May 16th, 2014, 07:43 AM | #1 |
Join Date: Jun 2013 Motorcycle(s): 2010 ninja 250 se Posts: 20
2010 Ninja 250 Tach/sputtering problem
Hello Fellow riders. My bike is now around 4000k. As soon as I hit 60mph, the tach went crazy and many time went all the way to the end of the red mark. IF i went back down below 60mph, then there is no problem. HOwever if i want to go back up to 61mph +, the throttle went all the way but the speed is not going up. THen if i release the throttle to slow it down, the bike sputtered.
I am going to check filter, spark plug, any obstructions. I want to know could it be the CDI? WHere can I get an aftermarket one? Thank you so much! |
May 16th, 2014, 07:47 AM | #2 |
Also check your battery voltage and battery connections.
I believe there's a connector under the tank that supplies power to the gauges, I'd check that as well. |
May 16th, 2014, 08:09 AM | #3 | |
See these threads https://www.ninjette.org/wiki/Battery - if your lights on the Ninja 250 begin to flicker or your gauges or engine speed start to act erratically, check your battery connections https://www.ninjette.org/wiki/Ignitor_problem https://www.ninjette.org/forums/show...3&postcount=21 |
May 16th, 2014, 09:38 AM | #4 |
Track Clown
MOTM - Sep '15
Shooting wild here, but you still have your clutch engaged at that point right?
2010 Kawasaki Ninja 250 problem | Revlimiter | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 29th, 2015 08:23 PM |
2010 ninja 250 roaring toyz lowering link problem | Beensoon | 2008 - 2012 Ninja 250R Tech Talk | 30 | September 1st, 2011 04:20 PM |
My Tach is still dead, common problem.. | JoeLansing | 2008 - 2012 Ninja 250R Tech Talk | 10 | August 4th, 2011 09:10 PM |
