Old May 13th, 2013, 04:14 AM   #1
pomartin
pomartin's Avatar
Motorcycle(s): 08 Ninja 250R (FI)
did u notice any change when you done your valve job?
Hy
just wondering.. what should i expect from it(how will it affect engine)?
Have never done valve job before and im curious
Tnx
pomartin is offline   Reply With Quote
Old May 13th, 2013, 05:14 AM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Waited till 12,000 miles for my first valve job and had to adjust 7 valves one step and 1 valve 2 steps. After it was done I noticed nothing as far as performance, response, cold starting or sound. The bike just simply went on its merry way running like a champ.
Old May 13th, 2013, 06:43 AM   #3
lgk
probably shouldn't expect anything, unless the motor was in bad shape.
Old May 13th, 2013, 06:56 AM   #4
pomartin
pomartin's Avatar
tnx
bike is maintained as prescripted.. only thing wich is bothering me is that there was no valve addjustement at 12000 km (~8k miles)...
at kawasaki service they told me that they stopped checking valves at this mileage, as no bike so far needed adjustement.
in a week or so i will hit 24000km (~15k miles) and will need to adjust valves..
sry for lame question, again.. i was just curious
Old May 13th, 2013, 08:30 AM   #5
lgk
Whens the last time you had your throttles synced?
Old May 13th, 2013, 08:50 AM   #6
Originally Posted by pomartin View Post
Hy
We don't notice much change, but the valves do, because they cool down much more when their gaps are as they should.
They have more time touching their seats, close to which the coolant flows.
The reason for periodic service is that, with wear, the gaps get smaller and the cooling time gets shorter.
In extreme cases, the valve remains semi-open, getting burned by the hot gases that leak through.
Check these explanations for pre-gen Ninjettes:
http://faq.ninja250.org/wiki/Why_do_...be_adjusted%3F
http://faq.ninja250.org/wiki/What_ar...ance_ranges%3F
Old May 13th, 2013, 12:52 PM   #7
pomartin
pomartin's Avatar
@Motofool tnx
@lgk i have never had throttles synced... in other words.. this means that i have to check that both "plates" in fi system opens at the same time?
edit: also, are acceptable clearance ranges on motofools link good for 08 250r too?
Old May 13th, 2013, 12:58 PM   #8
Chicagobob
Chicagobob's Avatar
Motorcycle(s): '06 Ninja 250, 2018 Honda GL1800B
Mine was noisier (more valve clatter), idled more smoothly and ran cooler.
Chicagobob is offline   Reply With Quote
Old May 13th, 2013, 01:05 PM   #9
lgk
@Motofool tnx
not so much that both are opening at the same time (both plates are operated by same shaft), its matching the airflow going through both cylinders.
usually fixed by adjusting idles screws, throttle stop, etc. with a pressure differential manifold.
the EFI probably doesnt need it done as much as carbs but still worth a look at 15k miles.
Old May 13th, 2013, 01:26 PM   #10
pomartin
pomartin's Avatar
ok.. will take a look at it too.
but first... learn something about it xD
tnx
Old May 13th, 2013, 02:20 PM   #11
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
When I did the valve adjustment, I had to adjust 3 valves. I put everything back and the bike ran fine.
However a week after I did the throttle body sync and they were way off. When I balanced them I acutally had to adjust the idle because when it was balanced it raised the idle. Took it to the track this weekend and it performed well.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old May 13th, 2013, 02:35 PM   #12
pomartin
pomartin's Avatar
hope Ill mannage how to do it... if not, it will be mechanics problem :P
Old May 13th, 2013, 04:33 PM   #13
if a valve is more than 3 or 4 sizes out of spec and really making some magical noises, it will perform pretty ******. i've done valves on a bike that was having some issues wouldn't idle right, skipping in the middle, after the service and sync it ran like a new bike. it was the bikes first service, but wasn't done til like 14k
milky/yellow oil after a valve job quanttrom 2008 - 2012 Ninja 250R Tech Talk 24 March 31st, 2012 04:39 PM
Valve job @ 2300 miles and... Socal5646 1986 - 2007 Ninja 250R Tech Talk 14 October 21st, 2011 08:32 AM
tire valve core - do you change it ? tac12345 2008 - 2012 Ninja 250R Tech Talk 12 March 8th, 2011 05:48 PM
Ideas for saving $ on valve job? Bring in naked & do oil myself? Anything else? CZroe 2008 - 2012 Ninja 250R Tech Talk 10 December 8th, 2010 08:12 PM
VERY, loud clicking after valve job headshrink 2008 - 2012 Ninja 250R Tech Talk 50 June 22nd, 2010 05:11 PM
