June 27th, 2009, 11:38 PM | #1 |
Join Date: Feb 2009 Motorcycle(s): '91 Honda CBR600 F2 Posts: A lot.
Make sure you tighten your bolts!!!!
Well folks, I'm somewhat mad at myself. Long story short, I was going to take my sister somewhere on the back of the bike, and she found out for me that something was missing. The bolt that holds on my left passenger peg, and holds up my left exhaust pipe apparently fell out. My peg is completely gone, as is the small bracket that holds it and lets it fold in/out. I immediately got in my parent's car and bought some new bolts (just replaced both sides temporarily until I get the AP exhaust and some new rear pegs ). My bike is fully intact now and I'm going to double-check all the rest of my bolts tomorrow after I change the oil. I also retraced my ride of that day to see if I could at least find the peg. No luck. Just thought I'd share that and make sure you all remember to tighten all your bolts.
1991 Honda CBR600 F2, White/Gray, D&D slip-on exhaust, tail integrator, gel grips, Custom undertail. |
June 28th, 2009, 01:05 AM | #2 |
Join Date: Jan 2009 Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock Posts: A lot.
healthy reminder there definately!
dont want that sorta thing happening oh...like in the middle of a CORNER or sumptin. i've gotten into the habit of recheck'in hardware after some miles to make sure stuff's still there.
Remember when sex was safe and motorcycles were dangerous? |
June 28th, 2009, 07:35 AM | #3 |
Join Date: Jun 2009 Motorcycle(s): 2007 EX250 Posts: 178
Fasteners I've found loose:
Engine mounting bolt nuts Clutch cover Chain adjusters everyone should go over the whole bike once in a while |
June 28th, 2009, 07:43 AM | #4 |
Yup - I've lost a fairing bolt somehow - ordering some tonight - let me know if anyone needs anything
June 28th, 2009, 08:27 AM | #5 |
Join Date: Jun 2009 Motorcycle(s): 1996 Ninja 250 Posts: 5
You most def check the engine mounting bolts... I've found mine sticking about 2 inches out after a ride... may want to locktite them
June 28th, 2009, 09:20 AM | #6 |
Join Date: Dec 2008 Motorcycle(s): 2008 250r (Fastest Color) Posts: 914
Ive lost 2 axel bolt covers (I dont like the design, they pop in too easy and therefore pop out too easy) Also lost a bolt that holds on my Zartan exhaust hanger.
Everyone go outside and tighten everything now(Ill re-tighten the bolts that hold my head to my neck cause I think im losing my mind with all these missing pieces...anyone know what I should torque to? |
June 28th, 2009, 10:31 AM | #7 |
Join Date: Jun 2009 Motorcycle(s): 2009 Ninja 250 SE Posts: 338
Prefix: I know next to nothing about mechanics but I'll ask anyways.
Is there any advantage to putting some bolt/nut holding product like LocTite on everything to remove the need to check so often?
2013 CRF250L 1985 GL1200 Interstate |
June 28th, 2009, 10:35 AM | #8 |
Loctite is a great solution, and for bolts that are supposed to stay put, it's almost always a great idea. Use the blue stuff if it's on a bolt that may have to be removed at some point, but if it's a bolt that won't need to ever come out for the life of the bike, you can consider using the red strength.
June 28th, 2009, 10:57 AM | #9 |
Join Date: Jun 2009 Motorcycle(s): 05 Ninja EX250R Posts: 156
I was coming to a stop one day when I first got the bike. No biggie. I popped it into neutral at this LONG light.
Light turns green... I go to pop her in first and commence the take off. good deal. now for second and wait... wtf is this? It's sooooo loose? I pull into the first turn I can safely in first gear and take a look. One of the bolts that hold that assembly on where the left side foot peg is vibrated out and fell out somewhere. I pulled out the toolkit and checked everything out. The other bolt was loose a bit so I took that bolt out, put it into the top hole and tightened the ever loving crap out of it. Then I gave it a once over and nothing else was loose. Just my story. That tool kit saved my tail.
June 28th, 2009, 11:01 AM | #10 |
Join Date: Nov 2008 Motorcycle(s): 2007 Ninja 250 Posts: 469
Great advice.
Now, if someone will post a safety wire article, that would be great. I want to safety wire my oil plugs...
"This is my Ninja. There are many like it, but this one is mine..." ~ Purspeed (ca. Nov, 2008) |
July 12th, 2009, 11:53 PM | #11 | |
Join Date: Oct 2008 Motorcycle(s): 08 250 R Posts: A lot.
Hi M-Oorb, Did you use the nylock nut with the hanger kit and it still backed out?
"Don't let adverse facts stand in the way of a good decision" Colin Powell |
July 13th, 2009, 07:25 AM | #12 |
Which way to tighten clutch and throttle cable locknut? | chsonnu | 2008 - 2012 Ninja 250R Tech Talk | 3 | April 14th, 2013 08:34 AM |
Tighten the steering stem nut, please tell me how | coelgrim | 2008 - 2012 Ninja 250R Tech Talk | 23 | December 29th, 2012 03:24 AM |
I just wanna tighten my chain! | poo poo | 2008 - 2012 Ninja 250R Tech Talk | 5 | July 23rd, 2011 04:05 PM |
how tighten mirrors? keep blowing back | dimeified | 2008 - 2012 Ninja 250R Tech Talk | 8 | March 20th, 2010 11:41 AM |
d-oh... didnt tighten the oil cap -.-! | wayanlam | 2008 - 2012 Ninja 250R Tech Talk | 13 | November 20th, 2009 11:54 AM |
