Old May 13th, 2015, 08:13 PM   #1
Lemonfresh
Motorcycle(s): '10 Kawasaki Ninja 250ARRRR (Sold), '13 Kawasaki Ninja 300 (Crashed), '07 Triumph Daytona 675
WTB: Bent 300 Forks
I am looking for a pair of bent forks from a 300. Specifically, I am looking for the damper rods. If you only have one you are willing to part with, let me know. PM me with shipped price.
Thanks.
Last futzed with by Lemonfresh; May 13th, 2015 at 10:22 PM.
Lemonfresh is offline   Reply With Quote
Old May 13th, 2015, 09:42 PM   #2
Ghostt
Ghostt's Avatar
I might have a pair of damping rods from my pre 94 EX500, which is the same as PreGen Ninjette, let me check, if your interested. Part # 44022 right?
violente et ignorantia
ZX-2R BLOG
Old May 13th, 2015, 10:18 PM   #3
Lemonfresh
That is the part I am looking for. Checking part numbers now, it seems the 500, pregen, newgen, and 300 all have different part numbers.
The 500 has 38 mm forks while the 250/300 have 37 mm. I can't say either way if the damper rods are the same or not but the part numbers for each are different.
Old May 13th, 2015, 10:21 PM   #4
Ghostt
Ghostt's Avatar
Well let me know, and I'll see if I can dig them up.
ZX-2R BLOG
Old May 13th, 2015, 10:44 PM   #5
why would anyone want bent damper rods
Old May 13th, 2015, 11:26 PM   #6
Ghostt
Ghostt's Avatar
1st Gen EX pre 94 have 37mm forks
ZX-2R BLOG
Old May 13th, 2015, 11:27 PM   #7
Ghostt
Ghostt's Avatar
He looking for the guts from a bent pair of forks.
ZX-2R BLOG
Old May 14th, 2015, 06:44 AM   #8
wont they be bent?
Old May 14th, 2015, 07:50 AM   #9
Ghostt
Ghostt's Avatar
wont they be bent?
Most cases only the upper tube part # 44013 is bent, the guts are in the lower tubes part # 44005.
ZX-2R BLOG
Old May 14th, 2015, 08:46 PM   #10
Lemonfresh
With different part numbers I am guessing the rebound damping hole is a different size to accommodate the higher weight of the the 500. Or it might be different size compression holes. Tough to say, they are probably not the same dampers though.
Old June 18th, 2015, 05:27 PM   #11
Lemonfresh
Still looking for a set of bent forks or at least the damper rods from a 300.
Does anyone have a pair laying around they could at least put some pin gages in and find the hole size?
Last futzed with by Lemonfresh; June 20th, 2015 at 07:39 AM.
Old June 18th, 2015, 10:33 PM   #12
Hasersys
Hasersys's Avatar
Motorcycle(s): Have owned Ninja250,EX500,Xj650,RD250,XV750
I know this is off topic, but anyone know if the 500 tubes fit the newgen bottom halfs? I have newgen bent forks and was wanting to see if I couldn't use some 500 tubes.
Hasersys is offline   Reply With Quote
Old June 27th, 2015, 01:06 AM   #13
Fastway Racing
Motorcycle(s): LOTS! 14 -675R Daytona, 13 ZX6R, 14 GSXR 1000, 13 GSXR 600, 07 SV650, 14 300 Ninja, 13 300 Ninja
I've got a bent set of 300 Forks. PM me if you are still looking for some. or text me
Fastway Racing is offline   Reply With Quote
Need cheap '94-'09 EX500 forks to experiment with (little bent=OK). South Atlanta GMA CZroe Items Wanted 4 June 19th, 2014 07:51 PM
forks possibly bent? greenmachine 2008 - 2012 Ninja 250R Tech Talk 4 August 9th, 2013 03:28 PM
Are my forks bent? dino74 2008 - 2012 Ninja 250R Tech Talk 19 April 16th, 2013 07:28 PM
Bent Forks? Avenged7Fold 1986 - 2007 Ninja 250R Tech Talk 7 May 5th, 2012 08:17 PM
