Old June 2nd, 2011, 12:19 PM   #1
h0yitsdom
newbie newbie
h0yitsdom's Avatar
Motorcycle(s): 2006 Ninja ex250
radiator hose burst :( leaking coolant
this just happened maybe like 10-20 minutes ago, coming home from a ride on the freeway and while i'm pulin in to my parking lot space i see some drops of liquid then look closer and notice its coolant here is the culprit does anyone know what the part number is for it?
its the hose on the left connected to the water pump, this is looking from above
and here is another picture i found, the part that was leaking is to the left of the circled bolt
h0yitsdom is offline   Reply With Quote
Old June 2nd, 2011, 12:23 PM   #2
h0yitsdom
newbie newbie
h0yitsdom's Avatar
just found this picture
from what i can tell it seems like the part i'm looking for is
#32102A
Old June 2nd, 2011, 12:30 PM   #3
#32102A
looks correct to me.
How do you know it's the hose that's the problem? can you see the split in it?
Old June 2nd, 2011, 12:33 PM   #4
DaBlue1
DaBlue1's Avatar
It's a drain bolt. Tightening it should resolve your problem. Torque the Drain Bolt to 9.8 N·m (1.0 kgf·m or 87 in·lb)
Make sure you check your coolant level. Also cleaning the area around the source of the leak makes it easier to identify.
Old June 2nd, 2011, 12:40 PM   #5
h0yitsdom
newbie newbie
h0yitsdom's Avatar
i actually saw the fluid coming out of the hose and its loose now it looked like a crack and then the coolant was squirting out in a fine line
im going to look at the bolts tomorrow and remove the fairing so i can get a better look at everything
Old June 2nd, 2011, 12:44 PM   #6
if you are sure it's the hose that's damaged, then yes, the part number you listed is correct from that picture.
Old June 2nd, 2011, 12:45 PM   #7
My coolant was leaking from where the same hose goes into the radiator but it seems to have stopped (been months). I'll be watching it more closely as temps go up. If I have to, I'll try replacing the clamp before the hose.
Old June 2nd, 2011, 12:48 PM   #8
h0yitsdom
newbie newbie
h0yitsdom's Avatar
thats the thing mine wasn't leaking at all then today it pretty much dropped all of my coolant in my parking space and onto my lower fairing
Old June 2nd, 2011, 12:50 PM   #9
is part 670A an O-ring? could it be bad?
Old June 2nd, 2011, 01:06 PM   #10
DaBlue1
DaBlue1's Avatar
A bad o-ring will definitely make it loose and leak. All coolant hoses and clamps should be check every 6k miles. It is rare that a metal pipe would crack or split not unless it was damaged in some way. It would take more than 18 psi (system pressure)to split the pipe.
Old June 3rd, 2011, 09:24 AM   #11
h0yitsdom
newbie newbie
h0yitsdom's Avatar
the hose that split and is leaking is rubber tho, it connects into a metal bracket on the water pump but that isn't the part thats leaking, at least i don't think so
Old June 3rd, 2011, 11:06 PM   #12
pilot815
Motorcycle(s): Mine: 09 KLR650 Wife: 05 Ninja 250
If its a rubber hose thats leaking then take it off and go to a local autoparts store and get the same size diameter. You will pay a premium by going with OEM Kawi parts.
pilot815 is offline   Reply With Quote
Coolant Reservoir disconnected hose Ninja Rob 1986 - 2007 Ninja 250R Tech Talk 4 September 23rd, 2014 02:15 PM
New venhill SS hose is leaking at the banjo M42 1986 - 2007 Ninja 250R Tech Talk 11 June 22nd, 2014 01:22 PM
Coolant leaking from the top of the engine... LoneRonin 2008 - 2012 Ninja 250R Tech Talk 9 April 16th, 2013 06:56 PM
Leaking coolant Chuffmonkey 2008 - 2012 Ninja 250R Tech Talk 5 May 30th, 2012 11:47 PM
Issue with leaking oil ... no hose on air box ? thsadmin 1986 - 2007 Ninja 250R Tech Talk 10 May 9th, 2009 06:18 PM
