January 19th, 2017, 04:41 PM | #1 |
[motorcycle.com] - 2017 Triumph Street Scrambler First Ride Review
2017 Triumph Street Scrambler Editor Score: 84.0%Engine 16.5/20Suspension/Handling 13.0/15 Transmission/Clutch 8.5/10Brakes 8.0/10 Instruments/Controls4.5/5 Ergonomics/Comfort 9.0/10 Appearance/Quality 9.0/10Desirability 8.0/10Value 7.5/10Overall Score84/100How many new Triumph Bonnevilles are we up to now anyway? The Street Twin came first, just about a year ago. We liked the sweet little runabout instantly, and it proceeded to come out on top of every comparison test we threw at it, usually by quite a lot. Wait, Maybe it was only this one: The Street Twin uses the 900cc “High Torque” Twin (instead of the 1200 Twins that go in the T120, Bobber and Thruxton), and that’s the engine Triumph decided to use in the all-new Scrambler. It’s a great little motor (that’s actually 900cc) that cranked out just about 53 rear-wheel horsepower in the Street Twin, which isn’t all that much but feels like way more thanks to the 58 pound-feet of torque it also produces at less than 3000 rpm. That grunt means it’s well-suited for off-road use even if other parts of the bike really aren’t. Triumph tells us it’s in the exact same tune as the Street Twin, which is fine by us. A single throttle body feeds both 450cc cylinders which keeps mixture velocity high; fueling is impeccable, exhaust gases are lower than Euro4 regs, and in normal use 60-plus mpg is, well, normal. (Not magazine testing use, where we stop and start constantly, ride like maniacs and make 80 photo passes.) They stuck the catalytic converter between that front black cover and the cylinder head. It was no problem on my chilly ride around Seville. Engineer David Lopez says it’s not one on hot days either, but this is not the bike for shorts and flip-flops. Triumph stresses it wants these bikes to be accessible to everyone, the opposite of intimidating – and it succeeded again with the Scrambler. Even 5-foot-8 people like me can touch the ground with both feet thanks to the 31.2-inch seat height, which is 33mm lower than before and a spec which actually reinforces the Steve McQueen ’60s look. I’m convinced McQueen would’ve quit riding if he’d lived into the era where dirtbikes constantly remind you how short you are. In fact, the new Scrambler reinforces the whole idea from that era that you can ride any bike off road if you have enough talent, whether the bike likes it or not. I only got to ride this one “off-road” (fire road, anyway) for maybe 20 minutes, and it’s definitely capable, but with 120mm of suspension travel at both ends and not a lot of ground clearance (you can’t have a lot and a low seat), you wouldn’t want to stray too far off the beaten path. I wouldn’t, anyway. Comes with actual bash plate ready to be bashed. It’s plastic, but it’s better than nothing. The budget slide-type front brake is the highest-effort control on the bike, but it does have good power given a stout two-finger squeeze. To get the right Scrambler geometry using the same frame as the Street Twin, Triumph bolted on longer shocks at the rear, then used 21mm-longer fork tubes up front. With the 19-inch wire-spoked wheel up front, you’re looking at a shallower rake angle and a longer trail figure to aid stability: 4.3 inches (109mm). To further aid stability, those longer shocks get stiffer springs and slightly increased damping in both extension and compression. But there’s still only 120mm travel at either end, 4.72 inches. The new Scrambler does feel like a big improvement over the previous one. Triumph specs a dry weight of 454 pounds. When we put gas in our Street Twin last year and put it on the official MO scales, it weighed 39 pounds more than Triumph’s claim. Using the same correction factor on the Scrambler should yield a 3.2-gallon gassed-up weight of about 493 lbs – which is still portly but 25 pounds less than the outgoing model. The giant Rio Tinto Mine outside Seville served as our own little Erzberg. Phoenicians first began mining copper and tin here to make bronze. The river that flows through it has a pH of like 2.5, but contains recently discovered bacteria that makes scientists think there could be life on Mars. Triumph Engineer David Lopez knows a lot of stuff… Along with that lightness (relatively speaking), the new Scrambler just seems to have more structural integrity than the old one; hitting potholes and rocky sections doesn’t have the bike squirming or loudly complaining like the old one. If you’re close to my size, the wide handlebar is in a good place whether sitting or standing, the new bike’s a bit skinnier between your knees. That big chunk of low-rpm power is really useful in lower-speed off-road use, and again, perfect, instant fueling makes the bike easy to control: So do the light-pull slip-assist clutch and effortless five-speed gearbox. For off-roaders of questionable skills such as myself, the addition of traction control is a good thing. Skilled ones can easily switch it off and perform lurid Mert Lawwill slides until their luck runs out. The ABS is also switch-offable. Back on pavement, the Metzeler Tourance dual-sport tires have enough grip to let you skim the Scrambler’s footpeg feelers now and then. It doesn’t steer as quick as the Street Twin, of course, but it’s still plenty quick diving into apexes and good fun roaring up to them with that blattiful pair of high pipes on the right side. Again, it feels like more than 54 horsepower. Like an old Ducati, this one prefers to be left in a higher gear where you can ride the torque wave out of corners instead of revving it out (which is a good thing since it only revs to 6500 rpm). It even quacks sort of like a Duc with the 270-degree crank. Toggle with the little “I” button atop your left thumb to find the ABS and Traction Control functions; you can turn both of them off if you so desire. TC will turn itself back on when you restart, ABS will not. It’s not really a street racer or a dirtbike, though, it’s a Scrambler, designed to be a stylish, easy-to-keep all-purpose daily runabout, and for that it could be a hoot. The wide handlebar and upright seating position make it easy to pick your way through inner-city traffic (and pick off the occasional mirror, oops…), and the seat you’re positioned upon is flat, broad, and very comfortable. If 120mm suspension travel is on the low end for off-road riding, for around town it’s ideal, and the 19-inch front tire’s nice for hopping the occasional curb as well. Nice rack: This comes with the bike and bolts right up instead of the back seat when you’ve got stuff to carry. There’s a USB port under the seat too. And though it looks like the classic ’60s Triumph Scramblers – one of which Evel Knievel failed to jump Caesar’s Palace fountain upon – it’ll be a lot easier to live with. Triumph says the oil only needs changing every 10,000 miles. I don’t think I could do that to a brand new motorcycle. Then again, the new bike’s not really on the cutting edge of high performance like the old Scramblers from the ’60s, is it? This is a kinder, gentler Triumph for the post-toolbox era, which Triumph is even trying to engage by already having over 150 bolt-on accessories standing by, many of which they say don’t require much mechanical skill or even a garage. Smart… The only complaint I can find is the bottom line: The Street Twin we heaped praise upon last year is an $8,700 bike. The new Scrambler starts at $10,700 for black, and from there “it’s a short walk” in PR-speak to matt green or red: Personally, I’m not sure I’m seeing where the extra $2000 went. But money is such a personal thing. If the Street Scrambler pushes your buttons, you won’t be disappointed. Swell detailing includes a brushed aluminum foil Triumph decal, which is almost as cool as an aluminum tank. 2017 Triumph Street Scrambler+ Highs</p>
Click here for full story...
[motorcyclistonline] - First Ride Review: 2017 Triumph Street Cup | Ninjette Newsbot | Motorcycling News | 0 | January 17th, 2017 02:51 PM |
[visordown.com] - First ride: Triumph Street Scrambler review | Ninjette Newsbot | Motorcycling News | 0 | January 17th, 2017 12:10 PM |
[motorcycle.com] - 2017 Triumph Street Scrambler Video Preview | Ninjette Newsbot | Motorcycling News | 0 | November 9th, 2016 12:21 PM |
[motorcycle.com] - 2017 Triumph Street Scrambler Video Preview | Ninjette Newsbot | Motorcycling News | 0 | November 8th, 2016 06:24 PM |
[motorcycle.com] - 2017 Triumph Street Scrambler Revealed | Ninjette Newsbot | Motorcycling News | 0 | November 8th, 2016 02:22 AM |
