:03 AM   #3
Snake
Snake's Avatar
Here it is with a video. https://www.youtube.com/watch?v=8wlzfoVroSY
Like I said, you can also make one.
Old July 4th, 2019, 06:11 AM   #4
Can you tell where the oil is coming from? If not, clean the area thoroughly and then watch to see where it comes from.
Old July 4th, 2019, 11:41 AM   #5
Could be just some grease from speedo drive, melted by heat.
Clean it really well and it should not come back.
Last futzed with by DannoXYZ; July 4th, 2019 at 11:02 PM.
Old July 4th, 2019, 12:29 PM   #6
ducatiman
ducatiman's Avatar
Fork seals certainly are not "forever". Even replacement can offer fitment issues....specifically....
On my then 18 year old Honda VFR, I replaced leaking fork and dust seals with All Balls brand, using their correct part # application for my VFR....INSTANT weepage/leakage. decided to acquire OEM Honda seals...problem solved. There was a tiny size differential not discernible by eye....lesson learned...never again aftermarket fork seals on any of my stuff. OEM only. Way too much labor to justify "do-overs".
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old July 4th, 2019, 01:32 PM   #7
Snake
Snake's Avatar
I’m still betting that the fork seals are leaking.
Old July 4th, 2019, 01:53 PM   #8
ducatiman
ducatiman's Avatar
hmmmm, the damper bolts have copper washers for sealing purposes ....leaking there perhaps? Were those bolts removed and washers *reused* or replaced during initial fork service?
hey @Darksik....any fork oil present when you carefully inspect or wipe the actual fork tubes? Is the leakage grease or fork oil?
The outside of the lower tube is a bit of a stretch for speedo drive grease to migrate to, but a leaky copper seal washer on a damper bolt...hmmmm.
Custom Carb Service
Old July 4th, 2019, 11:02 PM   #9
Hmm, looking closer at photos, it appears the oil that's on there is quite old with lots of dirt and dust on them.
Suppose it's possible this is first time OP's noticed it and it's been there all this time?
I still say clean entire fork, completely clean. So clean that you can lick it and not taste any oil. Then watch for oil leaking from above starting at seals.
Old July 5th, 2019, 06:13 AM   #10
A couple people have suggested that already but have not heard back from @Darksik yet.
Old July 5th, 2019, 12:13 PM   #11
Darksik
Darksik's Avatar
Sorry to answer late, but what is strange is that I had never heard that noise last Friday, until tomorrow I have time to clean the motorcycle bar, to see if it is not leakage or is what came when the seal was leaking oil
Old July 5th, 2019, 01:47 PM   #12
Noise is not related to oil leak.
Leak has happened for long time, months if not years.
Well, might be caused by low oil-level inside fork.
Old July 5th, 2019, 02:06 PM   #13
ducatiman
ducatiman's Avatar
44045 GASKET,FORK CYLINDER BOLT 44045-051
they ain't callin it a gasket for nuthin'
I'll wager they were reused, not replaced in prior fork seal service, heck the damper bolt may even be loose! Worth a look in the online parts microfiche.
Custom Carb Service
Old July 5th, 2019, 03:25 PM   #14
Also probably didn't use torque-wrench on that bolt. Copper's soft and deforms to seal, but you have to squeeze it minimum amount. I've seen brand-new ones leak when not torqued enough.
Old July 5th, 2019, 03:34 PM   #15
It's all just speculation until Darksik cleans it to see where the oil is coming from.
Old July 5th, 2019, 07:41 PM   #16
Snake
Snake's Avatar
Oil seal and dust seal front bars Darksik 2008 - 2012 Ninja 250R Tech Talk 3 March 13th, 2019 06:03 AM
