Old June 3rd, 2011, 01:19 AM   #1
wtfh4xx
Opinionated individual :)
wtfh4xx's Avatar
Motorcycle(s): 2010 Ninjette Special Edition (red/black)
Should I shim for a Yoshi slip on?
As title states, yoshi slip on and no snorkel delete.
Im thinking 1 washer each.
Has anyone still got the bag of 100?
Yoshi slip on, shimmed 2 washers, zip tie throttle mod, pre-load #2, snorkel delete
2010 SE 250R!
Miles in the saddle: 1000
wtfh4xx is offline   Reply With Quote
Old June 3rd, 2011, 04:09 AM   #2
rockNroll
rockNroll's Avatar
Motorcycle(s): black
I would expect shimming would make things nicer. I have 2 washers with stock exhaust.
Old June 3rd, 2011, 02:48 PM   #3
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
I need washers too (: if anyone can hook me up that'll be awesome!
Old June 3rd, 2011, 03:12 PM   #4
mmm just my opinion, and i know it will upset some, but seems like a waste of money.
go full pipe and jet the sumbish
Old June 3rd, 2011, 03:14 PM   #5
you buyin' for everybody?
Old June 3rd, 2011, 03:18 PM   #6
haha as soon as I win the lotto!
Old June 3rd, 2011, 03:25 PM   #7
tjkamper
tjkamper's Avatar
I'll hold you to that!
Old June 3rd, 2011, 03:27 PM   #8
Alex, I fully agree with you that a full system and a jet kit is the way to go, but you have to admit, for those not willing to commit that amount of money into their bikes, a slipon and shimming the carbs is a very cost effective combination. Hell, I would even go further and advise to skip the slipon and just shim the needles and be done with it for pennies.
Old June 3rd, 2011, 03:30 PM   #9
kaiserz
kaiserz's Avatar
hey guys I'm just wondering, will any 3mm washer do for shimming? or does it have to be something special?
Old June 3rd, 2011, 03:31 PM   #10
Snake
Snake's Avatar
Add me to the list.
Old June 3rd, 2011, 03:36 PM   #11
yes, either metric 3mm washers or SAE #4 washers will work.
Old June 3rd, 2011, 03:38 PM   #12
kaiserz
kaiserz's Avatar
Thank you Mr. Kkim (: you're the best!
Old June 4th, 2011, 12:01 AM   #13
wtfh4xx
wtfh4xx's Avatar
Thanks guys, after riding again today I could feel the power droppin out slightly at times I was on steady throttle.
Definitely felt a little lean and I think the colder temps today made the condition worse.
I was hesitant to shim because she starts up cold w/ choke no prob.
Definitely gonna shim now thou
How many washers do you need?
2010 SE 250R!
Old June 4th, 2011, 12:15 AM   #14
http://www.ninjette.org/forums/showthread.php?t=9465
Old June 4th, 2011, 06:22 PM   #15
wtfh4xx
wtfh4xx's Avatar
I just put in 2 washers and started it up, start up and idle are great.
I let it idle for about 5 minutes and then i rolled on throttle it bogs down and tries to die now.
Im guessing its too rich.
Should I pull a washer so theres only 1?
And my california kleen air system is too ridiculous to figure out to remove.
Nothing like the kleen air removal threads pics.
My big hose and small hoses both have t's in them going to some additional emission equipment on the left side of the bike.
2010 SE 250R!
Old June 4th, 2011, 08:41 PM   #16
wtfh4xx
wtfh4xx's Avatar
Washers were wrong size >.<
Got right ones from radioshack.
Went 2 shims each with snorkel remove and yoshi slip on.
just needs idle adjustment now
2010 SE 250R!
Old June 5th, 2011, 10:35 AM   #17
LoneRonin
LoneRonin's Avatar
Motorcycle(s): 09 Ninja 250r
is that with or without the snorkel?
LoneRonin is offline   Reply With Quote
Old June 5th, 2011, 11:06 AM   #18
wtfh4xx
wtfh4xx's Avatar
I adjusted idle and she's one happy girl now.
One thing I know, and its just because Im a pretty aware person, is that if you listen REALLY close you can kinda hear the washer in the carbs make a little jingle.
So to sum up the thread:
Dont buy washers other than the ones from radio shack.
Cali models kleen air is complicated w/ additional equipment.
I shimmed .40 (two .20 washers each carb) with yoshi slip on and snorkel delete.
Adjusted idle down slightly to 1500.
2010 SE 250R!
Old June 5th, 2011, 11:30 AM   #19
kenji_808
Motorcycle(s): 2009 CT Blue 250R(Sold), 2008 Black & Silver Honda CBR600RR(Current)
now just get a drop in k&n filter and perform the zip tie throttle tube mod and the bike will be really happy and way more responsive!!
you could drop your idle a bit more.... the FSM states idle speed at 1350 +/- 50 if i do remember correctly
kenji_808 is offline   Reply With Quote
Old June 5th, 2011, 01:00 PM   #20
rockNroll
rockNroll's Avatar
I pulled the snorkel out.
Old June 5th, 2011, 01:10 PM   #21
Cazper
ninjaholic
Cazper's Avatar
Kleen system delete isn't too bad and also helps eliminate backfiring. There is a thread about CA models (mine isn't even though I live here... I "imported" my bike from MN ) Just have to make sure that you cap the right things and add the fuel filter to the right spot. Just a thought
09' SE Ninja 250R
$2,547.83
Old June 5th, 2011, 04:09 PM   #22
wtfh4xx
wtfh4xx's Avatar
Thanks cazper, I checked around for a Cali specific kleen air removal but couldnt find one.
Also found out that instead of juryrigging up a plug, you can buy 5mm (i think thats right size) vacuum plugs for the crankcase and airbox holes.
2010 SE 250R!
Old June 5th, 2011, 04:12 PM   #23
wtfh4xx
wtfh4xx's Avatar
I was told the stock foam filter is a better filtering media and kkim advised adjusting idle to 1500 because its easier to read on the tach. Also easier to get goin in first with the slightly higher idle. Ill prob drop her down to 1400ish in a week or so once I get my first gear engagments down.
2010 SE 250R!
Old June 5th, 2011, 10:39 PM   #24
kaiserz
kaiserz's Avatar
Is there any benefit if you change your stock foam filter to a k&n filter?
I heard that it's not really advisable to do the kleen air removal mod if you have a stock exhaust. What if I have a slip-on? will it do any good? is it advisable?
Old June 5th, 2011, 11:08 PM   #25
wtfh4xx
wtfh4xx's Avatar
Filter: No benefit I am told.
Kleen air: Remove for anything other than stock exhaust of any form if you dont like the bubbling popping backfiring noise.
2010 SE 250R!
Old June 5th, 2011, 11:35 PM   #26
kaiserz
kaiserz's Avatar
No benefits unless you change it to pod filters?
Old June 6th, 2011, 06:12 PM   #27
Havok
Internet Slut
Havok's Avatar
Motorcycle(s): 04 FZ1, 07 FZ6
+1 to this, take the slip on money and save it to get a full exaust,
Slip on = noise
Full = Power
Havok is offline   Reply With Quote
Old June 6th, 2011, 06:15 PM   #28
wtfh4xx
wtfh4xx's Avatar
On a side note, Noise = Driver Awareness = Safety. ^_^
Sheesh, you want power you can get as much HP from snorkel delete as you can from full exhaust.
Saw the dyno maps :P
If I wanted power I'd just buy a bigger bike
The mods I did were simply to make the bike respond/run better, any HP gains were bonuses.
2010 SE 250R!
Yoshi Slip on Stinks rasta 2008 - 2012 Ninja 250R Tech Talk 10 October 25th, 2013 10:53 AM
Yoshi TRC slip on IconChris 2008 - 2012 Ninja 250R Tech Talk 7 April 17th, 2013 06:02 PM
yoshi slip on james250ninja 2008 - 2012 Ninja 250R Tech Talk 2 September 19th, 2011 07:44 AM
WTB: Yoshi CF Slip-On red Items Wanted 1 April 21st, 2011 07:14 AM
WTB: Yoshi CF Slip-On valerik Items Wanted 2 September 27th, 2009 09:58 AM
